BFGoodrich All Terrain T/A KO2
Discussion in 'Wheels & Tires' started by Discount Tire, Sep 15, 2014.
  1. Nov 22, 2019 at 8:11 AM
    #2101
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    I dont think so. But you can always check their website for available sizes and specs
  2. Nov 22, 2019 at 8:17 AM
    #2102
    Armedine
    Armedine Well-Known Member
    St George, UT
    2020 TRD Sport 6' 4WD
    Quicksand
    rubiconjp likes this.
  3. Nov 22, 2019 at 1:00 PM
    #2103
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    Not when I bought them
  4. Nov 22, 2019 at 6:10 PM
    #2104
    normb
    normb Member
    So Cal
    12 D/C TRD O/F
    I want to put on BFG T/A K02 275/70R17 on my 2015 DC TRD O/R. The tires are supposed to be 32.2 inch diameter.
    I went searching in junk yards for 17 x 7.5 wheels from a 2nd gen Tacoma. Luckily, and not surprisingly, they have the same offset as the stock 16 inch rims. I found 5 of the alloy 5 spoke rims for $350, but they charged me $20 each for center cap (I only got 4). So 5 rims for $430.
    I have a 2" lift with OME BP51Bs and Built Right UCAs. When I put the lift kit on, a weight on the inside of the 16" rims rubbed on the LCA. They put on 1.25" spacers and rub be gone.
    So here is the standard question.... Will the BFG T/A K02 275/70R17 rub? I do not want to do a CMC or rip out fender well liners. Lose or modify the mud flaps...things are a PITA when I off-road anyway...so I am likely OK with that option.
    Will I need the spacers on to avoid rubbing the new set up on the frame, suspension or wheel wells?
    Will the BFG T/A K02 275/70R17 fit the spare storage on a 2015 Tacoma DC TRD O/R (short bed)?
    Thanks.
    Norman
  5. Feb 15, 2020 at 5:32 PM
    #2105
    INT.EGRATED
    INT.EGRATED Well-Known Member
    San Francisco, CA
    2006 Lexus GX470
    I'm looking at AmericasTire website and trying to get a 315/70-17 KO2 in C-load and the load index I see is 113S with load range C, but then there's an OE Designation of FORD/LINCOLN/MERCURY. Do these OE designations matter?
  6. Feb 15, 2020 at 6:17 PM
    #2106
    PreTaco170
    PreTaco170 Well-Known Member
    Russ
    St. John’s County
    2009 PreRunner DCSB TRD OR
    Bilstein 6112/5160, Dakars, JBA UCAs, FN f(x) Pro 17x8, 285/70R17(C) BFG KO2, Wheeler's Off-Road Bumpstops/U-bolt flip kit, CMC, Marlin Crawler HD LCA Frame Brace Kit, TRD CAI, Flowmaster exhaust, Alpine iLX-407 CarPlay receiver
    No, it shouldn't matter. They do the same thing with the 285/70R17 in C-load and it says OE designation for Jeep because they made that tire for the Rubicon. I believe the 315/70R17 C might be for the Raptor but not sure as I would have thought it would have an E-load. But I also believe it is only a half-ton which makes a C-load make sense.
    INT.EGRATED[QUOTED] likes this.
  7. Feb 17, 2020 at 11:05 AM
    #2107
    Discount Tire
    Discount Tire [OP] Tire & Wheel Specialists Vendor
    Arizona, USA
    @INT.EGRATED - @PreTaco170 hit the nail on the head, the 315/70R-17 LR-C "FO" is the O.E. tire for the Ford Raptor. This tire can certainly be run on other non Raptor applications as long as the tire is properly load rated for the vehicle application and approved for the intended wheel rim width.
    I'll add that O.E. specific tires are designed for the specific vehicle they are equipped on and may differ from that of the catalog version. In other words, there may be "tweaks" in the tire such as tread design to meet the needs set by the vehicle manufacturer.
    JCWages and PreTaco170 like this.
  8. Feb 17, 2020 at 12:53 PM
    #2108
    BigBeej
    BigBeej Well-Known Member
    Bryan
    Vista, Ca
    Do they make a 285/75/16 in a C rated tire?
