BFG KO2 265/75R16 on 2011 4x4 Double Cab?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Offroad2011TRD, May 11, 2022.
  1. May 11, 2022 at 6:07 AM
    Offroad2011TRD
    Offroad2011TRD [OP] New Member
    2011 White TRD Off-road 4x4 Double cab
    What’s up guys. Been thinking about sizing up from my Firestone Destination 265/70R16’s to some BF Goodrich 265/75R16’s on my 2011 Tacoma double cab 4WD, but I’m concerned about rubbing as I’ve never sized up to this size in my Tacoma before. Any recommendations or has anyone else put this size tire on their double cab 4x4 tacoma?
    Also curious as to if your fuel economy was worse, or if there was really no change?
    Thanks!
  2. May 11, 2022 at 7:03 AM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    I say do it! Shouldn't have any issues rubbing, if you do it will only be on your mudflap up front. Don't get LT rated tires, the weight is what really kills your mpgs.
  3. May 11, 2022 at 7:12 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    You will be just fine with 265/75/R16's. That's only Ø1" larger than your current tire. Yes, you might lose some mpg's, but I doubt you would really notice. Also take into account your speedo & odo will be slightly off (unless you get them recalibrated, no real need to though).
  4. May 11, 2022 at 7:15 AM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    When I had 245/75/16 my speedo was 3mph off and In my case when I sized up to 265/70/17 from 245/75/16 my speedometer actually went back to accurate.
  5. May 11, 2022 at 7:58 AM
    mcgov303
    mcgov303 I'd rather be in the mountains
    Denver
    2015 BRM TRD Off Road 4x4
    Toytec 3" w/ AAL, Leer 100R, 16" SCS F5s, 265/75 KO2s, pro grille, cmc
    KO2s in that size only come in E load rating, he's gonna def lose a mpg or 3
    Musubi3, tacoman45 and Hobbs like this.
  6. May 11, 2022 at 11:52 AM
    MikeDeason
    MikeDeason Well-Known Member
    Michelin Defender LTX MS
  7. May 11, 2022 at 12:20 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    This is correct. A good way to avoid this is to install Goodyear Duratracs in Load C 265 75R16
  8. May 11, 2022 at 4:30 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Ouch, I foolishly went with E load Toyo OC ATIII's and lost about 2.5
  9. May 11, 2022 at 4:36 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Many years ago, I was able to get a P rated BFG in that size. I noticed no difference in milage. My current set are LT and I lost 1-2 mpg. Currently on my 3rd set of BFG ATs on my Taco.
