BFG KO2's 265/70/17 - Speedometer?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mitchpage85, Nov 27, 2015.
  1. Nov 27, 2015 at 4:24 PM
    Mitchpage85
    Mitchpage85 [OP] Member
    Mitch
    Portland, OR
    2016 MGM Tacoma TRD Sport DCSB
    Im about to place an order for 265/70/17 KO2s for a 2016 DCSB Sport 4x4.
    Will it affect the odometer and speedometer being slightly larger than the stock 265/65/17's??
    gsxxr and Sir Taco like this.
  2. Nov 27, 2015 at 4:27 PM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    Your talking about a 3.3% nominal difference - nothing major. At 60 mph on your cluster, you'll actually be going ~62 mph. The OEM speedometer is not certified, so the true difference may be slightly more or slightly less. You can easily use a GPS to determine your true speed at various points after you get new tires, but even at 90 MPH, the difference less a little less than 3 MPH.
  3. Nov 27, 2015 at 4:33 PM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    My 265/75r16s make me go 2+ @70mph according to my gps.
  4. Nov 27, 2015 at 4:34 PM
    nevadabugle
    Elko, NV
    And yes, you will also drive more miles than the odometer shows. So make sure you adjust when figuring mileage.
  5. Nov 28, 2015 at 5:37 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Did the GPS test with mine. Speedo says 70, GPS said 71-72.
    G.
  6. Nov 28, 2015 at 5:43 AM
    gsxxr
    gsxxr Well-Known Member
    2016 tacoma trd sport
    3" lift, goodyear wrangler duratracs 285/70r17, k&n filter, bakflip vp tonneau and tint.
  7. Nov 28, 2015 at 6:17 AM
    Wraith600
    Wraith600 Well-Known Member
    2016 AC TRD OR Quicksand
    In the settings for the GPS in the truck there is a calibrate option. Use that and drive with the new tires and it will fix it.
  8. Nov 28, 2015 at 6:18 AM
    gsxxr
    Are you able to give me directions on were this setting is. I have been looking with no luck finding it.
  9. Nov 28, 2015 at 6:25 AM
    Wraith600
    I wish I could off the top of my head but I know it's in there for sure because I have come across it a few times. I am at "work" right now so I can't run out to my truck to take pics.
    In fact it's been brought up a few times in the 3rd gen forums. Just make sure you are parked when going through the settings because a lot are greyed out / don't show up and you may have missed it.
    https://www.tacomaworld.com/threads...-on-my-2016-dcsb-trd-or.397420/#post-11015301
    gsxxr likes this.
  10. Nov 28, 2015 at 6:26 AM
    gsxxr
    No rush. If you think about on your way home or something. I will also look again today.
  11. Nov 28, 2015 at 6:27 AM
    Wraith600
    Yea I will but without a doubt its in there.
  12. Nov 28, 2015 at 6:38 AM
    Wraith600
    In your Entune manual page 251 - 252 for anyone else that decides to search the forum. (not a sarcastic statement)
    1 Press the “APPS” button.
    2 Select “Setup”.
    3 Select “Navigation”.
    4 Select “Detailed Navi. Settings”.
    5 Select the items to be set.
    Display the “Detailed Navi. Settings”
    screen. (P.249)
    2 Select “Calibration”.
    3 Select the desired item
    The tire change calibration function will
    be used when replacing the tires. This
    function will adjust miscalculation
    caused by the circumference difference
    between the old and new tires.
    INFORMATION
    ● If this procedure is not performed when
    the tires are replaced, the current position
    mark may be incorrectly displayed.
  13. Nov 28, 2015 at 6:56 AM
    gsxxr
    Thanks I will try now
  14. Nov 28, 2015 at 7:06 AM
    gsxxr
    Ok so I found the mode. Entered into and it shows the nav screen. I drove around the block a few times. It never prompt me if it was done calibrating or not.
    How can you tell?
  15. Nov 28, 2015 at 7:06 AM
    gsxxr
    Thanks For The help
  16. Nov 28, 2015 at 7:33 AM
    gsxxr
  17. Nov 28, 2015 at 7:38 AM
    Wraith600
    I honestly don't know but if you had a gps (other then in the truck) you could see if it's correct.
  18. Nov 28, 2015 at 8:15 AM
    gsxxr
    I will down load an app and see.
  19. Nov 28, 2015 at 8:35 AM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Doesn't this just change it for the nav unit? Or does it change the odo/speedo as well?
  20. Nov 28, 2015 at 8:39 AM
    Garyji
    Gary
    I don't have Nav in the truck. Just used my iPad.
    G.