  9. Feb 18, 2020 at 5:50 AM
    #2109
    Discount Tire
    Arizona, USA
    They do not currently, LR-E (10-ply rated) only. I don't believe any manufacturers actually offer anything lower than LR-D in the 285/75R-16 sizing. 285/70R-17 however, is a different story.
  10. Feb 19, 2020 at 10:31 AM
    #2110
    TacoTurboMan
    TacoTurboMan Well-Known Member
    San Jose, CA
    19 Super White TRD PRO
    If I go with KO2 in 285/70/17 (https://www.discounttiredirect.com/buy-tires/bfgoodrich-all-terrain-t-a-ko2) will I have to re-gear? And I noticed people on here usually run 265/70/17 vs 285/70/17..why is that? (aside from obvious MPG reduction). Also, what is the difference between the 116Q and 116S? I see that the Q is for the OE designation but will this really matter? They also differ in pricing..
    Btw I own a 19 TRD Pro. Mostly pavement driving but want that beefier look while also capable when going off road. I will also be installing 17 TRD Pro 4runner wheels.
    Sorry for all the questions, I just dont want to do it right the first time before I pull the trigger.
  11. Feb 19, 2020 at 10:37 AM
    #2111
    INT.EGRATED
    San Francisco, CA
    2006 Lexus GX470
    you will not have to regear, it is more of a convenience but with 33” aka 285’s its not as drastic as 35”. 265/70-17 does not require a cab mount chop or a lift (ymmv) and is bigger than stock by 1 size, but 285’s you do (99%) require a chop and lift.
  12. Feb 19, 2020 at 11:19 AM
    #2112
    PreTaco170
    Russ
    St. John’s County
    No worries about the questions, TW is a great place for that!
    The Q and the S are speed ratings on the tires. Q is listed as a max of 100 mph and S is listed as a max of 112 mph. I’m not sure how fast you drive and I can’t remember the top speed of our trucks but I don’t believe I have ever gone over 105ish in my truck.
    With that being said, I never get too concerned about speed ratings on my Tacoma tires because I barely ever drive over 85. Years ago, I had a fast 1989 Mustang 5.0 and I did concern myself with speed ratings then. :cool:
  13. Feb 28, 2020 at 9:29 AM
    #2113
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    I'm here to eat crow.
    For a few years I was running the 34" KO2 D's, and I thought they were perfectly fine. A couple months ago I switched to the 285/75 KO2's in E's, thinking that there wouldn't be a whole lot of difference coming from the D's. Well, that lasted for about 500 miles before I had had enough. Thankfully Discount Tire has absolutely baller customer service and they were willing to swap them out for just the difference in tire price. Wanting to stick with the same size tire the only option I had was the Ridge Grappler in C. I had them installed this morning and it was immediately a night and day difference. These ride so much nicer.
    The KO2's had never disappointed, so I'm bummed to be moving away from those. We'll see how the Nittos do on the trail....
  14. Feb 28, 2020 at 1:46 PM
    #2114
    OuchIDied
    OuchIDied Well-Known Member
    2021 Silver Sky Tacoma Off-Road
    I appreciate you coming back to say that. I'm at the end of the stock Toyos lives.
    I ended up ordering duratracs in the 265/70r16s.
