BFG Ko2 tire pressure
Discussion in 'Wheels & Tires' started by psdecoy, Sep 4, 2017.
  1. Jan 12, 2022 at 5:21 AM
    #61
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What is the size and load rating for the stock tire?
    On a 2nd/3rd Gen, 40 would be the adjusted psi for a 31x10.5R15LT.
    There are a few reasons why you might consider it "high".
    -you might have a light gvwr; 1st Gen were 4,250-5,100 gvwr...3rd Gen is 5,600 gvwr
    -yours might be from a time period before P and metric tires were derated by 10% for use on trucks/suv...see Ford/Firestone fiasco
    My, $.02 on chalk.
    It is confirmation of nothing other than your latitudinal footprint; what's the longitudinal footprint look like? Modern radial tires don't deform the same as bias ply(usually LT flotation, agriculture tires) for which the chalk test was viable. Chalk, even if viable, would only be current weight; not possible weight(gvwr). Most of the popular sized LT tires in use on 2nd/3rd Gen lose/gain about 150 lb of load capacity per 1 psi x 4 tires. That's roughly a 8 psi swing between 'empty' and 'fully loaded'.
    Most who use chalk, do not do it correctly. You're supposed to chalk, add 10%, and then equalize deflection by increasing pressure in the tires with lower deflection. This would be viable method for modern radial tires.
    Gmak621 likes this.
  2. Apr 14, 2022 at 6:12 PM
    #62
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    275/70/17's I usually run @36 PSI
