BFG AT size for 17" Sport Rims
Discussion in 'Wheels & Tires' started by Rhody76, Apr 5, 2011.
  1. Apr 5, 2011 at 5:13 PM
    Rhody76
    Rhody76 [OP] Well-Known Member
    Rhode Island
    2011 SR5 DCLB 4x4
    Rear leaf TSB, Bilstein 5100s set at 1.75",1" blocks, UWS low profile toolbox in black, husky liners, tint, LED interior and reverse lights, yellow fogs
    Hey guys I'm about to buy new tires to go on my stock sport rims. Ive already decided to go with the BFG AT's but I'm a bit confused about the size. Do I need 265/65/17 or 265/70/17? I cant find the 265/75/17's locally. If I go with the 70's will one of the big name tire stores install them since they're not the stock size? Thanks in advance
  2. Apr 5, 2011 at 5:20 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Yeah 265 75 doesnt exist.
    The shop will install whatever you tell them to.
    If you plan on ever doing a leveling kit or lift consider waiting because you will be buying bigger tires, again.
  3. Apr 5, 2011 at 5:20 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    265/70/17 is only one size up from stock. (~32"). Most tire shops will install them without any problems.
  4. Apr 5, 2011 at 5:27 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    I have an 11 TRD sport and got Goodyear Dura Tracs size is LT265/70R17
    You'll want the 265/70R17 size. The LT stands for "Light Truck Tire" stiffer sidewall and higher load capacity compared to non LT tires. Tires also have different load ratings C,D, etc. which further determines load cap. and amount of sidewall strength. But in your case 265/70R17 is what your probably looking for.
  5. Apr 5, 2011 at 5:30 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2. They'll try to talk you out of it and tell you every negative thing about oversized tires but they should install them for you since you're the one paying the bill.
  6. Apr 5, 2011 at 5:37 PM
    That Dude Tim
    Elyria, OH
    If you happen to get a flat though, get it fixed asap b/c having a different size tire on the other side of a 4x4 truck can mess up the differential. 265/70R17 is different from 265/65R17(stock spare). You can either change the spare also, switch to the spare during a flat and drive none highway speeds for only a few miles, or call a tow truck, or or fill up yourself if you have on-board-air. And yes they should mount them no problem.
  7. Apr 5, 2011 at 6:02 PM
    macgyver
    Brad
    Canton, GA
    It shouldn't matter with an open diff. The differential allows each side of the axle to spin at different rates. Think about when you go around a corner. Putting a smaller tire on one side is the same. Although it's not recommended to drive for an extended period of time, it won't hurt anything.
  8. Apr 5, 2011 at 7:17 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    Cool thanks. I already have 5100's up front set at 1.75" and rear leaf TSB and I dont plan to go any bigger
  9. Apr 5, 2011 at 7:25 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    As for the BFG AT's, I went through two sets and my 2000 Tacoma reg cab and got roughly 50K miles out of both and never got a flat. And they were used on some pretty rough terrain (constructions sites, off roading).
    Are there different load ranges and number of plles for the BF ATs? The others were just purchased off the rack at BJ's so I dont think they were a specialty tire. I think they were 6 ply
  10. Apr 5, 2011 at 7:27 PM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    with your lift i would go 275 70 17 the largest without big problems. See my gallery for pics of them on a 2/1" lift.
