BFGoodrich All Terrain T/A KO2
Discussion in 'Wheels & Tires' started by Discount Tire, Sep 15, 2014.
  1. Nov 25, 2014 at 5:40 PM
    #181
    Donefore
    Donefore Well-Known Member
    Gavin
    PDX, OR
    2012 Tacoma DCSB TRD OR
    Am I the only one that finds it very very hard to believe the Factory Jeep wheel survived the 10,000' fall? I can see the tire handling it but damn that rim sure as hell had to bend the way that thing landed.
  2. Nov 25, 2014 at 8:22 PM
    #182
    surfermatt
    surfermatt Well-Known Member
    CA
    04 prerunner, ext cab
    Front long travel custom: king 10" CO, solid lowers, fabbed spindle, heimed everything ect. Rear still in progress, waiting to be put on: bilstein 9100s, T100 axle. Stock 3.4 engine, 4.30 gears.
    Try 34 front 32 in the rear
  3. Nov 25, 2014 at 8:45 PM
    #183
    FooBird
    FooBird Well-Known Member
    Kirkland, WA
    '14 DCSB 4x4 TRD Off Road
    I'll have to look. I was planning on 35/32 front and rear.
    Not sure why Toyota suggests the other way around.
  4. Nov 26, 2014 at 4:24 AM
    #184
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    Just got some 285/70r/16's KO2's put on and they are pretty amazing so far. I came from Nitto Trail Grappler 285/75r/16's with 30k. There is a huge difference. Example: Road noise...didn't realize how noisy the Nitto's were until I changed to new tires. Agility.....my truck moves faster, easier, side to side (extreme difference). Speed..... starting from a dead stop and rolling speed is smooth and fast (very noticeable). Traction....is still the same from what I can tell. I'm on a half tank of gas, so I don't know what it might do for MPGs, but I'm pretty satisfied, but who isn't with a new set of tires!
  5. Nov 27, 2014 at 3:46 AM
    #185
    techride
    techride Weekend Warrior
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Bilstein/Icon 2" suspension lift with wheelers 5 leaf springs, 7-pin relocate through bumper, bfg KO2s, redline hood struts, immryo mirror relocation, stubby antenna, dipped emblem, heated mirrors, Jason trek cap, led fogs, debadged
    I've had my KO2's for two weeks now and have been pretty happy with them so far. I got them in the 265/75/16 size. Needless to say, they're a far cry heavier than the dunflops that came stock on the truck, and I've noticed a significant drop in throttle response. That being said, the traction in the wet on pavement is good and mud is better. I'm running 35/32 psi and the ride is choppy but I don't think that'll change with an E rated tire. Haven't been able to do a proper chalk test yet. Its too wet around here!!! :(
    From what the weather man says, I'll get to try them in snowy/icy conditions this weekend! I'll follow up once I get a chance to play around a bit :D
  6. Nov 27, 2014 at 5:14 AM
    #186
    IronBagel
    IronBagel Well-Known Member
    Jake
    North Carolina
    2009 DCSB
    Got mine put on a few days ago and have been pretty impressed so far. Tired them out in some light snow on their first day and they've been great. Very quiet, and handle on the road great. I am interested to see what they'll do to my mileage considering I have a 4 banger.
  7. Nov 28, 2014 at 1:41 PM
    #187
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    At Discount Tire right now getting 285/75R16's put on. Place is a ZOO!!! Snow in the forecast + Black Friday = nuttiness.
  8. Nov 28, 2014 at 2:02 PM
    #188
    Discount Tire
    Discount Tire [OP] Tire & Wheel Specialists Vendor
    Arizona, USA
    You have the equation dead on, scollins! We appreciate your patience :thumbsup:
    Let us know what your initial impressions of the tires are when you get a chance. Thank you for your business!
  9. Nov 29, 2014 at 10:39 PM
    #189
    ShawnR
    ShawnR Roads?? We don't need no stinkin' roads...
    Shawn
    Denver
    10 Taco TRD OR access cab
    PIAA driving lights,Pioneer AVH-P3300BT stereo with HD radio and Axxess steering wheel control adapter,rearview mirror mod,ReTrax rolling cover,Demello front bumper,WeatherTech,10 inch woofer,500 watt amp,CB in armrest, heated Wet Okole seat covers,Spidertrax spacers, ARB twin compressor,Ikon 10,500lb wireless winch,A-pillar RAM mount,Pull-Pal,electric locking tailgate
    Went on black friday to discount tire in Arvada, CO. Got BFG AT KO2's 285/75R16 on my wife's Ram 2500.
    Took them 2 hours, even with 6 bays going. They forgot to put the hubcap back on tight, and it was rolling down the road when they took it for the road test. My wife ran out and grabbed it.
    I'm planning to get Spidertrax 1.25 spacers on the Taco, and get the Hankook Dynapro AT-M 285/75R16's. Supposedly the spacers provide enough clearance for the wider tire.
    I keep reading the Hankooks have very good traction, and long life, and aren't TOO loud.
