BFG KO2s Load Range E? too much for my tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DRAWN, Apr 6, 2017.
  1. Apr 7, 2017 at 11:00 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I run 285/75/16 KO2's in load E rating, they're heavy bastards for sure. I get around around 18 with mixed highway/city driving on stock gears, with full skids and sliders.
    ensaladas likes this.
  2. Apr 7, 2017 at 11:01 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    Dang load E 265s? My 285s are load E
    DustStorm4x4 and TireFire like this.
  3. Apr 7, 2017 at 11:07 AM
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
    No problems with our KBRO2s. Definitely heavier than stock, which is a good thing, and stiffens up the ride nicely. I run at 38-40PSI
    16252139_10156246070652925_1742566945564_5cc20536da7a74cacdc940ede5e4f986b9de3660.jpg
    DjSamthrax and ensaladas like this.
  4. Apr 7, 2017 at 11:22 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    I run 43 psi in the front and 40 psi in the rear with my 285/75/16 KO2 E rated tires. The ride feels fine to me.
  5. Apr 7, 2017 at 11:47 AM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    I run 265/75/r16 E on mine they ride great. I chalk tested them and I have a full contact pattern at 45 psi on my truck unloaded. Fully loaded my contact pattern is good at 50psi. Mileage dropped about 1 mpg with them. I run them at 50-60psi when towing. Loaded for camping on road use 50psi. Loaded for camping on rock/dirt trail use 25psi. Beach with camping/fishing gear 15-20psi depends on the sand quality, good wet, packed sand I don't air down at all.
    I personally won't run anything but an E rated tire. They are just so much more durable on and off road. Not to mention the tread compound wears like iron. I have on numerous occasions in the past driven right over things on the trail with E rated tires that later cut or punctured friends C rated/P rated tires. My only 2 tire failures on the trail were on C rated tires. One of them was a tread face puncture the other was a side wall cut. I swapped them out for Es and haven't looked back.
    su.b.rat and cblow5 like this.
  6. Apr 7, 2017 at 11:51 AM
    su.b.rat
    su.b.rat broken truck
    FYI the reason i run lower pressure i'm my E tires is due to the size. 265/65-17 has smaller sidewalls and less flex than the 285 big brothers.. even the 265/70's. if i run even at 34 cold, not to mention 40 how the shop set them, i'm running on rocks, not tires. the bigger tires can get away with those pressures, but our ride is probably the same. end of the day the chalk test doesn't lie.
  7. Apr 7, 2017 at 12:29 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Post a pic!
  8. Apr 7, 2017 at 1:42 PM
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    I'm running 265/75r16 E's on my first gen reg cab. Arguably the lightest Tacoma you can get w/4wd. Slight decrease in MPG, but I went from factory tires to the BFG's so the size and weight are both factors. They're stiff, but if livable for my truck, they will be fine for any Tacoma
    I run about 30-32 on the street and 15 in the dirt. The extra stiffness and tough sidewall are worth the pounding they can take. When you're hitting 60-70mph in the desert, using the bump stops frequently and dodging bowling ball sized rocks, it's nice to have a tire you can trust to take the beating and get you home.
    Chile Verde and cblow5 like this.
  9. Apr 7, 2017 at 1:44 PM
    su.b.rat
    Cooper STMaxx E, 265/65-17
    1bad2k[QUOTED] likes this.
  10. May 17, 2017 at 12:59 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Glad I ran across this thread. I just swapped old KO's for new KO2's all 265/70/17C. Having trouble finding a sweet spot on psi. Been 90'ish the last couple of days so a cold 38 psi jumps quick to 41.5 psi and seems to beat me up on T4R 17 x 7.5 Trail wheels. Today with 38 psi hot still seems bumpy. Cannot believe some run as much as 50 psi which makes them balloons. Chalk testing is secondary to a comfortable ride. Planning on a 1500 mile road trip soon and gotta get theses comfortable for the trip. Maybe I will drop again to get 35 hot psi and see how they feel. I have one rear rim that is odd weighted, requires more than the other 3, but was the same with the KO. Love the look but after only a few days not happy with the ride yet.
  11. May 17, 2017 at 1:27 PM
    jake slatnick
    jake slatnick Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    I run my 285 ko2s at 28-30 psi. Nice and smooth :) mph with mixed city, highway, and traffic is 16 mpg
    Willbeck and mrproduxn like this.
  12. May 17, 2017 at 1:40 PM
    RedBeard1
    Red
    Chalk test your tires guys. Mine with just my armor on the truck want 45 psi to get a good pattern on the highway. Inflate them correctly for wear and make them last.
    DjSamthrax likes this.
  13. May 17, 2017 at 3:53 PM
    su.b.rat
    45psi on a tacoma with E's? my E tires, 265/65-17, do 30 front 28 rear with the chalk test. but i do ride light.
    1bad2k likes this.
  14. May 17, 2017 at 4:01 PM
    Chile Verde
    Chile Verde Well-Known Member
    Im running E rated 265/75 KO2s on stock wheels.
    I am planning on running fairly heavy though.
  15. May 17, 2017 at 5:06 PM
    #35
    RedBeard1
    Red
    My truck is a a little "husky"....
    My sliders alone are 204 lbs. Bed rack 93 lbs, roof rack and lights 58lbs. Then you throw in recovery gear, bug out gear, guns, ammunition, body armor, fuel jug, tools and yada yada it adds up.
    su.b.rat[QUOTED] likes this.
  16. May 17, 2017 at 5:40 PM
    #36
    DjSamthrax
    DjSamthrax Master Certified Toyota Product Specialist
    Sam
    Minnesnowta
    2018 Tacoma TRD-Off Road Double Cab Long Bed Cement
    18x9 Roost w/285/65/18 BFGoodrich K02, Icon Stage 4, Rough Country 30" Light Bar, Tekonsha P3 Trailer brake controller, Viper Smart Start w/GPS, Custom Screen Off Image, DDM Tuning 55w HID Low, LED everything else, Clearshield Platinum Package, Auto Armor, Tint, Every OE Toyota cargo management accessory ;-)
    I'm rolling a 285/65/18 E load K02 and love the feel of it. I know I lost a bit of power going to this however its not a race car and I would rather have an E load tire than a road hazard that interrupts my day. I'm at 38lbs cold and 42 at driving temps.
  17. May 17, 2017 at 5:41 PM
    #37
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    BETTER TO HAVE IT AND NOT NEED IT THAN NEED IT AND NOT HAVE IT! YEEEHAWWWWWWW DONT TREAD ON ME
    AZeyeTIE and canopycarl like this.
  18. May 17, 2017 at 6:00 PM
    #38
    RedBeard1
    Red
    Spent too many years in combat and working in third world countries.
  19. May 17, 2017 at 6:00 PM
    #39
    Doomsday
    Doomsday Well-Known Member
    Cypress, TX
    2017 TRD Sport 4x4 DCSB MGM
    Lights, Tires, Wheels,...more to come!
    My first set replacement set was KO in load E. Next 3 sets were load C. I will never do E again unless I run a 33" tires which most are Load E. Nitto does have a 33 in load C now, Ridge Grappler.
    crashnburn80 likes this.
  20. May 17, 2017 at 8:57 PM
    #40
    AZeyeTIE
    AZeyeTIE Uh huh
    Dewey, AZ
    '14 Super White TRD Baja
    Nothing noteworthy
    Ya buddy!! Nobody is gonna catch you slippin'.
