BFGoodrich All Terrain T/A KO2
Discussion in 'Wheels & Tires' started by Discount Tire, Sep 15, 2014.
  1. Apr 16, 2015 at 9:47 AM
    #501
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    Maybe I'll try them at 35 then.
  2. Apr 16, 2015 at 9:54 AM
    #502
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    The dealer and any tire shop will always put your tires at the door PSI regardless of them asking you.
    You have to tell them upfront that you are ok with them putting it at an "Unsafe" PSI amount as they claim its illegal.. LOL I laughed in the oil change techs face at the dealer last weekend.
    My truck came in with 35 and was leaving with 29.. I made them put the tires back at 35, I noticed on my receipt they messed with it and noted a bunch of dumb stuff that needed replacing, Timing belt, Water pump, Battery, Leaking valve covers, broken windshield washer container neck..
    I run a yellow top Optima 2 years old, timing belt was done 60k ago, windshield washer neck had duct tape on it, valve cover gaskets were done 10k ago and needed tightened.
    Also fun fact, most places have 1-2 guys that can drive a stick.. Hilarious.
  3. Apr 16, 2015 at 12:10 PM
    #503
    JBecker
    Virginia
    Well the tire shop I went to had them way over inflated.
  4. Apr 16, 2015 at 12:16 PM
    #504
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    rookies.
  5. Apr 16, 2015 at 1:01 PM
    #505
    ASUAviator
    ASUAviator Well-Known Member
    Anchorage, AK
    Tacoma TRD Off Road
    Got mine a month ago. Very happy with the handling and look. There was a noticable difference in throttle response going from the stock tires to these. More torque to get heavier wheels turnin. Lost a mile or 2 per gallon. I dont regret it though!
    Caliph420 likes this.
  6. Apr 16, 2015 at 1:18 PM
    #506
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    Pfft who cares about gas mileage anyways :D
  7. Apr 17, 2015 at 5:14 PM
    #507
    einsteinwv
    einsteinwv Member
    William
    Tulsa Oklahoma
    I got a set of SCS SR8 Wheels that should be on my doorstep Monday. And I called and got a quote on some of these locally and they are getting me a set in size 265/75 R16. Question is I shouldn't need any spacers or anything as I have a 07 Double Cab offroad. Trying to max out my tire size until I can talk my wife into a lift and from research this is my max. I'm just making sure I couldn't see any other issues going with the new wheels at the same time.
  8. Apr 17, 2015 at 5:23 PM
    #508
    yellowssm
    yellowssm Well-Known Member
    Toyota Tacoma SR5 4x4
    when I went to 265/75/16 on my oem wheels with all stock suspension on my 15 4x4 double cab, i rubbed pretty bad on the mudflaps. I didnt trim though as I added spacers and billstein 5100's/OME 885's (2" lift in front and 1" in the rear) and that solved my rubbing issues
  9. Apr 17, 2015 at 7:59 PM
    #509
    millertime89
    Erik
    Saskatchewan
    Yes sir
    Just tell your wife that you're actually saving them money by investing in a lift now and getting the tires in the size you want with your lift rather than investing in tires, eventually getting a lift, and then realizing you wanted a bigger size tire and you now have to convince her to let you get another set of tires :D
  10. Apr 17, 2015 at 8:13 PM
    #510
    yellowssm
    Just finished a tank of gas with the new tires 265/75/16, tonneau cover, spacers, 5100's, ome springs, 1" block in the rear. When the car was all stock I got 300 miles before the low gas light just came on, now with all the mods it came on at 280 miles. Quite surprised I only lost roughly 1 mpg with these heavy tires and spacers. Still loving these tires!
  11. Apr 17, 2015 at 9:21 PM
    #511
    millertime89
    Erik
    Saskatchewan
    Yes sir
    Accidentally unsubbed :popcorn:
  12. Apr 18, 2015 at 6:57 AM
    #512
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Been in Hungry Valley cali.ohv park And so for so good. More skinny pedal for hill stuff but with no loss of traction.