  10. Nov 30, 2014 at 2:52 PM
    #190
    scollins
    Scott
    Renton WA
    Pics:
    A04530CC-9C93-4F1D-BD8B-01D47FBA0C9D_zps_f8dd6ce04bae2e395ba059c79d9d6939aa11f4b6.jpg
    56393331-D386-46DD-BDE3-55BFBEA21709_zps_89c9bde2c1a85c30769380fe02804a812dba20fe.jpg
    4AA602BD-FEA8-44D9-BF90-F15C79ECE95E_zps_abc4fddf10ff7562cbff8c2932cfaccb671a4f1c.jpg
    3A34C278-2C51-4F05-959F-8757B9AF6A13_zps_9d1bb9a69a1d6ea562c57f6bfcca1043596cbfba.jpg
    Measured height as mounted and sitting:
    Front = 32 1/8" (Front GAW is 2,480 lbs)
    Rear = 32 3/8" (Rear GAW is 2,100 lbs)
    Initial impressions with only a few road miles:
    The ride quality, even with Load Range E tires, seems to be much better than the Rugged Trails that were replaced (OE tires had just under 26,000 miles on them.) I attribute this to weight increase of each tire being better matched to the spring and damping rates of the OME lift. The RT's were 38lbs each and the new TAKO2's are 59lbs each. It seemed with the RT's that the suspension was very harsh over bumps, but the TAKO2's are much smoother.
    They ride pretty quiet, even more so than the RT's they replaced.
    I did some pre-emptive trimming inside the front wheel wells, and so far have not had any rubbing on street-usage. The front mudflaps were ripped off long ago (one literally by a curb, the second by my hands minutes later.) The TX Pro wheels are 16x7.5 with 4.62" of BS, which is just under the recommended 4.5" BS. Since I'm running LR UCA's, I have enough clearance there as well. I'm sure under some stuffing, I'll find a few more areas that need attention.
    Overall, with the limited experience so far, I REALLY like these new tires. As more miles get put on, I'll report back.
  11. Dec 1, 2014 at 3:12 PM
    #191
    Discount Tire
    Arizona, USA
    Your truck looks great, Scollins. Thanks for the detailed overview!
    @ShawnR - Thank you for your business. Let us know what you think of the tires after you get some drive time on them. We apologize for the loose hub/center cap!
  12. Dec 1, 2014 at 5:48 PM
    #192
    surfermatt
    CA
    Tires handle great in the rain on the street. I felt very safe.
  13. Dec 3, 2014 at 8:39 PM
    #193
    wheresjames
    wheresjames Member
    Picked mine up on Black Saturday from America's Tire. 265/75/16
    2014 Stock suspension, stock off road wheels with 1.25" Spidertrax wheel spacers all the way around.
    Big handling improvement over Rugged Trails. I can definitely feel the sturdier sidewall of the KO2 when turning and over rough roads. Slight rubbing on the flap in front of the front wheel well. Removed the front flap and all is good. I'm thinking I may have the tires flipped for the white lettering out and or mount them to 16" spare steelies.
  14. Dec 3, 2014 at 9:04 PM
    #194
    JimBCa
    JimBCa Well-Known Member
    Jim
    Bay Area California
    2012 TRD Off Road
    Build Duratrac 265/75R16 Load rated E BAMF Rock Sliders, Pelfreybilt Front bumper and skid plates (3) Pro Runner front and rear shocks,Add-A-Leaf springs ATO (Armor Tech Offroad) hilift mounts, Famous Fabrication cb antenna/flag mount CoverKing Tactical seat covers, Flyzeye dash-light ARE Shell, backup light mod SumoSprings and Stops
    Nice looking set Wheresjames.
    I just returned from 5 days on the Mojave Trail, mine performed perfect. Went from one foot thick sand to volcanic rock. Aired down to 26# and had good ride as we moved on and off dirt. Going down and back, hit some heavy rain, no slipping or sliding, and felt pretty secure in them.
  15. Dec 3, 2014 at 9:11 PM
    #195
    wheresjames
    wheresjames Member
    Thanks the trip sounds awesome, can't wait until the holidays are done and I have some energy for a road trip. :)
  16. Dec 3, 2014 at 9:36 PM
    #196
    JimBCa
    Jim
    Bay Area California
    2012 TRD Off Road
    I will post some pics this week, but this ride, while really fun, do not go alone. Have another vehicle.
  17. Dec 4, 2014 at 7:40 AM
    #197
    Discount Tire
    Arizona, USA
    Thanks for your support. Your rig looks awesome.
    Thanks for your ride report. Sounds like the tires are working good for you.
  18. Dec 4, 2014 at 12:20 PM
    #198
    zeekevin
    zeekevin Well-Known Member
    San Diego
    Is there any chance bfg will release the other size tired (285-70-17) sooner then March 2015?
  19. Dec 6, 2014 at 4:45 PM
    #199
    Hollywood22
    Hollywood22 Wranglin the Badger
    Johnny
    Southern Ontario
    Generation X
    OME Lift, LR UCA's
    ^^^This? And will it be available in anything other than load range E? E is over kill for my application but want to size up. Have 265 70 17's load C and love them.
  20. Dec 6, 2014 at 9:03 PM
    #200
    surfermatt
    CA
    I disagree, the KO2s are doing great on wet roads, maybe because the added siping, and excellent just like the KOs in sand. I do agree on the mud though...
    but if you want MUD performance get a MUD terrain tire.
