Bfg ko2 265/75r26
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vini, May 25, 2021.
  1. May 25, 2021 at 12:34 PM
    Vini
    Vini [OP] New Member
    Vinicius
    2016 Tacoma Trd
    Hey guys, someone know what pressure I would use on bfg ko2 A/T 266/75r16?
    The tires shop guy told me that I would use 80 psi but it sounds insane to me.
    I’m using 50 psi at this moment...
  2. May 25, 2021 at 12:37 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    80?! Holy shit. Id run then between 34 and 40 if it were my truck. Whats Toyota say on the inside door sticker?
    Thatbassguy, 71tattooguy and Junkhead like this.
  3. May 25, 2021 at 12:40 PM
    ExplorHer
    ExplorHer Question Authority
    Near Pittsburgh
    2016 4cyl, 5MT, 4x4, 2 seats, dents, & rust
    Could put some chalk on them and test to see what pressure will make them wear evenly.
    Mark77 likes this.
  4. May 25, 2021 at 12:43 PM
    pca501212
    pca501212 Well-Known Member
    Alex
    Houston
    I have 265/75/16 KO2's and i run it at 35 PSI. 20k miles in and rotation every 5k, I havent had any problem with them so far.
    rmreid20, BT17 and Mark77 like this.
  5. May 25, 2021 at 12:44 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    35-37 psi.
    80? Haha! Wow...
    71tattooguy, BT17 and Mark77 like this.
  6. May 25, 2021 at 12:45 PM
    JWags81
    JWags81 Well-Known Member
    Iowa
    2017 Tacoma SR DCSB
  7. May 25, 2021 at 12:45 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Inside door sticker doesn’t apply since these are E loads and 1” bigger than stock.
    gsubioguy likes this.
  8. May 25, 2021 at 1:01 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Those tires are designed to be used on 3/4 and 1 ton trucks that weigh around 7000 lbs empty with GVWR's of 10,000+ lbs. Your Tacoma only weighs around 4000 lbs empty, no more than about 5500 fully loaded. Even the guys driving 3/4 ton trucks that weigh double what your Tacoma weighs only run 50-60 PSI unloaded. The 80 PSI is what they use when loaded to full capacity. The wheels on your Tacoma are only rated to stay together to around 60 PSI.
    Actually the number on the door sticker is a good place to start. Since they aren't designed for a Tacoma there are no hard rules for what is best. You just have to experiment. But I found around 30-35 PSI worked best for me. The number on the door called for 29 PSI front and 32 PSI rear, but that was for P rated tires and no load. The number on the tires (44 PSI) was for when loaded heavy.
    JWags81 and Mark77 like this.
  9. May 25, 2021 at 3:45 PM
    TacoedBars
    TacoedBars TacoedBars
    Sacramento
    16 TRD 4x4 OR
    Did they just fill it to the max capacity the tire says? I thought it was 33-37 Psi all around normally. I wonder how it rides with that PSI?
    Junkhead likes this.
  10. May 25, 2021 at 3:47 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I’m sure it rides pretty shitty even at 50 psi.
  11. May 25, 2021 at 3:50 PM
    TacoedBars
    Sacramento
    16 TRD 4x4 OR
    Tempted to air it that high and see first hand lol
    Junkhead[QUOTED] likes this.
  12. May 25, 2021 at 3:51 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Haha!
    I had e load KO2s and they were like bricks at 35 psi. Was so happy when switched to C load, what a difference.
    71tattooguy likes this.
  13. May 25, 2021 at 5:52 PM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Maybe he meant 80 psi for a 26 in wheel.
    "Bfg ko2 265/75r26"
    :bananadance::bananadance:
    gsubioguy and Junkhead like this.
  14. Jun 12, 2021 at 12:50 AM
    Scarab
    Scarab Well-Known Member
    2017 White Tacoma TRD Pro
    I just got 265/75/16 KO2s installed and they put in 34psi cold.
  15. Jun 12, 2021 at 3:38 AM
    2020_TRD_OR
    2020_TRD_OR Well-Known Member
    Pennsylvania
    2020 Cement Tacoma TRD Off Road
    Bilstein 6100s & 5160s Wheeler's Super Bump Stops Wheeler's AAL SPC UCAs Sway Bar Relocation Kit RCI Front Skid Plate
    Definitely came for the r26 tires
    turbosnail, Tyler7544 and gsubioguy like this.
  16. Jun 12, 2021 at 3:40 AM
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    35 cold is a good medium.
  17. Jun 12, 2021 at 4:32 AM
    Xero
    Xero Well-Known Member
    18 Tacoma TRD Off Road, 22 4R, 08 4R
    18 Tacoma TRD off road OME BP51 front Fox 2.0 Resi rear OME Dakar Meduim Yoko G006 325/75r16 Black Rhino stadium wheels Cali raised ditch light brackets Baja Designs S1 pods Baja Designs Squadron SAE fogs Prinsu Cab rack TRD Pro grille AVS rain guards Backwoods adventure mods hi-lite bumper BL Apex 12k winch Dobinsons 4x4 snorkel Sy-clone prefilter ARB rear diff breather relocation RRW rock sliders RCI full skids At the helm bed stiffeners lil b LCA skids Warfab Phantom rear bumper Warfab tie rod sleeves C4 fender liners Dirt king UCA Duro bump stops
    I run mine at 35 psi.
  18. Jun 12, 2021 at 6:16 AM
    NinGee87
    NinGee87 Well-Known Member
    AZ
    19 Cement DCSB TRD Sport 4x4
    I run 38-40 psi. Couldn't imagine what it feels like at 50
  19. Jun 12, 2021 at 6:19 AM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    What does the sidewall say?
  20. Jun 12, 2021 at 6:31 AM
    NinGee87
    AZ
    Mine says 80psi. I noticed when I was airing my tires up one time. I thought it was insane, but as a prior comment started it makes sense if these toes are also to be ran on bigger trucks
    gsubioguy[QUOTED] likes this.
