BFG KO3 review
Discussion in 'Wheels & Tires' started by Cbeery, Sep 20, 2023.
  1. Feb 19, 2025 at 9:41 AM
    #261
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Sadly not gonna get a response from @Discount Tire anymore here.
  2. Feb 19, 2025 at 9:58 AM
    #262
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    Yeah they merged with tire rack
  3. Feb 19, 2025 at 11:21 AM
    #263
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Yep, lots of highway miles. Truthfully, I've only ever rotated them myself each oil change (at 10k intervals) and never taken to a shop for rebalance or anything. I know pushing 100k isn't something someone should expect out of any tire, and I wouldn't expect to ever get that out of another set, but my commute/drive style obviously plays a big role in that. I'm positive I'd get half of that if my commute consisted more of twists and turns and less straight boring freeway.
  4. Feb 19, 2025 at 11:22 AM
    #264
    Off Topic Guy
    Ahh, that sucks. I knew they were "together," but didn't know DTD's TW presence vanished in that process. Oh well, I'll send an email!
  5. Feb 19, 2025 at 12:11 PM
    #265
    Burmapeak
    Burmapeak Well-Known Member
    Oregon
    2017 Tacoma TRD PRO Cement
    I went from OG Dura-Tracs 285/75/16 to KO3 285/75/16. The KO3 looked a lot skinnier. In fact, I didn't like them and now I have the new Dura-Trac R/T in 285/75/16. I also did not like the sidewall when I was researching tires. It's grown on me and looks fine now. We had 3 inches of snow in town last week. Since it was only going to last for a couple days I decided not to put on my dedicated snow tires, (Blizzaks). Well, The New Dura-Tracs did fine in 4wd accelerating from stop lights but stopping was less than desirable. Especially when I'm use to how well the blizzaks do. Had a few sketchy moments. Also, When turning on snow covered roads, they seemed to want to plow straight instead of turning. Required a bit more throttle taps to bite in. Also kind of strange. I'll definitely be putting on my dedicated snow tires for any traveling over the mountain passes instead of risking it with these. In all other conditions they have been great though. We'll see if they get as loud as the OG's when they wear down.
  6. Feb 20, 2025 at 11:29 AM
    #266
    Mad German
    Mad German Well-Known Member
    2016 TRD Off Road
    Yep, the lugs are spaced a little closer. That might be why the RT is supposed to be a littler quieter than the original DTs. Although, almost anything is a little quieter than the original DTs. If you don't mind the noise, the DT is a great tire.
  7. Feb 22, 2025 at 7:52 AM
    #267
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I recently switched from 285/75/17 Yokohama MT’s to 315/75/16 KO3’s. Same offset wheels with fairly aggressive CMC with both tires. The increased width of the 315 definitely increases the rubbing on the cab mount. i plan on modifying my chop to be more chopped and also trimming fenders this summer. Just something to think about when debating sizes.
  8. Feb 22, 2025 at 9:08 AM
    #268
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    2021 Cement Tacoma TRD OR DCLB; 2021 Blizzard Pearl 4Runner Limited; 2006 Tundra-SOLD
    Tint, DK ucas, Big Billies with Icon springs, SCS S6 wheels wrapped in Duratracs, a GFC, a Smartcap, martin OR RR, roam boxes sometimes, maxtrax and rotopax sometimes, and a ski rack other times
    How did the yokos fit on your truck? Any reason why you didn’t stick with the 285/75 KO3 size?
  9. Feb 23, 2025 at 1:38 AM
    #269
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    How well do these handle in heavy rain and going through puddles?
    RCrumb likes this.
  10. Feb 23, 2025 at 6:05 AM
    #270
    999
    999 Well-Known Member
    Texas
    Discount tire isn’t on here anymore.
    Road_Warrior likes this.
  11. Feb 23, 2025 at 6:48 AM
    #271
    boostedka
    James
    NM
    The Yokohama’s fit well with cmc, pinch weld folded over, 3.5* caster and lower fender/flare trim. No rubbing at all. Just wanted to go bigger for no real reason
  12. Feb 23, 2025 at 8:12 PM
    #272
    jmferg
    jmferg Well-Known Member
    I mounted 1, 295/75r16 to test fit for cmc cut, pinch weld and fender liner mods.
  13. Feb 23, 2025 at 9:08 PM
    #273
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    I’m curious to see how they look/how they fit and if you like em in the snow/mud/and rocks. I think the 295/70 KO3 is my next tire, but I haven’t seen em mounted up in the wild yet!
  14. Feb 23, 2025 at 9:45 PM
    #274
    MGMDesertTaco
    That's a huge tire for a 16" wheel.
    RCrumb likes this.
  15. Feb 23, 2025 at 10:43 PM
    #275
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    Update: Had the KO3's in 265/75/16 for 5500 miles/6months. They do great in the rain/wet roads so far. No slipping which was my biggest concern. Also seen some mud and sand but no white stuff here.
    Just rotated, road wear looks even, nothing odd.
    Road noise still pretty quiet. Pretty happy over all, just wish it wasn't $320 per tire!
  16. Feb 24, 2025 at 8:13 AM
    #276
    jmferg
    I have exclusively ran mud terrains or hybrid tires. I wanted something that would perform well enough in all conditions and be quiet on the road. In the northeast, you need something that can do it all. Snow/ice, mud and rocks. These KO3s will be the least aggressive tires I've ever ran so hopefully they don't disappoint.
    Bfgoodrich lists them at 33.4" x 11.6". they seem true to size, if not a little taller. You wouldn't want to go any wider on factory 16x7" wheels.
  17. Feb 24, 2025 at 8:51 AM
    #277
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    Same. Although as I’ve gotten older I’ve found myself gravitating to less and less aggressive tires with every new set I buy. lol. Living in the PNW, I need a good snow and ice tire. My OG duratracs have been great, but they’ve got miles on em and they’re starting to get loud and show their age
    jmferg[QUOTED] likes this.
  18. Feb 24, 2025 at 9:00 AM
    #278
    boostedka
    James
    NM
    This describes most of my friends.
  19. Mar 10, 2025 at 4:09 PM
    #279
    name_not_important
    name_not_important Blessed are the peacemakers
    Front Range CO
    2021 TRD OR Cement
    RCI sliders, Method 703, Diode dynamics fogs, Diamondback cover, leveled from TRD pro suspension (used take offs), MESO hitch pod, DesertDoesIt seat jackers
    Has anybody had the “MT Baja boss AT” before using the KO3? (They are my top 2 choices right now)
    It’s SL or E for the Baja boss and E for the KO3 in my size (265/75r16).
    Thanks in advance
  20. Mar 10, 2025 at 4:36 PM
    #280
    MGMDesertTaco
    There's a whole thread for those too. You might be interested in checking it out...
    https://www.tacomaworld.com/threads/mickey-thompson-baja-boss-at.751616/
    boostedka likes this.
