BFG Ko2 tire pressure
Discussion in 'Wheels & Tires' started by psdecoy, Sep 4, 2017.
  1. Sep 4, 2017 at 3:10 PM
    psdecoy
    psdecoy [OP] Active Member
    I recently went up to 265/70/17 Ko2s (c load) on my 2017 OR on the pro rims. I've searched the forums for the correct tire pressure and have seen everything from 32 to 40 psi. So I emailed BFG and they said 45 psi. Could this be correct? Is anyone else running their psi this high?
    Here's an except from their email:
    "...we find your original tire size to be 265/70R16 with an original inflation of 30 psi. We need to use 32 psi for our load chart which supports 2234 pounds per tire.
    When you changed your tire size to LT265/70R17, the new inflation will be 45 psi which supports 2255 pounds per tire."
    jim3456 and TRACKER54 like this.
  2. Sep 4, 2017 at 3:11 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    I run 37 in mine (same size)
  3. Sep 4, 2017 at 3:15 PM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Depends. But usually 32
  4. Sep 4, 2017 at 4:37 PM
    TRACKER54
    TRACKER54 2017 TACO 4X4 OFF ROAD ACCESS CAB BARCELONA RED
    MIKE
    Santa Clarita, California.
    3inch suspension lift kit "TUFF Country", TRD PRO Front grille,Bug deflector/vent shades, Trailer controller, Snug top shell SS (COLOR MATCHED) FRONT WINDOW FOLD DOWN, BLACK OAK 20 inch LED CREE light bar (front bumper), WeatherTech floor mats, MOTO METAL "LINKS" CUSTOM 17 INCH WHEELS, BFGOODRICH 17 INCH KO2 TIRES, HI/LOW/FOG "LUMEN" H11XHL C-G7S CONVERSION KIT LED LIGHTS. FOX 2.5 FS RESERVOIR REAR SHOCKS-DSC, HYPERTECH SPEEDODOMETER CALIBRATOR, WHITE KNUCKLE SEMI-GLOSS BLACK POWDER COAT/DOM TUBE ROCK SLIDERS 15 DEGREE ANGLED UP. PIAA BACK-UP LIGHTS.TMJ FRONT ROCK CRAWLER BUMPER, 10,000 LBS SMITTYBILT SYNTHETIC ROPE WINCH, WITH WIRELESS REMOTE CONTROL,MOUNTED INSIDE (UNDER THE LICENSE PLATE). SIDE BUMPER ROCK LED LIGHTS. ANYTIME REVIEW CAMERA - SWITCHED TO INSTRUMENT PANEL.
    I bought BF's KO2's and had them mounted at Costco, 275/70R17's. They put 30 P.S.I. of nitrogen them? Seems to me to be a little light? 45 seems a little stiff though.
  5. Sep 4, 2017 at 4:46 PM
    ElBlancoTaco
    ElBlancoTaco Well-Known Member
    Ron
    Scottsdale, AZ
    2014 SR5 DCSB 4x4
    Different tire, but issue is similar. Toyota and tire shop wanted me to run my tires at 32. Engineer from tire manufacturer said run it at 50. I ran it at 44, and it felt like I had just gotten brand new tires. Toyota and tire shops have liability concerns that are not the same as your best tire performance, and their interest is not necessarily equal to your best interest.
    TRACKER54 likes this.
  6. Sep 4, 2017 at 4:48 PM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    I run 36 psi on the same tire. Best way to find out the right PSI is to chalk test them to figure out the right pressure for you truck. Weight palys a factor in what PSI you need to run. Google it if you need to know how.
    suaveflooder and TRACKER54 like this.
  7. Sep 4, 2017 at 4:57 PM
    TRACKER54
    MIKE
    ElBlancoTaco and SuperBad thanks.
  8. Sep 4, 2017 at 5:01 PM
    Norgeman
    Norgeman Member
    Christopher
    2017 wht. DCSB Sport
    OME Front Coils, Bilstein 5100's, Progressive Add-A-Leaf (1-1/2"), 2° Rear Axle Shims, OME Carrier Drop & Transfer Drop, N-Fab Nerf Bars, 265/70R17's
    I like 35/34; front & rear respectively.
  9. Sep 4, 2017 at 5:11 PM
    TRACKER54
    MIKE
    Thanks. Norgeman.
  10. Sep 4, 2017 at 6:04 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    They neglected to account for derating.
    P and ISO metric are derated by a factor of 1.1 when used on trucks and suvs. LTs need not be derated.
    So...
    2,234/1.1=2,031 lbs
    A LT/265/70/17 attains a load rating of 2,038 lbs at 39 psi.
  11. Sep 4, 2017 at 7:17 PM
    TRACKER54
    MIKE
    WOW! Thanks!
  12. Sep 5, 2017 at 4:07 AM
    splitbolt
    NW Arkansas
    I would be leary of what they used for the OEM tire's load rating; did they use a P or ISO? I suspect they used P; if OEM was ISO...it makes a difference.
    Do you recall exactly what was on the sidewall of the OEM tire?
  13. Sep 5, 2017 at 7:40 AM
    Trdoffroad1149
    Trdoffroad1149 Well-Known Member
    Jacob
    Wilkesboro, NC
    2016 TRD Off-road
    275/70/17 BFG KO2 TRD Pro 4Runner wheels TRD Pro Grill
    275/70/17 Load Range E and I set mine at 36
  14. Sep 5, 2017 at 4:59 PM
    TRACKER54
    MIKE
    275/70/R17 Load Range E. Same tire and the max load range is 3195 lbs single at 80 psi. I will not be at 80 psi!
  15. Sep 5, 2017 at 6:03 PM
    splitbolt
    NW Arkansas
    Gen 3s have a 2,149 lb inflation requirement for OEM P- and ISO- tires.
    Or...2,149/1.1=1,954 lbs for LTs.
    LT/275/70/17s have a 2,000 lb load rating at 35 psi.
    psdecoy[OP] likes this.
  16. Sep 5, 2017 at 8:34 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    You guys are getting way too mathy. Just run a chalk test and call it a day. FWIW, I run 36 front 34 rear on my F250 with 285/75R16 KBro2's if I'm not hauling or towing. 45 psi on a Tacoma would feel like riding on wagon wheels.
    CROM123, suaveflooder and psdecoy[OP] like this.
  17. Sep 5, 2017 at 8:38 PM
    TRACKER54
    MIKE
    Hey, thanks. That sounds a lot better.
  18. Sep 5, 2017 at 8:41 PM
    TRACKER54
    MIKE
    Maticuno, that looks like a FINE ride, good for you!
  19. Sep 6, 2017 at 4:00 AM
    Trdoffroad1149
    Jacob
    Wilkesboro, NC
    2016 TRD Off-road
    Well this is a Tacoma we're talking about, I'd prefer it not to ride like a horse and buggy.
    CROM123 likes this.
  20. Sep 6, 2017 at 4:16 AM
    splitbolt
    NW Arkansas
    I hear ya...
    I did the math to show differences in weight from gen 2 to gen 3.
    Also, that psi is a part of total air volume; the tire size is the other part. Change tire size, you change the container volume; psi must change accordingly to accomodate total air volume. PSI is a means to an end.
