BFG KO3 review
Discussion in 'Wheels & Tires' started by Cbeery, Sep 20, 2023.
  1. Aug 6, 2024 at 4:19 AM
    #141
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Keep us updated for sure, milage , any power loss. That kind of thing
    Hookes law[QUOTED] likes this.
  2. Aug 9, 2024 at 12:23 PM
    #142
    MFG
    MFG Well-Known Member
    Agreed, following
  3. Aug 9, 2024 at 12:41 PM
    #143
    Hookes law
    Hookes law Well-Known Member
    Frank the tank
    Tacoma
    I haven't driven too much lately, mainly surface streets, no change in speed, I tested that in a speed check Street at low speeds 45 mph zone
    Not sure, but maybe insignificant power loss going up inclines, almost negligible, I think I noticed having to accelerate slightly more going up an incline
    Evostaco[QUOTED] likes this.
  4. Aug 20, 2024 at 3:28 PM
    #144
    firsttraxxx
    firsttraxxx Well-Known Member
    NoVA-LoCo
    2013 Baja TX
    Fox 2.5 front / JBA UCA 3” Fox 2.0 rear / Icon RXT Stg 1 3” BAMF rear bumper Some cool mods
    I think my installer screwed up, told them tires are directional on side “rolls forward” drivers side (above) looks correct, passenger is reversed. Geez
  5. Aug 20, 2024 at 4:49 PM
    #145
    OffRoad_Stu
    OffRoad_Stu Well-Known Member
    West Coast
    2021 Army Green TRD OR DCSB
    Just got these in a 285/70/r17E installed, they ride so smooth and quiet compared to my previous tires (patagonia milestar M/Ts with super bad heel/toe wear.) Big O Tires is offering TWO $60 rebates on them right now!
    firsttraxxx likes this.
  6. Aug 25, 2024 at 2:21 PM
    #146
    1urch420365
    1urch420365 Well-Known Member
    James
    2015 Tacoma
    I believe the tire is multi directional meaning that’s how it’s suppose to be
  7. Aug 25, 2024 at 4:43 PM
    #147
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    The 70 and 75 is what is referred to as the aspect ratio. The 265 or 285 is the section width in millimeters (width of the sidewall to sidewall, not tread width) The 70 & 75 is a percentage of the section width indicating the height of the sidewall. Example: 265mm x .75=198.75mm is the sidewall height. So, tire overall diameter would be (198.75 x 2=397.5mm) (397.5mm divide by 25.4)(to convert mm to inch) =15.65 + rim diameter of 16"=31.65"for calculated tire diameter. However, with every brand there will variables and tire diameter may not actually be that 31.65. Then tire height/diameter on vehicle with the weight of vehicle on tire will be smaller.
  8. Aug 25, 2024 at 5:52 PM
    #148
    eurowner
    eurowner Duke Sky
    Scoty
    1urch420365 likes this.
  9. Aug 26, 2024 at 12:23 PM
    #149
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    Does anyone think this will be C rated RWL?
  10. Aug 26, 2024 at 5:25 PM
    #150
    1urch420365
    James
    2015 Tacoma
    Possible… no 265/75/16 c or d… brutal. Guess I’m getting the Es
  11. Aug 30, 2024 at 11:07 AM
    #151
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Now that it’s been almost a month, how are they working for you? Any experience with wet traction? Also curious about if you can feel the weight with them being 55 lbs (stats were updated). I’m tempted to wait for the stock size to become available next February.
  12. Sep 2, 2024 at 12:50 PM
    #152
    1urch420365
    James
    2015 Tacoma
    Can anyone confirm the weight of these in 265/75/16? Bfgoodrich website says 55lbs while DT says 50lbs. Also I currently have toyo at3s SL in the same size. Will I notice a significant change in power, mpg ect. with the weight difference of the tires? Thanks in advance for any information!
  13. Sep 2, 2024 at 1:04 PM
    #153
    BLtheP
    Plano, TX
    I’m also wanting to know the same with the weight. I’m going to guess 55 is accurate, since it’s from BFG and not DT. I also say that because the KO2 was something like 53-54 lbs and so that seems more likely to point to 55 for KO3 than 50. The 265/70R17 KO2 to KO3 went from 53 lbs to 55 lbs.
    2 years ago my truck came with 53 lb KO2s in 265/70R17. I went down to 265/65R17 Toyos in XL and shaved 14 lbs per. I noticed a small increase in performance, but it wasn’t that drastic. Not as drastic as I thought it would be anyways.
    From looking at my mpg spreadsheet, my mpg didn’t change measurably, but I drive with a lead foot and am constantly in the high rpm’s, so there’s no telling how the mpg could have been had I applied myself. I think it may hurt some in town but on the highway not so much.
  14. Sep 5, 2024 at 12:28 PM
    #154
    ohmyleg
    ohmyleg Member
    Just heads up, getting a very slight rub at full turn on the front mudflaps on TRD off-road 3rd Gen with 265/75/16 and 0 offset wheels (no lift). Was surprised to find out, but not a big deal
    TacoPandaTRD and Evostaco like this.
  15. Sep 5, 2024 at 1:04 PM
    #155
    BLtheP
    Plano, TX
    Pretty typical for 0 offset, especially if your wheel is 8-8.5” or more in width. Even the 7” wide +4mm offset TRD Sema wheels will hit the stock mud flaps on 32” tires.
    How do you like the tires? Maybe too soon to tell, but are they smooth and do you notice the weight?
    TacoPandaTRD and ohmyleg[QUOTED] like this.
  16. Sep 5, 2024 at 2:55 PM
    #156
    ohmyleg
    ohmyleg Member
    I've only had them for two days, so a bit too soon to tell. Butt dyno detected a little bit of a weight increase, but also could be me overthinking. Def not a huge deal.
    Highway/city driving was nice and smooth. I have a roof rack that's already pretty noisy, so whatever road noise they added is negligible. Excited to take them on some trails later this month!
    BLtheP[QUOTED] likes this.
  17. Sep 8, 2024 at 3:51 PM
    #157
    PNW15
    PNW15 Well-Known Member
    2015 Tacoma DC LB SR5
    I dunno if my P rated AT3w are gonna hold out long enough to get some LT255/75R17 C... Since they don't come out until next year... But I'm optimistic that this will be a good size and weight for the Tacoma now that the AT4w is so heavy relative to the AT3w and other models...
  18. Sep 10, 2024 at 5:11 PM
    #158
    Daulll
    Daulll Well-Known Member
    Saul
    SoCal
    2022 Tacoma OR
  19. Sep 12, 2024 at 12:25 PM
    #159
    RedsWhiteTaco
    RedsWhiteTaco Well-Known Member
    Portland
    2020 Tacoma Off-Road
    anybody done any rain riding with these yet? Need to replace my Falk AT3W and the AT4W is getting terrible rain reviews.
  20. Sep 14, 2024 at 12:39 AM
    #160
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    Also looking for updates on road noise and wet road tracking. Is it more, less, same as KO2?
    Regrets?
