BFG AT KO2 in the snow
Discussion in '3rd Gen. Tacomas (2016-2023)' started by joejm14, Nov 12, 2018.
  1. Nov 13, 2018 at 6:27 PM
    #41
    Isay0526
    Isay0526 Well-Known Member
    Isay
    2017 Tacoma TRD offroad
    So we all mentioned KO2, duratrac, wildpeak, Cooper's and Michelin ms2. But has anyone on here tried the Michelin AT2?
  2. Nov 13, 2018 at 6:46 PM
    #42
    SpeySquatch
    2016 TRD OR DCSB
    What width are you running?
    Skinnier tires work better in snow and ice. A 245 or 255 width mud terrain is something to behold
  3. Nov 13, 2018 at 7:08 PM
    #43
    sfr4dr
    sfr4dr Well-Known Member
    Truckee/Tahoe CA
    Currently trying to pick my next Toyota!
    I live in a ski town, tons of snow and ko2s suck. Figures since they were designed in what, the 80s! I have Wildpeaks for summer. They're snow flake rated but I want the best traction available and that only comes with dedicated winter tires. You need those thousands of sipes and winter rubber compound to really grab. I run the pictured General Altimax Artics and they're absolutely amazing on plowed roads and snow up to the bumpers. On ice, they're very good. Studs would be better but I drive it down to the flatlands for holidays and the studs are noisy AF. Our other car does have studs though.
    SilverII, TacoManOne and Stocklocker like this.
  4. Nov 13, 2018 at 7:11 PM
    #44
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    I didn't have much issue in snow with my old KOs, at least when they were new, but I always found their cold, wet weather traction to be lacking in that it was quite easy to trip the ABS on my 2G. I ended up with dedicated snows (Hankook i-Pike RW11's) and they have worked well enough.
    So far the KO2 on my 3G don't seem to have quite the same damp / wet weather ABS engagement issue, but we will see how they wear. That being said, I'm still running my Hankooks for likely one final season as they're coming up on 6 years old, although they have sufficient tread remaining. The Cooper AT3 4S are appealing for replacements although I'll need to do some reading comparing those to dedicated snows.
  5. Nov 13, 2018 at 7:15 PM
    #45
    phsycle
    phsycle Well-Known Member
    CA
    Surprising this get regurgitated so much. Simply not true on all accounts.
  6. Nov 13, 2018 at 7:37 PM
    #46
    SpeySquatch
    2016 TRD OR DCSB
    OK...a lot of snow and ice here in Oregon.
    Surprising that 285’s get consistently desired when in fact they hinder the engine performance and power of these small trucks...I guess it’s a “looks” thing
  7. Nov 13, 2018 at 7:47 PM
    #47
    Hemlocktherm78
    Hemlocktherm78 Well-Known Member
    That's what I would go with for a winter tire. Our suburu has had them since 2013 (short commute) during winters. They are amazing on ice, deep snow, and the dreaded end of driveway burm from the plow. The car version (general altimax arctic) might not be apples to apples compound, load, etc., but the tread looks very similar. They have wore very well considering I forgot to take them off one summer. Maybe not as soft as a blizzak, not sure, but the open tread design really allowed that suburu to blast thru drifts. Also performed great during break up when road very wet and pooling h20.
  8. Nov 13, 2018 at 8:32 PM
    #48
    sfr4dr
    Truckee/Tahoe CA
    They do make Altimax Artics in truck sizes. I have them in 265/75r16. Maybe they discontinued them though. I have Grabber Artics studded on my work truck and they rip as well.
    NickleCityTaco likes this.
  9. Nov 13, 2018 at 8:36 PM
    #49
    SpeySquatch
    2016 TRD OR DCSB
    By MT Hood, Oregon?
  10. Nov 14, 2018 at 7:38 AM
    #50
    rowbaretow
    rowbaretow Well-Known Member
    Robert
    2018 Cement TRD Off-Road Double Cab Long Bed
    265/75/R16 BFG KO2
    Yes this was on Mt. Hood a few miles away from the White River/NF48.
    I would like to see a few stock Tacoma's, or of similar design, with all different tires do a real world tire comparison test. Each truck climb the same hill, take a sharp corner, perform a hard break going 20mph. Usually these tests are done with different rigs. I want to see the real results.
    Hiker trash and DavesTaco68 like this.
