BFG K02 285/70/17 on TRD Pro Wheels
Discussion in 'Wheels & Tires' started by justhaag, Dec 9, 2017.
  1. Dec 9, 2017 at 9:27 AM
    justhaag
    justhaag [OP] Well-Known Member
    Mesa, AZ
    2017 Quiksand Tacoma TRD Off-road 4x4
    Hey guys!
    Still fairly new to things and I'm looking at replacing my current stock wheels and tires on my 2017 TRD OR. I currently have a 2.5" lift with bilstein 5100's and OME coils in the front and I'v got an Icon AAL and shocks in the back. Would I have any issues with the TRD Pro wheels if i were to go up to the BFG K02 285/70/17?
  2. Dec 9, 2017 at 9:48 AM
    scs_vuth
    scs_vuth SCS sales rep
    Vuth
    Bay Area, Ca
    2013 Tacoma - 2020 GX460 - 2022 Jeep Gladiator EcoDiesel
    Your 285 wide tire might rub on the upper control arm. You will need to run at least a 1.25" spacer with the TRD Pro wheel to clear.
    Vuth
  3. Dec 9, 2017 at 11:51 AM
    justhaag
    Mesa, AZ
  4. Dec 10, 2017 at 9:02 PM
    not0ny
    not0ny Well-Known Member
    2017 MGM TRD SPORT DCSB 4X4
    Bilstein 6112/5160 JBA UCA
    You shouldn't rub on the uca. The trd pro sema wheels are 17x7 off set 0 backspace 4.5 should push it away from the control arms etc. Theres a thread about people with the trd pro sema wheels and 285/70/17 without spacers. If you run spacers and your 2 inch lift you will rub on the fender more likely.
  5. Dec 11, 2017 at 12:09 AM
    scs_vuth
    Vuth
    Bay Area, Ca
    I've ran spacers before with no issues. Many people run them with little to no issue. If you do get them, get the well known quality brand hub centric application.
  6. Dec 18, 2017 at 7:07 AM
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    My buddy is running 285 KO2’s on his 17’ Pro and isn’t rubbing the frame or control arms. We did a cab mount chop preemptively and we had to trim some of the fender but now it’s solid with no rubbing. I mention the frame and UCA because that seems to be were 285’s run without spacers or decreased backspacing (which I believe the Pro wheels have)
    Kerm1967 likes this.
