BFG 33/10.5/15 & Costco help
Discussion in 'Wheels & Tires' started by Rucas, Jun 5, 2011.
  1. Jun 5, 2011 at 3:30 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    Costco has a pretty good price for these tires installed
    $175/tire
    $14 install (super cheap)
    But theres one problem...
    I called and they said that they would only do the install if there is clearance around the tire and fender. If not they would not let me leave with the tires on.
    I have eibach's in the front giving about 3", and close to 4" in the back.
    How much clearance will I have with the 33/10.5 tires?
    (BFG a/t KO)
  2. Jun 5, 2011 at 3:31 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    what kind of wheels you got?
    pretty sure you have enough lift just the wheel backspacing is the only thing i can think of that would make you run into a problem
  3. Jun 5, 2011 at 3:34 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    they would be 3rd gen 4runner rims.
    Idk the backspacing?
  4. Jun 5, 2011 at 3:35 PM
    08pretaco
    az
    arent most toyota stockers 5.5"?
  5. Jun 5, 2011 at 3:41 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    actually there 2nd gen 4runner rims.
  6. Jun 5, 2011 at 3:47 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    Backspacing is most likley 4.5"
    (3.5" came from Solid axel 4runners)
    Ill check the rims when i get home to make sure.
  7. Jun 7, 2011 at 3:52 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    nevermind on this...
    Costco only installs costco bought tires.
    Also Sears does installs for $16.99 and they dont have any problems if the tires rub a little. (costco wouldnt install if they rub)
  8. Jun 7, 2011 at 3:57 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Not entirely true...you just have to talk to the guys in the shop.
    I showed up with 4 loose wheels and tires for my toy hauler and $40 and bullshitted with one of the guys in the shop for a bit. Came back an hour later and it was done. :cool:
    Also, doublecheck that price on Sears. I'm pretty sure it's $16.99 for mount/balance IF YOU BUY THE TIRES FROM THEM.
  9. Jun 7, 2011 at 10:15 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    hmmm well Ill check on the Sears price befor I got down there. Im pretty sure he said free mounting and balancing is $16.99
  10. Jun 7, 2011 at 10:32 PM
    tanzak88
    tanzak88 Well-Known Member
    Costco won't install tires on a vehicle if the tires aren't factory size.
    It's a liability issue. They will mount/balance though.
    At least this is the way it is in Canada. Been there, done that.
  11. Jun 7, 2011 at 11:08 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    yeah that was my dilema. The place around here said that they would only do it is there was clearance, if not they would take them off and either refund my money, or send me some with the tires.
  12. Jun 8, 2011 at 5:14 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Any way you could just bring them the rims? Not sure if you have another truck or if you could borrow a buddy's for a little bit. They'll never know if they rub or not.
  13. Jun 8, 2011 at 7:35 AM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    I kinda solved my problem, by switching to having Sears install.
  14. Jun 12, 2011 at 9:11 AM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    okay.
    Just in case anyone else searches this and wants to know the outcome, the 33/10.5's were put on by sears and didnt rub at all. Full turn both ways, front suspension if bilstein 5100's and eibachs.
