BFG TA Size Question
Discussion in 'Wheels & Tires' started by flu33ys, Jul 29, 2009.
  1. Jul 29, 2009 at 9:39 PM
    flu33ys
    flu33ys [OP] Active Member
    Denver, CO
    "Mathilda"
    2009 Silver DC Offroad, 2" ADS lift kit and adjustable shocks, Deaver u402 leaf springs stage 1, 4x4 Innovations skid plate + high clearance rear bumper, Mr Marv baffles and stereo kit, soft topper, etc. etc.
    Greetings,
    Recently joined TW and I've just purchased a new 2009 DC Offroad Taco and am loving it! This truck kicks arse! Have replaced the entire stereo system and the interior is done, at least for now ;) (kudos to Mr. Marv!). Ivan Stewart 16x8 TRD rims arrived today and await new rubber, 5100's on order and should arrive soon.
    My noob question is as follows:
    After much research on this site (thanks to TW members!) I think I've decided upon a 265/75/r16 BFG TA KO tire with the 5100's set at .85 to help level out the truck. I've always run BFG TA's (2 prior trucks were Nissan hardbodies) and have always used Discount Tire. However, on the Discount Tire web site, there are three types of BFG 265/75/r16 tires listed:
    Type 1: $197 each
    Size LT265/75R-16/D1 120S Warranty 50,000 Miles UTQG N/A Speed Rating S
    Type 2: $201 each
    Size LT265/75R-16/E1 123Q Warranty 50,000 Miles UTQG N/A Speed Rating Q
    Type 3: $202 each
    Size LT265/75R16E1 123S W Warranty 50,000 Miles UTQG N/A Speed Rating S
    Aside from the speed rating, can you folks help me with the differences between these tires? Which should I order?
    Cheers - flu33ys
  2. Jul 30, 2009 at 12:43 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Load rating. Side walls will be stiffer on the E.
    Do you want a stiffer ride? Do you tow or load the bed lots? Do you off road where airing down is an issue?
  3. Jul 30, 2009 at 8:39 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    You don't need an E rated tire on a Tacoma. It's an extra 10 lb. of rolling mass on each corner. Go with the lighter rated tire.
  4. Jul 30, 2009 at 10:23 AM
    Ramphonic
    Ramphonic Well-Known Member
    Cape Cod
    2k1 SR5 4x4 V6
    Adjustable Bilstein, AAL Lift, Eagle Rims with BFG ATs, Trd Exhaust, Clear Corners, Red Clear Tails
    I just inquired with Discount tire on a set of the BFG ATs 265/75/16 in the D rating and they told me they would be special order and they dont stock them anymore.
  5. Jul 30, 2009 at 10:40 AM
    bb609
    bb609 O.F.
    NH
  6. Jul 30, 2009 at 12:35 PM
    flu33ys
    Denver, CO
    "Mathilda"
    Excellent - thanks for the information. I'm curious where you get the extra 10lbs data from?
    Tire Rack has great prices, but shipping costs to Denver more than make up for the difference. :( Discount Tire seems to be the best local option, but still searching.
    Thanks for the Hunter "finder" link - most handy!:)
  7. Jul 30, 2009 at 12:38 PM
    bb609
    bb609 O.F.
    NH
    Check it out on the specs page. I guess I was wrong on 10 lbs. I SWEAR it was all of that last I looked.:p It's all extra weight that you don't need anyway.
    http://www.tirerack.com/tires/Spec.jsp?make=BFGoodrich&model=All-Terrain+T/A+KO&tirePageLocQty=
  8. Jul 30, 2009 at 12:41 PM
    flu33ys
    Denver, CO
    "Mathilda"
    Ah, ok. I think the D rating is the best move - thanks again!
