BFGoodrich All Terrain T/A KO2
Discussion in 'Wheels & Tires' started by Discount Tire, Sep 15, 2014.
  1. Dec 16, 2014 at 7:32 AM
    #221
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    While there, make sure they remedy the tpms issue. that's nonsense
  2. Dec 16, 2014 at 7:36 AM
    #222
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    There is a button under the steering wheel that re-sets the TPMS. set the 4 tires to 32psi, then read the owners manual on the correct procedure to "set" the TPMS. i think you just have to hold the button while the truck is running.
    btw i love the wheels, i don't say that very often.
  3. Dec 16, 2014 at 7:54 AM
    #223
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Reseting the TPMS psi setting is easy
  4. Dec 16, 2014 at 8:01 AM
    #224
    BAJAxMIKE
    BAJAxMIKE Well-Known Member
    Sa,TX
    2013 Tacoma BAJA
    thanks much!
    ....and yes (tpms)they are working fine now just need to reset them.
    And due to mud and rock krawling areas being more easier to access i would rather get the km2's
    not to say rough, hard dirt and city hwy driving these tires(ko2's) are great.
    these are 10ply tires so im sure they are more rough than the oem bfg's but they have less than 500miles on them and at this point half the time of the ko2's is in the mud which they don't do too well on so far. I plan on testing them again this weekend if I don't make the switch
  5. Dec 16, 2014 at 8:12 AM
    #225
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Correct but I would set mine for 2-3 psi under what you decide you want to set your tires at. That way you don't have a light on if you have a cold morning and lose 1 psi. Just lower the pressure on all tires reset your system and then bump them back up again.
  6. Dec 17, 2014 at 5:04 AM
    #226
    BAJAxMIKE
    Sa,TX
    2013 Tacoma BAJA
    so I set the tires at 25psi while going thru dirt and seems to absorb the terrain way better as far as comfort, the mud has dried up so waiting to test it out on the mud
  7. Dec 17, 2014 at 6:08 AM
    #227
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    a little centrifugal force could solve all your mud issues by the looks of it
  8. Dec 17, 2014 at 10:10 AM
    #228
    Taco Libre
    Taco Libre Well-Known Member
    JohnnyHildo
    Saskatoon, SK
    2008 Black 4x4 Access-Cab TRD OffRoad
    Rear TSB, 5100s @ 0, Toytec 3" lift, Total Chaos UCAs
    saw the ko2's finally in person the other day and have to say that the pictures don't do them justice. the rugged looking shoulder is a bonus to an already proven tread design so i can't see how these would be bad in any way for the guy that uses an all-terrain tire
    NeedmoreTaco likes this.
  9. Dec 26, 2014 at 5:29 PM
    #229
    NashvilleTaco
    NashvilleTaco Member
    Hi all,
    Bought these in 265/75/16 for my 2014 TRD OR. Costco informed me that they will not install if they rub at all. Got me a little worried. Anyone have this setup that can comment?? Preemptive measures I can take?
    Also, any pics with this setup.
    Thanks!!
  10. Dec 26, 2014 at 5:37 PM
    #230
    Hollywood22
    Hollywood22 Wranglin the Badger
    Johnny
    Southern Ontario
    Generation X
    OME Lift, LR UCA's
    ^^^^ If you are running stock wheels they shouldn't rub at all.
    I have BFG KO's 265 70 17's (which is essentially the same size as yours) on stock wheels and they do not rub at all. When I had the Stealth Six's on over the summer they rubbed due to the offset.
  11. Dec 26, 2014 at 5:39 PM
    #231
    NashvilleTaco
    Completely stock. I hope they don't rub... I had read some places the KO2's are slightly different in width than the KO's.
  12. Dec 27, 2014 at 8:39 AM
    #232
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    I have the 265/75/16 on stock aluminum wheels, no lift, 100% completely stock, 2014 v6 base crew cab, and they clear everything very well. No rubbing anywhere at all. You should be good to go. Which mine arent the new version AT either.