  15. May 9, 2020 at 12:31 AM
    #2115
    JRLYON
    JRLYON Well-Known Member
    Portland, OR
    2020 Cement TRD Off Road DCSB
    KDMaxx Tuned Bilstein 6112/5160 set at 2” w/ 1.5” Icon AAL 2020 TRD Pro Shocks and Struts (no longer installed) 2020 TRD Pro 16" Wheels Goodyear Wrangler Duratrac 265/75/16 tires Alpharex LUXX Series LED Taillights Black/Red (no longer installed) 2020 TRD Pro Taillights TRD Performance Air Intake TRD Performance Exhaust TRD Front Skid Plate Tyger T3 Soft Fold Tonneau Cover TacoGarage Pro Grille w/OEM sensor garnish Taco Garage DSM w/ magnetic phone mount Runnin4Tacos Smoked Amber Grille Lights (CURRENTLY NOT INSTALLED) Runnin4tacos amber grille lights) Runnin4Tacos Lower Control Arm Skid Plates Katzkin Black Leather Interior with red stitching and TRD logo in seat back TRD Pro Shift Knob TRD Oil Cap TRD Radiator cap TRD Off-Road Special Tailgate badge JLT 3.0 Oil Separator Catch Can Demon Brackets w 3/4" red/black Autmatch D-Ring Shackles Black Emblems and Tailgate badge OEM Bed Lights OEM Predator Tube Steps AVS In Channel Window Visors MESO Total Tail Stage 1 MESO Ultimate Map Lights (Dual Color) (CURRENTLY NOT INSTALLED) MESO Ultimate Map Lights (White) MESO Ultimate Dome Light V2 (Dual Color) MESO Chrome Delete Kit Red MESO Customs Red Start/Stop Ring MESO Customs Red 4x4 Select Ring MESO Customs Red Start/Stop Button (Small Letters) MESO Customs V5 Ultimate Turn Signals (Reverse Sequential) MESO Customs TRD Stearing Wheel Emblem cover MESO Customs red door handle chrome delete (CURRENTLY NOT INSTALLED) MESO Customs black door handle chrome delete TVDVinylDecal red door sill protector letters TVDVinylDecal red glovebox letters Redline Tuning Hood Struts Diode Dynamics SS3 Pro Fog Lights (White) (CURRENTLY NOT INSTALLED)Diode Dynamics LED 194 HP5 Map Lights (CURRENTLY NOT INSTALLED) Diode Dynamics LED HP6 29mm Festoon Dome Light Bulb (CURRENTLY NOT INSTALLED) Diode Dynamics LED 28mm Fuse Vanity Bulbs Diode Dynamics LED 194 HP3 License Plate Bulbs Taco Vinyl TRD Grille Badge Black/Red Cupholderhero cupholder/door/pocket rubber liners Front Tinted Windows to match rear OEM tint OEM Tacoma Rubber Bed Mat OEM Tacoma Bed Extender Tacos4Cheap TRD Coin Box JDMCAR Glove Box Organizer Insert JDMCAR Center Console Organizer Insert CeramicPro 9h Lifetime Ceramic coating
    I cant decide between Goodyear Wrangler Duratrac or BFG KO2. Had Duratrac on my 2000 Tundra and loved em and had KO2 on my 2019 4Runner and loved em. Also if I go KO2 do I get the DT version? Not sure what to do
  16. May 9, 2020 at 6:16 AM
    #2116
    OuchIDied
    I think you'd be happy with either by the sounds of it. I personally went for the Duratracs in 265/70/R16 in the SLs. I didn't need LT tires because my offroading would be limited, but I definitely needed something that could handle occasional fields, camps, and snowstorms.
    I wanted to KO2s, but could only get E Load. That felt like overkill to me.
    Also before I got the Duratracs, thought they were ugly af and would look like crap on a Tacoma. Turns out they're a sexy tire. There's little GY symbols on the sides of the tread blocks and the sidewall tread looks good. They fill up the wheel well with even the stock size.
    JRLYON[QUOTED] likes this.
  17. May 9, 2020 at 8:14 PM
    #2117
    JRLYON
    Portland, OR
    Yeah ill probably go with Duratrac. Just street driving with an occasional unpaved dirt or gravel road to go fishing along with thr maybe 0-4 days lf snow each year we get in Portland, OR
  18. Sep 2, 2020 at 11:22 PM
    #2118
    Tacochan
    Tacochan Well-Known Member
    Alaska
    23 TRD OR
    Has anyone sourced 265/75/16 KO2s with black sidewall letters? According to BFG website, they no longer offer them? White lettering is a turn off.
  19. Sep 3, 2020 at 5:23 AM
    #2119
    Northern Taco
    Ummm, just mount them white letters in.......
    If the white letters in still bother you, take a black sharpie to them. You won't see them
  20. Sep 3, 2020 at 5:30 AM
    #2120
    BRIANMTEW
    BRIANMTEW Well-Known Member
    2020 TRD Pro Tacoma Army Green
    Yeah, one side is usually white while the other is black.
    TRD2010SpeedwayBlue likes this.
