BFGKO2's (C or E rated) thoughts? differences?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LENPro, Apr 21, 2020.
  1. Apr 21, 2020 at 2:49 PM
    LENPro
    LENPro [OP] Well-Known Member
    2019 Tacoma TRD Pro
    I recently put E rated KO2's on my TRD Pro.
    Any thoughts on whats most used?
  2. Apr 21, 2020 at 3:10 PM
    TacoTime850
    TacoTime850 Always Maybe Sometimes Never
    Everywhere and Nowhere
    2019 DCSB 4x4
    2.5” lift, Fox 2.5 ext tvl adjustable w/ DSC, SPC adjustable UCAs, Icon RXT leaf pack, Superbump stops, 17x9 Fuel Podium Bronze wheels, 285/70/17 Cooper STT Pro
    E rated are the most common KO2s. So I would guess they they are the most common used.
    I have the C rated and they are a little more stiff than the C rated Ridge Grapplers I had on before.
  3. Apr 21, 2020 at 5:26 PM
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    If you're not towing, go c rated. If you're going to tow, get e-rated. It's that simple. E-rated can handle the work a 1-ton will put it through. You have a tacoma. E will work, might be rougher but certainly heavier.
    If you have the choice and don't need it, go c. If you're going to work the hell out of your taco or tow a mid-range load for thousands of miles, go e.
    The difference is the tradeoff in comfort and stability with p-rated being the cushiest, c being the all purpose and e being "you had better beat the hell out of it to be rewarded"
    Just don't lie to yourself.
    (I've run them all; even the odd-ball, d-rated duratrac. Towed an xj a thousand miles on them. Each tire has its place but unless you're on that level, there's no need to play the game on hard mode, its just more expensive and, well, harder.)
  4. Apr 21, 2020 at 8:06 PM
    Spazum888
    Spazum888 Well-Known Member
    Spaz
    Orlando, FL
    2017 Taco TRD off-road 4x4
    And this is how you complete a thread.
    Since you already have the tires, no biggie
  5. Apr 21, 2020 at 8:08 PM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    C all the way for a daily driver. I've had both
  6. Apr 21, 2020 at 8:42 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Our trucks only require a C rated tire. The side walls of C rated tires are rated higher than the Tacoma tow capacity, so E rated is basically pointless for towing.
    if you off road often and you air down over sharp jagged terrain, then an E rated tire should be considered. Otherwise a C rated is more than plenty.
    stealthmode and brodyman0508 like this.
  7. Apr 21, 2020 at 9:14 PM
    Doobfucious
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Thank you, sir!
    Truth on e-rated being well over the ability, but like I said, if you're towing significant weight (4500+) a significant distance (long enough to require at least a gas and piss-break), then you'll notice the stiffer sidewall of an e-rated. Wheeling... eh, not so sure, c-rated gives a nice squish on a light vehicle like a taco. 12psi on e-rated MTRs on my tj looked like about 20 on a normal truck. Sharp rocks or edges, yeah, e if paranoid but it's in no way critical.
    jmauvais[QUOTED] likes this.
  8. Apr 21, 2020 at 9:29 PM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    E rated will take more abuse and is less likely to suffer a puncture. These will hit your gas mileage as a penalty.
    C rated will be more comfortable, will give better mileage and is likely the correct choice unless you will subject the tires to heavy off road abuse.
    I plugged a few holes in the AT2s I ran, but while I have pulled a screw out of the X3s, it did not go through.
    stealthmode and Big tall dave like this.
  9. Apr 21, 2020 at 9:43 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    The Tacoma only requires a P rated. Max load with max trailer is still well within the P rating. Hell, my Tundra with 4K more capacity still only requires a P rated tire.
    Only reason to ever go E is desert sharp rocks or thorns.
