BFG Load Range "E" Tire Question
Discussion in 'Wheels & Tires' started by jgang, Aug 22, 2009.
  1. Aug 22, 2009 at 6:02 PM
    jgang
    jgang [OP] Well-Known Member
    OK, so LR "E" 10 ply BFG ATs are "supposed" to be for heavier duty trucks. However, for those with 18" wheels, the only thing available in the BFG AT is a LR "E" tire. For you guys with 18" rims running BFG ATs, do you notice a harsher ride vice a LR "C" tire? LR "C" is all we really need on our Tacomas.
  2. Aug 25, 2009 at 5:12 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Yes, you will have a 'harsher' or 'more truck like' ride with the stiffer 'E' rated tires. But most people don't mind it too much, so it is a matter of personal opinion. Also they will weigh a little more, so you can expect your mpg to go down slightly.
  3. Aug 25, 2009 at 7:31 AM
    jgang
    Bout what I figured. Not sure if it's worth the hassle to find an 18" wheel I like, then pay $225/tire. :-(
  4. Aug 26, 2009 at 3:12 AM
    FoxySandChick
    Kristin
    Henderson, NV
    IMO...18s are too much for this truck, more people are running 17s ;)
  5. Aug 26, 2009 at 9:26 AM
    ComaChic
    ComaChic Well-Known Member
    New York...not the city!
    06 DCLB TRD Sport V6
    OME 885's w/ Top spacer kit, OME Nitro 90000 Sport and N182, LR UCA's, 2" AAL non TSB, Window tint, K&N Intake, Lights
    E load range is overkill for the Tacoma i would have to say. 10 Ply tire is gonna be very stiff. Paying way more for them too when you won't be needing it.
  6. Aug 26, 2009 at 9:39 AM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    What about a 'D' rated tire?
  7. Aug 27, 2009 at 4:51 AM
    FoxySandChick
    Kristin
    Henderson, NV
    Same for D and E rated, overkill for the truck and both will be considerably 'stiffer' than the stockers,which are P-passenger rated.
  8. Sep 5, 2009 at 10:35 AM
    Kahunadave
    Kahunadave Well-Known Member
    Dave
    Orlando, FL
    05 DC PrernrTRD Sport
    K&N CAI-series 63, custom Billet Grille, Magnaflow exhaust, AR Tactic 17x8, Toyo A/T opencountry 265/70/17, Iridium plugs.
    had BFGs (forget which model) but LR "E" on a 98 4Runner i had and yes..ride is very harsh, should have gone w/LR C.
  9. Sep 6, 2009 at 9:31 AM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Just because it is a LRE you don't have to put 80 psi in it. You can keep them around 40/50 front back if you tow some and if you tow a lot bump the rears up. It's a lot better for towing heavy loads, it won't sway. But I agree that that is too much tire for that.
