BFG All Terrain Off Road Pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by canyonchaser, Nov 1, 2011.
  1. Nov 1, 2011 at 8:26 AM
    canyonchaser
    canyonchaser [OP] Member Known Well
    Dave
    Utah
    LR TRD PRO MT
    So on the street I run about 35-40psi, what pressure should I run for moderate off-road, rocky terrain?
    Thanks,
    dp
  2. Nov 1, 2011 at 8:27 AM
    98tacoma27
    Ben
    Not Beech Creek
    12-20 psi.
  3. Nov 1, 2011 at 8:29 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Are you not bouncing all over the place with the pressure that high on the street? Assuming they are Load Range E.
    I had MTZs in Load Range E and I had them at 30-32 in order for the ride quality to be decent - the chalk test proved they were only slightly underinflated so I just went with it and they lasted 40k+.
    Fink
  4. Nov 1, 2011 at 8:50 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I'd like to know the offroading pressure too. I'm running bfg a/ts load range e at 36psi front/34 back. I was under the impression too low a pressure could cause sidewall damage since these sidwalls are so thick. Is that a real concern for the amount of time the pressure would be dropped while offroading with the e rated tires?
  5. Nov 1, 2011 at 8:53 AM
    Fink
    Orlando, FL
    Ben answered the question - 12-20psi is ideal.
    As long as you are smart about it, you won't hurt anything.
    The idea that a thicker sidewall is more prone to damage when underinflated doesn't seem to make much sense to me, but I have no proof to back my suspicion.
    Fink
  6. Nov 1, 2011 at 3:52 PM
    canyonchaser
    Dave
    Utah
    LR TRD PRO MT
    Yes, they are the load range E and I watch them pretty close and between 35-40 seems to be the best compromise between wear and ride.
    Thanks for the off-road prussure guideline. I've always run mine off road much higher than that. I'll probably start around 15-18 and go from there. :D
    dp
