BFG K02's or Falken WildPeak AT3W ?????
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LENPro, Dec 19, 2019.
  1. Dec 19, 2019 at 10:47 AM
    LENPro
    LENPro [OP] Well-Known Member
    2019 Tacoma TRD Pro
    So I have a 2019 TRD Pro and am looking for a more aggressive look.
    I don't want to F with the suspension. I have done the research on this forum which I am grateful for.
    I'm torn between the BFG K02's and the Falken WildPeak AT3W's......
    I will be doing some off-roading as well.
    Gonna go with 265/75/16.
  2. Dec 19, 2019 at 10:50 AM
    trackdaybro
    trackdaybro Well-Known Member
    Wildpeaks since you can get them in P load. Save yourself some mpgs and ride quality.
    Get the KO2s if you’re putting your tires through a lot of trails prone to damaging tires. I think they only come in E load for that size.
  3. Dec 19, 2019 at 10:51 AM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    Falkens. :thumbsup:
    Superdave1.0 likes this.
  4. Dec 19, 2019 at 10:51 AM
    YMMPRO
    YMMPRO Well-Known Member
    Northern Alberta, Canada
    2018 Super White Tacoma Pro
    TRD Intake / Falken Wildpeak AT3W
    Well i don't care about looking aggressive, but i went with the Falken and they work well for my requiremnts They are also quite good on the highway IMHO.
  5. Dec 19, 2019 at 10:52 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Falkens, I am getting some mounted on my wifes GX and they seem to be reviewed better.
    edgarcg2 and Superdave1.0 like this.
  6. Dec 19, 2019 at 10:53 AM
    Madtown
    Madtown Well-Known Member
    Eric
    Madison,WI
    Former 3G Tacoma owner
    The local DTD recommends not getting Falken WP due to vibration issues. I would stay away from them. I hated mine from day one. Trash tire.
    MannyS, Chasespeed and Jpalafox like this.
  7. Dec 19, 2019 at 11:01 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    1 set of wild peak , 9 sets of bfg at's. I have never had a bfg get a flat or blowout. Bfg last a long time on a light truck, however the sidewalls seem to dry crack prematurely. Ive got 2 sets of ko2 right no. 1 on 1st Tacoma the other on my f350. The only complaint is the ko2 needs alot of weight to balance. Ive never had this issue with the og bfg at or the ko. The 305s needed close to 12oz on the worst tire . 285s just over 8oz. Only 3k miles on the wild peaks, about half the wieght to balance though
  8. Dec 19, 2019 at 11:14 AM
    Sosk
    Sosk Well-Known Member
    Evan
    Vancouver Canada
    2018 TRD Sport
    Grabber ATX over KO2.
    Ran the KO2's for two years and slid all over in the rain/needed 4WD in the snow to go anywhere.
    Been running the grabbers for a while now and don't slide in the wet. and didn't need 4WD in the snow going up to a local ski hill the other day.
    MannyS and Norsemanvike like this.
  9. Dec 19, 2019 at 11:14 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    If you're serious about just wanting a more "aggressive look", just find whatever tire you like the look of and get that.
    But if you plan to go offroading with your TRD Pro (for the love of god I hope so), ditch the idea of P or C rated tires and stick to E rated all terrains. They perform FAR better in the dirt, are less prone to flats, and fair better when aired down (stiffer sidewall means they better support the weight with less air, etc...), and all terrains are still a great tire for daily driving (I've done it for ~15 years on my KOs).
    I guess you could call me a BFG fanboi. I've had BFGs for nearly 25 years and will likely never buy another brand. I've NEVER gotten a flat with my E rated BFGs in almost 20 years. Last flat I got was from some really old 32x11.50r15" BFG M/Ts (predating the KMs) on my 1st gen 4Runner. I've run nothing but E tires, and for the first several years I had my Taco, it was primarily a daily driver. I'd rather take a 1 or 2mpg hit in MPGs than tear a sidewall on the trail.
    Another benefit to the BFGs is that they typically don't require a lot of weight to balance them. I've seen C rated tires with more weights than my E's.
    Yes, you might take a slight hit in MPGs (likely only 1 mpg), but did you buy that TRD Pro to drive to the grocery store or go off-roading with?
    Gs4x46mt, AKGSD, DavesTaco68 and 2 others like this.
  10. Dec 19, 2019 at 11:23 AM
    dondecontente
    dondecontente Member
    Seattle WA
    2017 DCSB
    If you drive in the snow a lot I would stay away from the Wildpeaks, went romping around in the snow on thanksgiving and took them off that Saturday for some Duratracs.
    DavesTaco68 likes this.
  11. Dec 19, 2019 at 11:26 AM
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    You're talking about a performance AT tire in the BFG and a budget AT tire in the Falken. My buddy is manager at a Discount Tire and doesn't have any real good things to say about any Falken unless you are looking for cheaper tires. If you want to save a few bucks, get the cheaper budget tire otherwise, stick with the better and more reputable brand IMO. Just be careful here in the 3rd gen section where apparently the Falken Wildpeak AT3 are the best tires ever created since the dawn of tires themselves. Which is laughable.
  12. Dec 19, 2019 at 11:27 AM
    GreyBaldTaco
    2019 F150 5.0
    Thats odd, the lexus guys are big on them too.
    95tojo likes this.
  13. Dec 19, 2019 at 11:29 AM
    SoCal TacoOR
    SoCal TacoOR Life at Redline
    Kommie Kali
    17 DCSB TRD OR Super White
    Just did this...Wildpeaks. America’s Tire had no issues balancing. They are running smooth and true.
    TXpro4X4 and Superdave1.0 like this.
  14. Dec 19, 2019 at 11:30 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Hey my wife has a GX too! Awesome trucks.
    GreyBaldTaco[QUOTED] likes this.
  15. Dec 19, 2019 at 11:31 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    i like the wildpeaks more than K02's..
    performed excellent in the sand
    BassAckwards and edgarcg2 like this.
  16. Dec 19, 2019 at 11:32 AM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    If you drive in snow or on ice I would recommend Wildpeaks.
    No issues with a smooth and quiet ride for 20,000 miles for me.
    They are wearing evenly with a lot of tread remaining.
    24B0699F-9876-42A8-96AC-8C46CFD1A0DE.jpg F9762938-BF3D-40C3-A383-133F8F61847B.jpg 03B842A8-7591-435B-8791-4E82E7D86F65.jpg
    AKGSD, TnTuna, IEsurfer and 2 others like this.
  17. Dec 19, 2019 at 11:33 AM
    taco king
    taco king Active Member
    Grand marais, MN
    2015 trd sport
    Ome, 887s, Dakar, lruca, rims, tires, brake lines, rear view mirror, dynamite, prinsu, lots of small stuff
    I've ran both in that size and prefer the falkens. I try and get off road a few times a month and haven't noticed any decrease in perfomance in the p rated tires. Falkens also are a lot less noisy.
    AKGSD and GreyBaldTaco like this.
  18. Dec 19, 2019 at 11:34 AM
    GreyBaldTaco
    2019 F150 5.0
    They are very nice and reliable. And share a ton of common tools, fluids, maintenance schedules etc.
  19. Dec 19, 2019 at 11:35 AM
    Freegolf
    Denver
    They are just happy for the price of the tires because the price they paid on the Lex.
    Comato$e likes this.
  20. Dec 19, 2019 at 11:36 AM
    GreyBaldTaco
    2019 F150 5.0
    We picked up my wifes lightly used lexus for cheaper than a lightly used 4runner.
