'BF GR AT 275/70/16 with 5100s
Discussion in 'Wheels & Tires' started by spiceman, Nov 22, 2009.
  1. Nov 22, 2009 at 12:13 PM
    spiceman
    spiceman [OP] Well-Known Member
    Hawaii
    '07 4x4 DC OR, Desert Sand Mica
    Window Tint, Sockmonkey bed decals, Eibach 1.6" coils, 5100s front (set @ .85) / rear
    I have an '07 Tacoma OR 4x4 and I am considering placing 5100s on all four corners, with the 5100s on the first setting up front to level the truck and replacing the rugged trail 265/70/16s with 275/70/16s. Does anyone know if they will rub? I do not want ot trim. Also, will I need a diff drop and will my alignment be able to be adjusted back to specs? Thanks.
  2. Nov 22, 2009 at 12:23 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    I would go with a 265/75/16 set the billy's in the middle @ 1.75 and be done I don't think you need a diff drop but some might say you do good luck
  3. Nov 22, 2009 at 2:27 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    ^^ is right...w/ the lift and the 275's, there may be a slight trim...but possibly none...also no need for the diff drop and specs should be really close, if not in
  4. Nov 22, 2009 at 2:36 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    mine never rubbed even when my truck was stock
  5. Nov 22, 2009 at 2:39 PM
    jhodge83
    SC
    17 XLT Sport
    275's or 265's? i know the 265/75's wont rub
  6. Nov 22, 2009 at 2:47 PM
    spiceman
    Hawaii
    Thanks, I was interested in the BFGR AT 275/70/16s, but I do not want to trim and I was going to stay stock in the rear (with 5100s) and only level out the front with 5100s. I do not see where anyone goes to the 275s; they usually go all the way to 285s with a full 3" lift. What do you think?
  7. Nov 22, 2009 at 2:50 PM
    jhodge83
    SC
    17 XLT Sport
    i think u'd be safe w/ the 275's and leveled out. those 265/75's dont rub at stock height. i was running 255/75/17's stock and they are slightly taller and slightly narrower and i didnt have any issue
  8. Nov 22, 2009 at 2:56 PM
    spiceman
    Hawaii
    What would you recommend setting the 5100s at to level the front?
  9. Nov 22, 2009 at 3:01 PM
    jhodge83
    SC
    17 XLT Sport
    if stock in the rear w/ no TSB, i think most are at 1.75"
  10. Nov 22, 2009 at 3:04 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
  11. Nov 22, 2009 at 3:13 PM
    spiceman
    Hawaii
  12. Nov 22, 2009 at 3:17 PM
    jhodge83
    SC
    17 XLT Sport
    complain about bottoming out and rough ride...question the TSB, then if they get stupid, whip out a copy of the TSB
  13. Nov 22, 2009 at 3:21 PM
    spiceman
    Hawaii
    Thanks, That's what I have read. The only problem I can think of is that I keep my truck clean, nothing has ever been in the bed, and it only has about 8K miles. You can tell when you look at it that it has been babied. So I am not for sure if they will listen when I tell them it bottoms out. It would be nice to get the extra leaf though.
  14. Nov 22, 2009 at 3:24 PM
    jhodge83
    SC
    17 XLT Sport
    well u can try just complaining about the rough ride in the rear over bump/washboard areas, etc. thats all i complained about to get it done on my 07
  15. Nov 22, 2009 at 5:50 PM
    spiceman
    Hawaii
    Now that sounds good, roads are rough out here, I will call Monday, thanks
