BFG KO3 review
Discussion in 'Wheels & Tires' started by Cbeery, Sep 20, 2023.
  1. Jul 30, 2025 at 6:01 PM
    #361
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    2021 Cement Tacoma TRD OR DCLB; 2021 Blizzard Pearl 4Runner Limited; 2006 Tundra-SOLD
    Tint, DK ucas, Big Billies with Icon springs, SCS S6 wheels wrapped in Duratracs, a GFC, a Smartcap, martin OR RR, roam boxes sometimes, maxtrax and rotopax sometimes, and a ski rack other times
    Alright folk, I threw a 295/70/17 up next to my worn 285/70/17 GY duratrac and there isn’t much a difference in size being completely honest. I also compared em to a Yokohama X-AT in the same 295/70/17 size and the difference is fairly noticeable. BFG makes a 305/70/17 and those may size similarly to a true 295/70. I think I’m likely going to go that route.
    MGMDesertTaco and Road_Warrior like this.
  2. Jul 31, 2025 at 7:15 PM
    #362
    MGMDesertTaco
    Poor Olga's out there sweatin in the sun while you're trying to make up your mind. :bananadead:
    GTGallop and 4xThad[QUOTED] like this.
  3. Jul 31, 2025 at 9:46 PM
    #363
    MGMDesertTaco
    Had mine rotated after the first 6k miles today. :burnrubber:
  4. Jul 31, 2025 at 9:52 PM
    #364
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    35x11.5x17 "C" load is supposed to be coming, originally shown to be in May 2026
    4xThad[QUOTED] likes this.
  5. Aug 1, 2025 at 6:08 AM
    #365
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    :rofl::rofl:
    MGMDesertTaco[QUOTED] likes this.
  6. Aug 1, 2025 at 6:30 AM
    #366
    king.cong.1119
    king.cong.1119 Well-Known Member
    Recently switched from KO3 (265/70r17 lrE) to Falken Wildpeak AT4W (255/80r17 lrE), only reason to switch is I wanted the pizza cutter.
    I really liked both of them, Falken definitely felt a bit more soft/plush and doing a better job dampening the road (both tires same psi), I am suspecting the narrower profile and taller side walls helps a lot in this.
    Road_Warrior and Canadian Caber like this.
  7. Aug 1, 2025 at 5:56 PM
    #367
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    Problem is that I’m not sure I can wait that long
  8. Aug 5, 2025 at 5:31 PM
    #368
    Millertaco21
    Millertaco21 Active Member
    2021 Tacoma SR, 4x4, quad cab.
    Looks great, are these E or C load? What are the actual mounted dimensions?
    Road_Warrior likes this.
  9. Aug 6, 2025 at 7:59 PM
    #369
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    So they’re still actively making the K02 in a ton of sizes still!!?
  10. Aug 6, 2025 at 8:06 PM
    #370
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Pretty much anything that KO3 has a size for has been discontinued in KO2. You can kinda see this on tire rack by looking at all the KO2 sizes and seeing which are available but are on special/closeout…indicating they are going bye bye soon.
    20 more sizes were just released last Friday, they are getting close to being done with the rollout. I think it’s 100% by May next year.
    Gmak621[QUOTED] likes this.
  11. Aug 7, 2025 at 5:37 AM
    #371
    Millertaco21
    I just ordered a set of 285/75/16 C load KO3s from custom offset, should be delivered next week.
    captrussia253 likes this.
  12. Aug 7, 2025 at 5:52 AM
    #372
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    They’re dropping a 35x11.5 next May.. which measures 34.5” tall. I think I’d really like that tire but I don’t think I can wait until next May for rubber.
  13. Aug 7, 2025 at 6:21 AM
    #373
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    I think in the roll out they are phasing out some of the 16" tires since that's not as popular a rim size any more. As far as I know, Toyota is the only one selling trucks with 16's on them any more.
  14. Aug 7, 2025 at 7:41 AM
    #374
    jmferg
    jmferg Well-Known Member
    would you consider
    305/70r17 33.9 x 12 @ 64lbs
    or
    285/75r17 33.8 x 11.2 @ 63.2lbs
  15. Aug 7, 2025 at 8:24 AM
    #375
    01 dhrracer
    Still Shopping
    Before BFG updated their website they provide more details with the tire dimensions. For a KO2 the 315 was 12.5" wide and my 285's on a 8.5" wide rim with zero offset it is closer to 11.5" wide. The 305 is an "F" load. Something BFG is showing a lot more of than with the KO2. I would need to use a spacer or a negative offset wheel to use the 315 and most likely with the 305 as well. No plans to change wheels and I won't be using spacers. That is why the 35x11.5 is so appealing. My KO2's in 285/75/17 only came in an "E" load rating. A little rough ride at times. The KO3 in 35x11.5x17 will be available in a "C" load. My understanding is that all KO3's will be 3 ply sidewall. KO2's sizes were either 2 or 3 ply sidewall with all "E" loads I believe were 3 ply but only some "C" loads were. Something BFG did not have on their website.
  16. Aug 7, 2025 at 8:27 AM
    #376
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    The 305 is an F load… so no, it’ll be a dump truck
    The 285/75 is interesting. Ive actually ordered a C load 285/75/17 falken at4 so we’ll see how that goes. The Falken runs true to size or even big… the bgf runs small. No 295 Falken yet… just wish the Falken wasn’t so heavy…
  17. Aug 7, 2025 at 12:57 PM
    #377
    jmferg
    yeah, the wildpeak AT4 gained a lot of weight vs the wildpeak at3. Read a couple reviews and see if you'll be okay with the snow/winter performance of the at4.
    https://www.youtube.com/watch?v=pp0QrccoKqA&t=33s
  18. Aug 7, 2025 at 1:51 PM
    #378
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    I actually watched that video last night…. Those are all E rated tires. I feel like a C rated tire might be more plyable and perform better in snow however?
  19. Aug 7, 2025 at 5:48 PM
    #379
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    The tread has always kinda reminded me of something, but I could never quite put my finger on it...until tonight. Anyone else?
    jmferg likes this.
  20. Aug 8, 2025 at 5:21 AM
    #380
    GTGallop
    Greg
    Anthem, Arizona
    Dash Cams and Hams!
    When I was a kid in the early to mid 70's, my dad had some sandals that were made out of used tires. He got them in Mexico.
    Around July of 2000 I went to Cancun and looked for them - couldn't find them. Apparently they were only around for the hippies in the 60's.
    Then later in about 2006, still chasing the dream, I was in an ankle boot for an injury. I wore the tread off of it pretty quick and got a used tire from Discount and cut the tread and fit it in the ankle boot. Worked like a CHAMP.
    Always thought that off road tires were missing a HUGE marketing opportunity to put their tread on shoes.
    MGMDesertTaco and moon22 like this.
