BFG KO2 on stock TRD Sport
Discussion in 'Wheels & Tires' started by adrian191, Jun 16, 2021.
  1. Jun 16, 2021 at 8:23 AM
    adrian191
    adrian191 [OP] Active Member
    Adrian
    New Jersey
    2016 Tacoma TRD Sport
    So I have a 2016 TRD Sport. My current tire size is 265/65/17. I want to get the KO2s but I’m a little confused about the sizes. I see people are putting on 265/70 or 265/75. I’m keeping the truck stock height and I’m not sure what size tire to get. Any recommendations as to which size is the most functional. Most of my driving is done on the highway. I also see that 265/75 is very common on the 16inch wheel but my wheels are 17s. Can someone help me out. Pictures would be appreciated too!! TIA
  2. Jun 16, 2021 at 8:56 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Look for C load in 265 70 17, light weight, looks good.
  3. Jun 16, 2021 at 9:09 AM
    kd2021
    kd2021 Member
    Kevin
    Vancouver, BC
    2021 Cement DCSB TRD offroad
    I have 265/70/16 on a stock off road. My understanding was that I could put on 75's without any rubbing.
    adrian191[OP] likes this.
  4. Jun 16, 2021 at 9:14 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    A 265/75r 16 ia the equivelant to a 265/70r 17.
    The larger rim of the 17" wheel makes up the sidewall height difference in the tire.
    skeletron, adrian191[OP] and kd2021 like this.
  5. Jun 16, 2021 at 10:13 AM
    adrian191
    Adrian
    New Jersey
    This is exactly what I wanted. Thanks man. Now the questions is what load? C or E? From my understanding a E load drives harsher/stiffer?
  6. Jun 16, 2021 at 10:22 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Yeah you are missing out on the wheel size bit;
    https://www.tacomaworld.com/threads/how-to-understand-metric-tire-sizes.23715/
    265 - that's the width in mm (eh!).
    65 - that's the sidewall ratio - 65% of the width 265mm = 172.25mm.
    R17 - that's your wheel size.
    Play around with the Calc and see; https://www.tacomaworld.com/tirecalc
    C vs E - Tires load rating has do do with how they are built and how strong they are, used to be how many layers or ply, 8 vs 10ply etc.. But stronger tires are heavier (mpg loss) and stiffer (rougher riding).
    It's relative to what you are used to. I run E because I tow an RV and appreciate the extra stiffness.
    TRD-ED likes this.
  7. Jun 16, 2021 at 10:54 AM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    ^^ :thumbsup:
  8. Jun 16, 2021 at 11:06 AM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    I run E's. Only b/c the tire i wanted in the size i wanted was only offered in an E load. Makes the decision rather eazy.
    People will argue about load rating constantly. Its one of the topics that i feel 3rd party opinions are useless. Way to many variables. Its always apples to oranges.
  9. Jun 16, 2021 at 11:12 AM
    adrian191
    Adrian
    New Jersey
    Okay I’m leaning towards the C load but one more question. Will I be able to tow a small boat/RV in the future if I go with the C load?
    vicali[QUOTED] likes this.
  10. Jun 16, 2021 at 11:23 AM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Totally fine, absolutely.
    Here are those tire specs;
    265/70R17 K02 C; max load 2470lbs, 46lbs ea, max 50psi.
    265/70R17 K02 E; max load 3195lbs, 53lbs ea, max 80psi.
    So E carry more, weigh more, and can be inflated more. (cost more too!)