  13. Apr 18, 2015 at 11:36 AM
    #513
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Your odometer is turning slower with the 1" taller tires... so don't put all the blame on the tire, as you drove more miles than the odometer is telling you.
    With 265/75-16 on instead of the stock 265/70-16, my speedometer (which read fast with stock tires) is now accurate, but my odometer is 10 miles slow for every 400 miles driven (2.5%).
  14. Apr 22, 2015 at 8:04 PM
    #514
    Got Tacoma 4 x 4
    Got Tacoma 4 x 4 Member
    Phoenix
    2010 Tacoma TRD 4 x 4 Dbl Cab Short Bed
    I emailed BFG 3 days ago asking them if they will release a KO2 LT265/70r/16 in load range D and they said that size will only be manufactured in load range E. I keep them inflated to 42psi. I currently have KO 265/70r/16 load range D for several years and have lost 2 to 3 mpg combined city/highway compared to the rugged trails. Highway mileage @65mph is 19 to 20 mpg. Highway mileage @75mph it drops to 17 to 18mpg. My KO's load range D weigh 49 lbs and KO2 load range E weigh 50 lbs. How much more mpg will I loose with higher rolling resistance load range E tires? One way to find out. I can't imagine loosing even more mileage with an LT 265/75r/16.
  15. Apr 23, 2015 at 6:14 AM
    #515
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Why would you assume a E has higher rolling resistance than a D if they are the same weight and size? I can't find any information anywhere the correlates load rating with rolling resistance. Certainly in general higher load rated tires may weigh more and that would increase rolling resistance - but in this case the weights are nearly identical.
    According to an article on Tire Rack:
    I'm guessing the KO D vs. the KO2 E are if not identical in rolling resistance they certainly are within 10% meaning the impact to fuel economy is essentially impossible to measure.
    When you went from Rugged Fails to the KO you went from a 38 lb P rated tire with a 10/32 tread depth to a 49 lb LT tire with a 15/32 tread depth. That's a huge change in weight and a big change in tread depth too (more tread depth means higher rolling resistance). BFG rates those tire as having significantly different efficiency as well.
    In comparison the difference between the KO in D and the KO2 in E are negligible. At most 1 lb difference and essentially identical tread.
    You shouldn't notice any difference going between the two. Or more accurately, any difference you see is going to be the difference between an older worn tire and a new tire with full tread depth.
  16. Apr 23, 2015 at 7:21 AM
    #516
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    The thing most of us who aren't keen on going with a Load-range E are worried about is the weight difference. There's very few tires that are offered in both so I'm going to use the Goodyear Duratrac for comparison. The difference in load-range C vs E at the same size (265/75/16) is 6 pounds. 6 pounds per tire has a significant impact because of the inertial mass that you have to both spin up on acceleration and spin down while braking. Sure in gross vehicle weight it's the same as only 3 gallons of water in your back seat, but it affects fuel economy a lot more than just 3 gallons of water.
  17. Apr 23, 2015 at 12:01 PM
    #517
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Hmmm...good stuff here
  18. Apr 23, 2015 at 2:10 PM
    #518
    Hublocker
    Hublocker Well-Known Member
    Does anyone have any snow or ice experience yet?
  19. Apr 23, 2015 at 2:28 PM
    #519
    Theloden
    Theloden Well-Known Member
    Joe
    Lakes of the North, Michigan
    '23 TRD Off Road
    Yup, drove on mine all winter long through some pretty deep snow cover since they don't plow my road at all. They worked great and never had an issue even when I was crawling through 10+ inches of the white stuff.
    Ice, well with ice you're going to have a hard time with most tires but I wouldn't say they were bad. Just easy on the throttle and let the TCS do it's thing to get grip.
  20. Apr 23, 2015 at 3:10 PM
    #520
    Hublocker
    Thanks. I'm on the West Coast of Canada where we have rain but now snow. Just 100 miles East though, we get snow from October until March. I need a real all-season tire.