  11. Nov 14, 2018 at 8:28 AM
    #51
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    Yeah but you are assuming people care about performance. As far as I can tell they just want monster truck tires because they look cool. Who cares if they rub anytime the truck isn't going straight on a flat surface.
  12. Nov 14, 2018 at 8:31 AM
    #52
    SpeySquatch
    2016 TRD OR DCSB
    o_O
  13. Nov 14, 2018 at 8:32 AM
    #53
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    I agree completely and thanks for the fine review. I'm an archaeologist and have had 8 4WD vehicles since 1967, including 6 Toyota trucks and used them in Oregon, California, including the Colorado Desert, Arizona, New Mexico, Baja California (Norte and Sur), and Chihuahua. I've used many brands and types of tires on those vehicles, and while you are correct about a P or C rated tire that may be more appropriate for Tacomas, I've lost too many tire sidewalls on the P and C rated tires in rocky conditions, not to mention nail flats. So, while my E rated KO2s are stiff, I've never blown a sidewall on them or the earlier KOs, nor had them fail in any other manner. So, I'll take the rougher ride for not having to change a tire on a 4WD low range road on a grade. That is the decision I've made.
    DavesTaco68 and COOutlaw[QUOTED] like this.
  14. Nov 14, 2018 at 8:38 AM
    #54
    shackley
    I looked at those for the Pro, but they only have 17s, and I didn't want to change out the stock Pro wheels. Discount said they were easy to balance and they get few returns.
    Mtn Mike[QUOTED] likes this.
  15. Nov 14, 2018 at 8:40 AM
    #55
    shackley
    The chalk test unloaded on my 18 Pro indicated that 30 lbs on both front and rear wore evenly. I put 33 in them when I'm loaded for camping.
  16. Nov 14, 2018 at 9:03 AM
    #56
    COOutlaw
    COOutlaw Old Guy-fan of: Shotguns,Birddogs,Flyrods,Whiskey.
    Colorado
    2019 DCLB TRD OR CEMENT
    None yet
    Exactly This. For off road use, the E rated are absolutely the ticket, especially in desert flora. While living in AZ it was my choice as well and would not have even considered anything else. In fact, the original vision and testing of the BFG AT's was to produce a "Baja Proven" tire. They succeeded for sure. The reason I actually quantified "usage" as a consideration was an attempt to enlighten folks that most all tires excel at their designed purpose...winter specific use tires vary in design from all terrain tires, and although most all terrains will suffice in performance as a winter use medium (and have been redesigned and upgraded to meet greater multi use purposes over the years), they are still not the optimum choice for that specific usage. Nor would a winter snow specific tire be the optimum choice for traversing rocky canyon, boulder strewn, trails. Life is full of compromises, making an educated choice based on "majority of ones needs" is obviously the reasonable alternative to constantly changing tires in accordance with the activities at hand. As long as our expectations are adjusted accordingly and we don't assume we can pound nails with a screwdriver.
  17. Nov 14, 2018 at 9:48 AM
    #57
    Hemlocktherm78
    ok
    when did u buy the arctics for truck?
  18. Nov 14, 2018 at 9:54 AM
    #58
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I ran them exclusively for years living at 9200 feet in Colorado and they were perfectly fine. I have also ran Michelin LTX AT2s and were great as well, we average 186" of snow each year
    Winter Tire experience is heavily subjective since we have no idea how a similar tire would perform in the EXACT same situation. some people have bad experiences and others have good, it all comes down to driving styles, road conditions etc. There are too many variables to determine if X tire is better than Y. Only closed courses and official comparisons give us some idea.
  19. Nov 14, 2018 at 10:03 AM
    #59
    here4cake
    here4cake Well-Known Member
    KO2 is a fantastic tire for the snow we get in BC. From the wet snow on the coast, to the dry snow in the interior, the KO2s have never left me down. I've done 100kph through fresh snow on the Coquihalla while all other traffic was barely doing 30, I've plowed knee-deep snow on trails, and have driven up&down a million slick hills - never any issues.
    DavesTaco68[QUOTED] likes this.
  20. Nov 14, 2018 at 10:29 AM
    #60
    dspec
    dspec Well-Known Member
    How are the AT3W's so far in daily driving and in cold wet conditions? I'm curious how they hold up in snow too. Really conflicted with KO2's vs AT3W's at this point.
