BFG AT KO2 in the snow
Discussion in '3rd Gen. Tacomas (2016-2023)' started by joejm14, Nov 12, 2018.
  1. Nov 15, 2018 at 3:56 AM
    #81
    Tarzan13
    Tarzan13 Well-Known Member
    Keith
    Longmont, CO
    2015 DC TRD Off-road
    In my experience with the KO2's they were great in Moab, they were great for snowy/icy 39 mile commutes in the CO front range, now I am back in Pittsburgh. It rains a lot here, and my KO2's break loose pulling out from stop signs, or when I am driving at slow speeds and hit the gas and the truck down shifts I ll break traction as well. They really don't seem to hook up on wet pavement. Even when they were new in CO I noticed in the rain that I would break traction starting out. Not quite sure how a snow rated all terrain that grips rocks and snow covered roads has trouble hooking up on wet asphalt?
    I am considering Cooper's AT3 4S for my next tire.
  2. Nov 15, 2018 at 4:14 AM
    #82
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    Maybe we can't have everything.
  3. Nov 15, 2018 at 4:34 AM
    #83
    Tarzan13
    Keith
    Longmont, CO
    I didn’t ask for mud performance lol
  4. Nov 15, 2018 at 5:54 AM
    #84
    RetiredSCPO
    RetiredSCPO Well-Known Member
    Will
    Seven Cities
    2017 Tacom TRD Off Road Double Cab-Silver
    Stock
    Not siped enough and compound is probably not optimal, not a great tire for snow
  5. Nov 15, 2018 at 6:09 AM
    #85
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Probably because generally speaking it's true. All things being equal, a narrower tire will outperform a wider one in most winter conditions. The exception is on hard pack or solid ice, where (again, all things being equal) a wider tire will do better because of the wider contact patch.
    doublethebass likes this.
  6. Nov 15, 2018 at 7:33 AM
    #86
    phsycle
    phsycle Well-Known Member
    CA
    Ok, I give you in certain situations, that is true. However, in 99% of the time, it simply doesn't matter. ESPECIALLY if we're talking about such insignificant difference in width. 255 vs 265? That's 10mm! My (anecdotal) experience. 265 tires performed better than 235's. Didn't track/wander on slushy roads and stopped and handled better as well. Wider tires had better lateral grip.
  7. Nov 15, 2018 at 7:37 AM
    #87
    Noelie84
    Noel
    Wales, Maine
    Yeah, 10mm won't make much of a difference. However, going from a 265 to a 235 would, if you used identical tires of the same condition, inflation, etc.
    I'd be willing to bet that you opted for a more aggressive tire when you upsized as well, though, right? Because a more aggressive tread will make a bigger difference than a narrower or wider tire.
  8. Nov 15, 2018 at 7:38 AM
    #88
    Jeff@ExE
    Jeff@ExE Well-Known Member
    Jeff
    2016 Toyota Tacoma
    A Lot
    Depending on conditions of the snow and tire pressure our K02’s have rocked in the snow. No complaints whatsoever.
    2016Tacoman and DavesTaco68 like this.
  9. Nov 15, 2018 at 7:41 AM
    #89
    Sn4rlax
    Sn4rlax Well-Known Member
    2016 Red Taco 4x4 V6
    KO2 - E rated, have nothing in my bed. No issues in the rain at all, I switched from tires that did. In the snow today, even in 2WD did ok, in 4HI I had no slippage unless I tried to have it slip. Then again, mine are brand new.
    DavesTaco68 likes this.
  10. Nov 15, 2018 at 7:44 AM
    #90
    phsycle
    CA
    Actually, no, they were the same tires, same brand/model (BFG KO). Driving my usual commute route and going up to my favorite ski resort. Really didn't make any difference, and again, an advantage to the wider tire. Diameter was the same (265/75/16 and 235/85/16). Caveat, this was back to back winter SEASONS, not tested within the same season. Only had the 235's for a few months the first season before getting rid of them for 265's. So tire wear wasn't a factor.
  11. Nov 15, 2018 at 7:50 AM
    #91
    Noelie84
    Noel
    Wales, Maine
    Both LT, obviously. Did you keep them at the same PSI, or go by the chalk test?
    Dirtridercrf250 likes this.
  12. Nov 15, 2018 at 7:57 AM
    #92
    phsycle
    CA
    No, didn't get that specific/anal. I ran them both around 32 or so. This was a few years ago. That's the best I remember. Both KO's were Severe Weather rated as well. Some of those E-load range weren't "snowflake" rated. I was expecting a compromise in performance when I went to 265's, but never happened.
  13. Nov 15, 2018 at 9:09 AM
    #93
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Do the chalk test it's accurate! You need to set the proper pressure and you'll be good. I promise slap some chalk on those bad boys.
  14. Nov 15, 2018 at 9:16 AM
    #94
    Noelie84
    Noel
    Wales, Maine
    Doesn't sound like he's having any traction problems as it is, but may run into some irregular wear in the future.
  15. Nov 15, 2018 at 9:49 AM
    #95
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    I will answer tomorrow. YAHOOOO our first snow of the season:dancingbacon::broccoli::jellydance::kona::woot::yay::yes:
  16. Nov 15, 2018 at 10:03 AM
    #96
    phsycle
    CA
    Again, the switch happened several years ago. No irregular wear noticed.
  17. Nov 16, 2018 at 2:48 PM
    #97
    porsmork
    porsmork Member
    Got to test my ko2s with 5k miles on them yesterday around NYC, honestly thought they were great. I'm used to Blizzaks on my AWD hatchbacks so I know what good snow traction feels like. I had no issues starting from a stop on a steep incline, other cars around me were spinning their tires and couldn't get out of their own way.
    I have broken traction a few times in the wet in a turn, but that was my fault. Having a manual transmission might make a difference in how I experience the tires too.
  18. Nov 16, 2018 at 5:59 PM
    #98
    Rephil
    Rephil Well-Known Member
    Phoenix
    I ran KO2's for about 40k Miles. I beat them up and they never failed. However, I have now done quite a few miles on General AT/X's and can say without a doubt they are better tires, especially in wet traction conditions.
  19. Jul 20, 2021 at 9:43 PM
    #99
    Kingair84
    Kingair84 Well-Known Member
    Wisconsin
    2016 Double Cab TRD Off Road 6 speed MT
    Rad Industries skid plate, trd pro grill, rigid DOT Fogs
    Honestly my general grabber AT2 tires have been the absolute best tire I’ve ever owned I’m on my 3rd set now and get excellent all around performance on them up to 50k miles. Hence the reason I keep buying them.
  20. Oct 26, 2023 at 8:43 AM
    #100
    Johnrc
    Johnrc Member
    2004 Tacoma
    2.5" lift, Steel all over, Upgraded speakers and sub in back, Custom Aluminum Camper
    Blown away by the KO2s in snow and ice. I had some Nitto A/T tires last winter and what I am able to do in 2WD is pretty unreal
    Junkhead likes this.
