BFG KM3
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BPCLFD, Jun 12, 2019.
  1. Jun 12, 2019 at 12:35 PM
    BPCLFD
    BPCLFD [OP] Member
    Brian
    2017 Tacoma
    just replaced my OEM 265/70/16 with KM3 265/75/16 what is everyone else running on road PSI?
    suprdav59 likes this.
  2. Jun 12, 2019 at 12:38 PM
    hoch
    hoch Well-Known Member
    Desert
    18 DCSB OR 6MT
    My basic rule of thumb with LT tires. Start at 32 and adjust from there.
    SpeySquatch likes this.
  3. Jun 12, 2019 at 12:49 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    I'm running 40 in the same size e rated ko2s.
    lpfe42 likes this.
  4. Jun 12, 2019 at 12:51 PM
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    Just sell em now and go to 255/85-16. I went to 265/75 for less than a year before I went to 255/85. Only partially joking, but yea I run 35-40psi
  5. Jun 12, 2019 at 12:58 PM
    BPCLFD
    BPCLFD [OP] Member
    Brian
    2017 Tacoma
    ok the side wall with 80psi have me 2nd guessing myself thanks for the info
  6. Jun 12, 2019 at 12:59 PM
    BPCLFD
    BPCLFD [OP] Member
    Brian
    2017 Tacoma
    Are you running stock suspension with the 255/85-16s
  7. Jun 12, 2019 at 1:18 PM
    16Tacos
    Zach
    Boston
    No I have the 2" OME lift but I think it'd be fine on stock (depending on your wheels) if you remove the front mudflaps and max out your caster to 2.3-2.5, I have stock UCAs so that's about the max I can get from them.
  8. Jun 12, 2019 at 1:50 PM
    BPCLFD
    BPCLFD [OP] Member
    Brian
    2017 Tacoma
    I will probably go with something bigger down the road planning on upgrading the suspension down the road also
  9. Jun 12, 2019 at 1:58 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    that's max rated psi on the sidewall, I found 32psi is a sweet spot atleast for me with E rated falkens
  10. Jun 12, 2019 at 2:04 PM
    BPCLFD
    BPCLFD [OP] Member
    Brian
    2017 Tacoma
  11. Jun 12, 2019 at 2:08 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    I run 37psi
  12. Jun 12, 2019 at 2:08 PM
    BPCLFD
    BPCLFD [OP] Member
    Brian
    2017 Tacoma
    :thumbsup: Love that Color PRO
    Flash1034 likes this.
  13. Jun 12, 2019 at 2:11 PM
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    Don't fill it anywhere near that! lol that's the max pressure before the tire explodes. I run my E-load coopers at 28psi all around, anything higher than 30 and it feels like you're sitting on a wooden roller coaster. Very bumpy ride.
    If you want to find the pressure that you SHOULD have them at (which is specific to your exact vehicle) then do the chalk test.
    BlackGT99 likes this.
  14. Jun 12, 2019 at 2:14 PM
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    That isn't the max before ethe tires explode. That is the minimum psi at Max load. Burst pressure is around 200psi, even higher on E rated lt tires.
  15. Jun 12, 2019 at 2:14 PM
    BPCLFD
    BPCLFD [OP] Member
    Brian
    2017 Tacoma
    I wouldn't go to 80
    i was thinking in the 40psi range I was just getting a group pic of what everyone else is running to see if I was in the right starting area.
  16. Jun 12, 2019 at 2:16 PM
    BPCLFD
    BPCLFD [OP] Member
    Brian
    2017 Tacoma
    Yes I just didn't want to get into that thanks tho
  17. Jun 12, 2019 at 2:16 PM
    BlackGT99
    BlackGT99 Well-Known Member
    Noel
    2019 VooDoo Blue Tacoma TRD Pro
    This is correct.
  18. Jun 12, 2019 at 2:19 PM
    BPCLFD
    BPCLFD [OP] Member
    Brian
    2017 Tacoma
    no worries guys Im not going to run or go over 45 to start Its all good
  19. Jun 12, 2019 at 2:19 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I start at 35. The next time you drive a dusty road you will see how much of the tire is hitting the road. You want the entire tread surface to be contacting the road evenly. It's usually 30-36 psi on e loads.
    DustStorm4x4 likes this.
  20. Jun 12, 2019 at 2:23 PM
    BPCLFD
    BPCLFD [OP] Member
    Brian
    2017 Tacoma
    Ok embarking on a roughly 5200 mile trip out west in a few days about 2400 of that is off road so I will have it to my liking on and off road after a few days on the trip thanks
