BFG 265 70 R17 Rugged Terrain vs All Terrain
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elytravis, Sep 9, 2015.
  1. Sep 9, 2015 at 5:31 PM
    elytravis
    elytravis [OP] Well-Known Member
    Travis
    Always changing...but there is no place like home.
    2012 Nautical Blue DCLB TRD Sport
    Black tube steps, Skid plate, Bilstein 6112's front and 5160's rear, Bakflip F1 folding cover, EGR raingaurds, All weather floor mats, AFE pro dry filter, BFG 265 70 R 17 KO2's.
    I have a 2012 TRD Sport DCLB with stock suspension and no lift. I'm coming due for some tires and am liking the aggressive look of the BFG A/T's. I see BFG has All Terrain and Rugged Terrain is an option too and am trying to compare the two as far as aggressive stance, effectiveness on and off road, rubbing on a non lifted TRD sport, and MPG which is the least of my concern but still a factor. Off-road.com says "Here’s a comparison between the tread pattern of the Rugged Terrain T/A (front) and the All-Terrain T/A KO. As shown here, the Rugged Terrain is not quite as aggressive as the All-Terrain, but it is a much quieter tire on pavement and is designed for improved wet traction." in regards to the picture I have posted but am wondering what tacomaworld has to say. Thanks for any help.
  2. Sep 9, 2015 at 6:21 PM
    Turdsport
    Turdsport Well-Known Member
    Josh
    '14 TRD Sport Supercharged
    Well, the ko's are decent for off-road. They'll keep you out of moderate trouble. The rugged terrains will likely give you a better ride, less noise, better mpg and longer wear. They'll still do decent off-road, but they lack that aggressive look. I'd go with the ko. They're a little less grocery-gitter.
  3. Sep 9, 2015 at 7:36 PM
    elytravis
    Travis
    Thanks, I think that's what I'm leaning towards. I think with those and a subtle lift or leveling they will still look good but it seems I can fit them without needing a lift quite yet. I'm also deciding on what to get for a reasonably priced suspension kit. My friend may be able to get me a deal on an icon setup but that's pretty expensive too.
  4. Sep 9, 2015 at 10:19 PM
    Robman
    Robman Well-Known Member
    Rob
    Hawaii
    '14 Tacoma Double Cab
    I've owned AT on my last two vehicles, I personally found it to have excellent treadlife.
    If I were in your boat, i'd go for the KO2 (2nd gen). Came out right after I put my current set on. They look even more aggressive. Any KO tire you buy at this point is likely to have been sitting on a shelf for the better part of the year.
    I'm in a '14 Sport, no suspension mods but the wheels are not factory. No issues.
    idahbro likes this.
  5. Sep 10, 2015 at 12:22 AM
    JDawg562
    JDawg562 Derp.
    Justin
    Long Beach, CA
    2007,TRD Off-Road, Access Cab
    Can't go wrong with the BFG KOs! They were my 1st set I got after I got my truck. My Tacoma had the Rugged Terrain and I didn't really like them. I'd get the KO2s they seem really good.
  6. Sep 10, 2015 at 7:29 AM
    elytravis
    Travis
    Thanks for the insight, Robman the pic looks good and is helpful and JGawg562 the side by side opinion is almost the most helpful so far.
  7. Sep 10, 2015 at 5:29 PM
    JDawg562
    JDawg562 Derp.
    Justin
    Long Beach, CA
    Yeah it's all up to you and what you want to do with it. My friend loves his All-Terrain T/A KOs on his Tundra and he goes pretty much anywhere I go. I tried to get him to buy Goodyears Duratracs next I wanted him to be my guinea pig, but he seems set on getting the BFG All-Terrain KO2s next.
  8. Sep 10, 2015 at 6:46 PM
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    Are you getting the older AT KM or the new AT KM2?
    I had the Rugged Terrains on my previous 4Runner and I enjoyed them. They rode great on the highway and did very well in the MD/DC snow storms.
    But when I replace my tires on the Tacoma, I want to go with the BFG AT KM2.
  9. Sep 10, 2015 at 7:16 PM
    elytravis
    Travis
  10. Sep 10, 2015 at 7:21 PM
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    He meant KO or KO2. Those in the link are KO2, the newest design with the more aggressive sidewall. I'd skip the Rugged Terrains but I'd make sure to get load range C ATs, not E. The E range tires will be heavier, stiffer, and more expensive.
    elytravis[OP] likes this.
  11. Sep 10, 2015 at 8:05 PM
    mattvivsound
    Southern MD
    Yea whoops... I meant KO... the KO is on the AT and KM is on the Muds. Both are in "Gen 2" of the K_ line up; in actually the KM2/KO2 are the 3rd version of the tire. The original T/A series didn't have any sidewall lug/tread/ribs.
  12. Sep 10, 2015 at 8:09 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    When I bought my Taco I did a lot of reading online. Get the KO2 instead of the KO. The KO2's are the newer generation and reportedly better than the original. Had I gone with an AT tire the KO2 was at the top of my list.
    I decided to get a Highway tire since I don't actually off-road yet. And I put 20+ miles a day on my truck at 55-70mph for my commute to work. My Michelin LTX M/S2's aren't aggressive looking at all... but they are quiet, ride very smooth, hold a straight line, and did not impact fuel economy at all.
  13. Sep 11, 2015 at 5:54 AM
    elytravis
    Travis
    I have been told I may need to remove or trim my front mud flaps if the truck isn't lifted yet but that's a small issue I believe.
  14. Sep 11, 2015 at 5:57 AM
    Iowa10
    Iowa10 Well-Known Member
    I don't know why, but it sounds like it varies from truck to truck. plenty of people here have put the KO2s on their unlifted truck and report zero problems. Seems like there shouldn't be variance from vehicle to vehicle, but apparently there is.
  15. Sep 11, 2015 at 8:39 AM
    elytravis
    Travis
    Well...I was surprised today to find on Tacomaworld a steal...
    http://stores.ebay.com/Discount-Tire-Direct
    I bought 2 separate sets of 2 tires (BFG 265 70 R 17 KO2) $466 each. I got $100 off each purchase on free shipping on both to be here in 6 days for a grand total of $732. Hell of a deal!
  16. Sep 12, 2015 at 3:58 PM
    JDawg562
    JDawg562 Derp.
    Justin
    Long Beach, CA
    Yeah with 265/70/17s you probably have to remove the mud flaps and trim a little if you don't have a lift.
  17. Sep 12, 2015 at 4:13 PM
    idahbro
    idahbro Well-Known Member
    TRD OR AC
    Leer XL Cap, Thule Rack, Weathertech Mats, Sleeping Deck/Bed Storage, Pop and Lock Tailgate Lock
    What are the size specs on your wheels/tires?
  18. Sep 12, 2015 at 4:29 PM
    Pigpen
    Dan
    Northwest Montana
    That's the same size as a 265/75/16 (31.5" +/-). You shouldn't have to do anything - even for offroading - as long as you're on stock rims with no spacers. If you have spacers, you may rub when flexing and turning. I ran the 265/75/16 through hell and back with no issues before lifting and going to 33s
  19. Sep 12, 2015 at 5:41 PM
    elytravis
    Travis
    Nice, I'm looking into wheels and a subtle leveling kit up to a 3" lift. I think I'll still be happy with the tires with a little suspensions increase
  20. Sep 13, 2015 at 8:57 AM
    Robman
    Rob
    Hawaii
    17 inch x 7.0 inch x 4 mm offset
    265/70/17
    idahbro[QUOTED] likes this.
