BFG All terrains
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004Taco, Apr 15, 2010.
  1. Apr 15, 2010 at 4:04 PM
    2004Taco
    2004Taco [OP] Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Ok, so about a few weeks ago, I posted a thread about 265/75/16 and MPG. Ever since going from a Radial Emerald all terrain 265/70/16 to a BFG all terrain 265/75/16 my MPG has gone down. Ppl have been telling me they have been getting average MPG with the SAME SIZE TIRE (265/75/16) about 17 or 280 to a tank.
    So my question is, what do you guys get with this specific BFG AT KO 265/75/16 tire?
    Im getting about 250-260 to a tank. Before i got about 280-290 with a Radial Emerald all terrain (265/70/16). Am I going crazy or is it just the BFG all terrian tires and not the size?
  2. Apr 15, 2010 at 4:12 PM
    fixedforbroke
    fixedforbroke Well-Known Member
    St. Simons Island
    06 PreRunner SR5 White as Snow
    Stock the way god made her. (FOR NOW)
    I personally have no experience with BFG All- Terrains but i know that they are heavier than standard tires.
  3. Apr 15, 2010 at 4:17 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I went from BFG AT 265/70/17 to BFG AT 285/70/17 and I took about a 1.5mpg hit.
  4. Apr 15, 2010 at 4:22 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    i have 285/75/16 BFG AT's and i get close to 250 per tank
  5. Apr 15, 2010 at 4:39 PM
    Got Tacoma
    Got Tacoma Well-Known Member
    Gila
    Arizona
    2010 Dbl. Cab Sb 4 x 4 Trd
    Undercover Tonneau, Roof Rack, ABR Bumper, Warn 9.5xp, OME 886, Dakar leaf springs, Bilstein 5100 Struts and shocks
    I don't know what Radial emerald weigh but the BFG All terrain in 265/75/16 weigh around 53 lbs per tire that's 13 lbs heavier than the stock BFG rugged trails weigh.
    Here is some date comparing your old size tire to your new size tire. Every inch you go up in size loses about .75 to 1.0 mpg efficiency. If your old tire weighed around 40 lbs making a 13 lb difference and adding one inch tire height I would say a minimum loss of 1 mph is about par.
    I have BFG All Terrain 265/70/16 and get 21mpg at 65 mph mixed driving 75% hwy and 25% between 40 and 50mph.
    Current Tire New Tire Difference Diameter inches (mm) 30.61 (777.4) 31.65 (803.9) 1.04 (26.5) 3.4%
    Width inches (mm)
    10.43 (265) 10.43 (265) 0 (0) 0%
    Circum. inches (mm)
    96.15 (2442.27) 99.43 (2525.53) 3.28 (83.26) 3.4%
    Sidewall Height inches (mm)
    7.3 (185.5) 7.82 (198.75) 0.52 (13.25) 7.1%
    Revolutions per mile (km)
    658.95 (409.21) 637.23 (395.72) -21.72 (-13.49) -3.3%
  6. Apr 15, 2010 at 6:13 PM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    When I changed tire size, I used my GPS during a long road trip (200+ miles) and tracked 100 miles, twice to see how much I was off in regards to my odometer. My truck showed 100 miles, and my GPS showed 103. Second test: GPS showed 100, truck showed 97. I am about 3% off on my truck's odometer mileage so I calculate that when I figure my MPGs each tank (before I enter the miles into fuelly.) Odd though, my speedometer is pretty spot on...
    EDIT: Forgot to add tire size change...
    I went from 265/70-16 to 265/75-16...nothing big, but similar to what the OP changed. Don't forget to check out http://www.tacomaworld.com/forum/tirecalc.php to see the differences of the two tire sizes.
  7. Apr 15, 2010 at 7:49 PM
    toyman
    toyman Member
    t
    Amarillo Tx
    2003 Toyota Tacoma 4x4 trd
    i have 265/70/16 and i get about 19mpg,so yea its not great.thats what it had on it when i bought it.
  8. Apr 16, 2010 at 12:10 AM
    Backslash
    Backslash Well-Known Member
    Thatcher, AZ
    04 3.4V6 Auto 4x4
    2004 Xtra Cab with exact same tires: 17.6 around town and dirt road driving
  9. Apr 16, 2010 at 9:25 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    with bigger tires you cant get an accurate mpg with your odometer because it'll be off.
  10. Apr 16, 2010 at 9:41 PM
    shocker01
    shocker01 Well-Known Member
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    5100 Billies, drop-in k&n, deck plate, gray wire, Dynomax exhaust.
    I lost around 1.5mpg instantly when I went to the AT from stock RT, same size.
  11. Apr 17, 2010 at 6:03 PM
    2004Taco
    Lou
    California
    Well im about to get a new fuel filter and change my spark plugs. Havent done that since i bought the thing ( a little over a year ago ). So we'll see
  12. Apr 17, 2010 at 8:31 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Ever think that the way that you drive your truck could be slightly more aggressive, which would mean slightly worse gas mileage, than the people that gave you their numbers?
    crazy thought, i know.
  13. Apr 17, 2010 at 9:00 PM
    2004Taco
    Lou
    California
    I drive like a grandma
  14. Sep 7, 2010 at 8:51 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    I have BFG AT KO 265/75/16s and my Odo still says between 300 and 350mi per tank. Most of it highway. Because of the larger tire size, it actually traveled a few more miles than that.
    So I guess factoring in everything; I get around 18-19 mpg highway.
  15. Sep 7, 2010 at 8:57 AM
    bighungitacoma
    bighungitacoma Well-Known Member
    backslash, im pretty sure we might b twins...or actually triplets with conekiller:
  16. Sep 7, 2010 at 8:59 AM
    2004Taco
    Lou
    California
    Gobais- do you have the 4 banger?
  17. Sep 7, 2010 at 9:06 AM
    gobias
    02 Dbl TRD
    Nope. 3.4L
  18. Sep 7, 2010 at 11:18 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    I had 32" BFGs and a 3RZ engine and I got like 18 in the winter. Also had manual tranny tho. I'll let you know my MPG in the winter when the ATs go back on.
  19. Sep 7, 2010 at 5:28 PM
    fireman_343
    fireman_343 Ultimate TRD
    Brian
    Columbus, OHIO
    05 TRD Dlb Cab
    Viper Alarm, XD Series Wheels, Pioneer touch screen radio/nav system.
    My 01 DC V6 has 35's and I get about 16 mpg now, but I've got super light rims, so that helps a lot!!
    My old 00 ext cab V6, manual tranny with 31x10.5's got around 19mpg.
    It's all in how you drive it, I get a lot less if I have a lead foot!
  20. Sep 7, 2010 at 5:41 PM
    bajaracer
    bajaracer Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    I went from Toyo Open Countrys to BFG AT KO's and seem to be getting better MPG...