  13. Dec 27, 2014 at 3:26 PM
    #233
    speyguy
    speyguy Well-Known Member
    Access Cab 4x4 SR5
    Extang Trifecta, BFG AT, Weathertech Digital Fits, AVS Bug Deflector II
    Just picked up 4 of the new KO2, 265/75/16, really like the look of these on the truck.
    2012 AC 4x4, stock no lift. I have zero rub froward or reverse at full lock left and right. I was running the original KO before this in a 265/70/16, they were a load range D.
    So far I have to say the new KO2 are much quieter at highway speeds than the original KO. Pretty good road manners as well, rock solid on the highway. Today was the first time I had them in the dirt but nothing heavy. No issues in rocky sandy soil. Got into a bit of mud and they cleaned out ok once I got on the throttle, honestly it was nothing serious though so not a real good test.
    Interested to see how they perform once we get some snow, pretty green here right now. I will chime back in once we get some snow.
    Did a little bunny hunting today but no luck, my trip turned into a spring trout hole scouting run instead, which was not a bad thing :)
    New trout hole for the spring
  14. Dec 28, 2014 at 8:55 PM
    #234
    7A7ER
    7A7ER FLYNN LIVES!
    AL
    '05 Radiant Red Tacoma XCab PreRunner TRD
    Removed Step Bars, Hood Visor, OEM Bed Mat, Window Tint, Fog Lights Anytime, BFG All-Terrain KO2s, Removed Mud Flaps, Add A Leaf Recall, Color-Matched Grill and Bumper& Plasti-Dipped Badges!
    You Guys Rock! I just ordered these delivered to my house for $100 cheaper than tire rack! and that included FREE UPS Shipping and a $25 Online Discount...Thanks Discount Tire Direct and all the 265/75/16 Testimonies!
    Will Post Pics once they are delivered in 2-5 days!
  15. Dec 29, 2014 at 8:27 AM
    #235
    IronBagel
    IronBagel Well-Known Member
    Jake
    North Carolina
    2009 DCSB
    Little update on mine seeing as I've had them for about a month now. They've been extremely great so far in a variety of conditions. My daily commute at the moment is an unpaved road up the backside of a mountain and I have no complaints from the tires. I can now do this road in 2wd even when it's a little muddy! It was almost impossible to do it in 2wd on my old tires even in the best of conditions! In light snow they've held grip really well and felt a lot more stable than my old Dunlop Rovers. Overall I'm super impressed, they haven't even made too much of an impact on my mileage either which was a concern of mine.
  16. Dec 29, 2014 at 10:16 AM
    #236
    Discount Tire
    Discount Tire [OP] Tire & Wheel Specialists Vendor
    Arizona, USA
    You rock, 7A7ER! We appreciate the shout out :cool: We look forward to helping you again in the future.
    We guarantee the lowest out the door price on all the products we carry. If a competitor has a cheaper advertised out the door price, we'll beat it :cool: PM coming your way.
  17. Dec 29, 2014 at 3:30 PM
    #237
    Discount Tire
    Arizona, USA
    Very sharp!!! Thank you for sharing, Gelo. We appreciate your support :cool:
  18. Dec 30, 2014 at 5:57 AM
    #238
    FooBird
    FooBird Well-Known Member
    Kirkland, WA
    '14 DCSB 4x4 TRD Off Road
    I didn't have any rub with the tire on my 2014 TRD-OR. They are close on clearances but don't rub given you have the stock wheels.
  19. Dec 30, 2014 at 6:07 AM
    #239
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    Just got my $70 gift card from BFGoodrich for buying my KO2s last month. Don't forget to take advantage of this!
  20. Dec 31, 2014 at 2:45 PM
    #240
    NashvilleTaco
    Just got them put on. No rub at all, look freaking amazing. Drive just as well as the rugged fails. No rain yet, but sure they will blow them out of the water. Will get more pics at some point, it was freakin cold.
    And yea, that is some front end damage. Getting that fixed right after the new year.
    Dirtbag27 likes this.
