Bfg all-terrain
Discussion in 'Wheels & Tires' started by TRDsport253, Mar 2, 2010.
Tire size
Poll closed Apr 1, 2010.
  1. 265/65 17
    10 vote(s)
    7.9%
  2. 265/70 17
    116 vote(s)
    92.1%
  1. Mar 2, 2010 at 3:19 AM
    TRDsport253
    TRDsport253 [OP] Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    I'm buying bfg all terrain this weekend and having trouble deciding on the tire size. Don't know whether i should just get stock size which are the 265/65 17 or up a size 265/70 17. The truck won't be lifted anytime soon or not at all. Who's running 70's on thier stock height 4x4/PreRunner truck. How does it ride and any rubbing or other issue at all? White wall out or black wall? Remember truck will remain at stock height for the time being. Lift in the far future.
  2. Mar 2, 2010 at 11:22 AM
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
  3. Mar 2, 2010 at 11:28 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    I got the next size bigger 265/70/17 Duratrac. No lift at all. Stock Height. No rubbing. No issues at all. Rides Great. I went with black out. Im glad I did. I may or may not lift. No plans to do so yet.If I do lift a little, this size tire will still look good. Im happy with the way it makes the truck look more aggressive.They make the truck look so much better. Just do it! Hope this pic helps!
  4. Mar 2, 2010 at 11:30 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    The width (265) & the sidewall (70) both make up how big the tire is.......265/70 means the sidewall is 70% of the width which in this case would be 70% of 265mm. That formula determines the outside diameter of the tire. The 17,18,19 is just the hole in the center to fit the rim. Find a tire size calculator online to see what slightly wider sizes will be relative to the oem OD to keep the speedo correct as possible....and rub the least if at all without doing lift.
  5. Mar 2, 2010 at 11:33 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I had BFG AT 265/70/17's on my truck @ stock height, didn't have any rubbing issues
  6. Mar 2, 2010 at 11:35 AM
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
  7. Mar 2, 2010 at 11:35 AM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    Wow I totally misread your post. :anonymous:
    265/70/17
  8. Mar 2, 2010 at 11:39 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Yea it's basically the same size as a 265/75/16...I ran that size with no lift and had no issues at all...I'm still running 265/75s with a 3" lift...I gotta get new wheels with a different/deeper backspacing to run 285s...I refuse to run spacers
  9. Mar 2, 2010 at 11:40 AM
    taco man31
    taco man31 Well-Known Member
    i had a set of bfg all terrain on my truck for a little while. They suck. Always threw rocks up and chipping my truck.
  10. Mar 2, 2010 at 11:41 AM
    ColtsTRD
    Scott
    AZ
    Yea they clog up pretty easy...
  11. Mar 2, 2010 at 11:58 AM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    okay. Just did
  12. Mar 2, 2010 at 12:18 PM
    Hunter423
    Hunter423 Hunter423
    hunter
    TN
    2008 Tacoma TRD off road
    brush guard, piaa foggs, tinted tail light, tinted windows, rain guards, pure white with blue tinted bulbd all over, white bulbs for licencess plate lighting, blacked out head lights
    hey question if any one can help, how does the bfg all terrains compare to dura trac all terrains im trying to buy a new set of off roading tires they wont be used on streets at all and was just trying to see how they compare and if how they compare price wise
  13. Mar 2, 2010 at 12:21 PM
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
    thanks to all.
  14. Mar 2, 2010 at 12:23 PM
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
    second thoughts about the bfg now.
  15. Mar 2, 2010 at 12:55 PM
    NicksRig
    NicksRig Well-Known Member
    Kenora, Ontario
    07 Tacoma DC TRD Sport
    Blacked out Skid plate, block heater, bug deflector, blacked out headlights, tinted fronts, OME 3" lift, Toytec AAL, Revenge-Fab Sliders, K&N Air Filter
    Go with the 265/70/17 Looks a little bigger and better IMO
  16. Mar 2, 2010 at 12:57 PM
    ColtsTRD
    Scott
    AZ
    I think the Duratracs look better and from what i've heard they perform better aswell... :D
  17. Mar 2, 2010 at 1:16 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    i have 265/70/17 bfg at's on my stock prerunner. looks sexy as fuck.
  18. Mar 2, 2010 at 1:20 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    no. get them. they are great.
  19. Mar 2, 2010 at 2:27 PM
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
    for some reason the 265/70 are actually cheaper than 265/65
  20. Mar 2, 2010 at 2:48 PM
    john32
    john32 Well-Known Member
    Seaside, Ca
    4x4 Reg cab 2.7L SR5 Manual
    diff breather
    ColtsTRD, why do you refuse to run spacers?
