BFG ALL TERRAIN REVIEW
Discussion in 'Wheels & Tires' started by Ihavataco98, May 8, 2012.
  1. May 8, 2012 at 7:12 PM
    Ihavataco98
    Ihavataco98 [OP] Well-Known Member
    Well, they lasted me 7 years and so far i got 70,000 miles outa them. They were the best tire i have ever had... I had the 32x11.5x15s, they went through everything and anything you can immagine. This weekend they will be coming off for a set of bfg rugged terrains, I would recomend this tire for any terrain possible..... time to test the rugged terrains and let ya'll kno how they do..... :D
  2. May 8, 2012 at 7:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Put them up against other AT's side by side, and you'll see their flaws. Yes, they are a strong tire. However, their designe is 30+ years old. Most new AT's out right now have much better traction characteristics than the BFG AT's.
  3. May 8, 2012 at 7:58 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    So you are going to switch from a all terrain tire to a highway tread tire that looks like an all terrain tire.
    Just letting you know the rugged terrain is more looks than anything else. Hope it will meet your needs. I has gotten positive reviews on here when replacing the rugged trail POS.
  4. May 8, 2012 at 8:22 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    The bfg a/t/ ko is a great tire! I've gone through around 5 sets of them over the years and get about 70,000 miles out of them each time....wouldn't put anything else on a truck.
  5. May 9, 2012 at 7:27 AM
    Ihavataco98
    They do look like a highway tire... yes.... but if you look at the tread it has an Awesome pattern on them. I loved the bfg but i wanted something new, this was a newer look. at first look they look like they have little tread on them, but when you put your finger down in the middle of the tire they have PLENTY of tread. Yes, i didnt want to stray away :( but I just couldnt help myself.... Ill be the monkey to test them :D haha
  6. May 9, 2012 at 7:34 AM
    lj973gm
    Ohio
    06 DCSB 4wd
    They have been tested already if you search. It is not a easy search since you typically get rugged trail results. Probably about 5-6 people posted about running them with positive results for a nice quiet tire.
    I was all about these when they first came out but then backed off since they are a highway tire. I have seen them in person multiple times. They are a pavement cruising tire. BFG specifically made these to keep mpg up but have the look of a tuff all terrain tire.
    Check any major retailer and they are a highway tire. Not trying to prove anything here just letting you know before you buy or if you already have and need a different tire for your needs.
  7. May 10, 2012 at 7:18 AM
    Ihavataco98
    i checked them out, they are a highway tire... I dont do much wheeling But I do have to have a tire for my hunting camp.... these seem like they would be perfect thats why I went and got them already.... :D just waiting on my next payday and im putting a powdercoat on my rims and the new babbys are goin on.... thanks for the info on them tho, i woulda never known. I hate the humming that the kos had hopefully this will be what i need. If not im going back to the Ko.
  8. May 10, 2012 at 10:27 AM
    Smokey11
    Smokey11 You Can't Fix Stupid !
    Jeremy
    Anchorage, Ak
    99 ex-cab TRD 2.7L 4X4
    OME 881, 10MM top plate spacer,nitros,wheelers 5 pack, 1.25 Daystar Shackles,265-75-16 Duratracs on 16X8 Pro Comps,leer shell, husky liners, sway bar removed, X-runner badges, tint, auto start, BPV relocate, extended rear brake line.
    To me that means something, if something has been around that long must be pretty dam good. Have had a number of sets of them ( including running them now) and couldn't be happier every time.
  9. May 10, 2012 at 10:31 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Yeah, it means they've been too lazy to redesign a new tread pattern :D
    I agree with Chris16, they're not a bad tire at all, they are certainly tried and true but there are better options out there. Tire tech has evolved, BFG KO's have not.
  10. May 10, 2012 at 10:33 AM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    Rugged Terrain SUCK SUCK SUCK SUCK SUCK
    DON"T DO IT.
    Shitty traction
    Shitty treadwear
    sidewalls roll in corners
    ANY mud and they will bologney skin on you in a second.
    I had these tires
    They SUCK
    lasted me 28kmi
    Again, dont do it
    I have had teh BFG AT and they were great. Even with driving like a mad man, they went almost 60kmi for me.
  11. May 10, 2012 at 10:34 AM
    Aw9d
    Aw9d That one guy
    Az
    :rofl:
  12. May 10, 2012 at 10:36 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Rugged Trails came stock on a lot of Tacomas, they arent named Rugged Fails for nothing
  13. May 10, 2012 at 10:39 AM
    CantSitStill
    FTR
    CNY
    this again- If you are doing NO offroad, the rugged trail may be OK for you.
  14. May 10, 2012 at 11:33 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    OP is changing to rugged terrains, not regged trails. different tire.
  15. May 10, 2012 at 11:49 AM
    Cr250jumper
    The moon
    50 shades of tan©
    Damn, fail by me :eek:
  16. May 10, 2012 at 11:52 AM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    duratrac
  17. May 10, 2012 at 2:51 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    A popular tire, indeed... maybe the #1 AT tire out there... But, if they see a lot of off roading, the weakness is their over-rated '3 ply sidewall'... I experienced a sidewall failure and have seen and heard of numerous sidewall failures on the BFG All Terrain TAs... But, there are those who swear by them, still the same.
    Cooper (Discoverer ATR), Toyo (Open Country AT) and Hankook (Dynapro ATm) have proven themselves as great AT tires with me... so far!
  18. May 10, 2012 at 7:40 PM
    CantSitStill
    FTR
    CNY
    Ooops, maybe I got the wrong tire here. Maybe it was the Rugged TRAIL that came on my FJ with the Offroad package. Those tires did suck it
  19. May 10, 2012 at 7:45 PM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    bfg a/t is a damn good tire..i like my terra grapplers a little better, price is mainly what had me sold. i don't think bfgs are worth the money
    Thanks for the review OP!
  20. May 10, 2012 at 7:45 PM
    tacoftw
    McDonough, GA
    05 Double Cab 4x4
