BFG KO3 review
Discussion in 'Wheels & Tires' started by Cbeery, Sep 20, 2023.
  1. Jul 9, 2024 at 11:37 AM
    #121
    king.cong.1119
    king.cong.1119 Well-Known Member
    100%
    captrussia253 likes this.
  2. Jul 9, 2024 at 12:11 PM
    #122
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    they just overall a better tire compared to ko2.
    Have to watch the vids in this thread and read all the posts but was just trying to hear from someone who had both
  3. Jul 9, 2024 at 12:17 PM
    #123
    TRD2010SpeedwayBlue
    Brandon
    @Discount Tire do these ko3 come in 285/70/17 C rated with white letters?
  4. Jul 10, 2024 at 5:29 AM
    #124
    king.cong.1119
    I have had around 4-5 sets of KO2s in various size, I personally have no problem with them being little slippery in wet condition (one of its short comings allegedly). So far KO3 seems to be a tad quieter than KO2s and I have not had opportunity to drive it in the wet yet. However, given that my truck struggles off the line in wet even with stock tires, I am not expecting a lot.
  5. Jul 10, 2024 at 10:12 AM
    #125
    christianherc
    christianherc New Member
    been waiting for the KO3s for over a year now and it doesnt look like im getting a 265 70R16 What's the main issue going from an R16 to an R17, will the truck just sit a little higher ?
  6. Jul 10, 2024 at 10:15 AM
    #126
    king.cong.1119
    The OD of 265/70r16 is about 1 inch less than 265/70r17, however, the effective height of the tires is only 0.5 inch difference (raise the vehicle up by 0.5inch) and I think it's negligible.
  7. Jul 10, 2024 at 10:21 AM
    #127
    christianherc
    oh, but i would need to get a 17 rim then ... thats not going to work, i have the PTR56-35220-F3s and i want to use them
  8. Jul 10, 2024 at 10:23 AM
    #128
    king.cong.1119
    right, I'd suggest wait for 265/75r16 thats coming out in august.
  9. Jul 10, 2024 at 10:23 AM
    #129
    christianherc
    whats the difference in the 70 and 75 then ?
  10. Jul 10, 2024 at 10:26 AM
    #130
    king.cong.1119
    265/75r16 is essentially the same OD with 265/70r17, but for 16inch wheels. I only suggested that since you were looking for 265/70r17 in the beginning, and 265/75r16 is very similar.
    christianherc[QUOTED] likes this.
  11. Jul 10, 2024 at 11:17 AM
    #131
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    265/70R16 is coming out in February 2025.
    16 and 17 are wheel sizes. 265/70R16 is an inch smaller than 265/70R17. If you wanted an equivalent to stock size (265/70R16) tire on a 17" wheel, you would want 265/65R17.
    Obviously, you need to have a set of 17” wheels for that to work. If you want to upsize on your 16’s, you would run 265/75R16. KO3s in that size are coming out next month, August 2024.
  12. Jul 10, 2024 at 7:48 PM
    #132
    Daulll
    Daulll Well-Known Member
    Saul
    SoCal
    2022 Tacoma OR
    285/70/17 load C mounted time for alignment!
  13. Jul 15, 2024 at 6:39 AM
    #133
    king.cong.1119
    Took a trip to beach, 200miles highway, 20 miles sand, tire did 100% great, highway mpg calculated to be 22.6mpg with LT265/70r17 load range E. Very satisfied with KO3. (did not air down due to the stormy weather and the sand was wet enough)
  14. Jul 15, 2024 at 7:07 AM
    #134
    TRD2010SpeedwayBlue
    Brandon
    Does anyone know if LT 285/70/17 C come in white letter?
  15. Jul 15, 2024 at 7:13 AM
    #135
    king.cong.1119
    not that i know of, yet
  16. Jul 15, 2024 at 7:17 AM
    #136
    TRD2010SpeedwayBlue
    Brandon
    I hope they do. Or else ima have to get the black letters. Not opposed to it just use to the white letters since i got my truck in 2015
  17. Jul 15, 2024 at 7:19 AM
    #137
    king.cong.1119
    yea personally I love the look of the raised white letter tires for our tacomas, it gives tires a bit more definition.
  18. Aug 5, 2024 at 7:37 PM
    #138
    Hookes law
    Hookes law Well-Known Member
    Frank the tank
    Tacoma
  19. Aug 5, 2024 at 8:17 PM
    #139
    BLtheP
    Plano, TX
    Looks good. Any chance you got to weigh them before install? Curious if the listed weight is correct. They are listed lighter than the KO2 in the same size, which doesn’t make sense because most the other KO3 are heavier than their previous KO2 size.
    Drive any different than what you had previously? Sluggish or anything?
  20. Aug 5, 2024 at 8:40 PM
    #140
    Hookes law
    Frank the tank
    Tacoma
    I did not weigh them.
    I just had them installed, I only drove it back from the tire shop to my house which is about 5 miles.
    But it felt better then the stock tires (Goodyear Wrangler) I had before.
    Evostaco and BLtheP[QUOTED] like this.
