BFGoodrich All Terrain T/A KO2
Discussion in 'Wheels & Tires' started by Discount Tire, Sep 15, 2014.
  1. Aug 13, 2015 at 11:07 AM
    #741
    Discount Tire
    Discount Tire [OP] Tire & Wheel Specialists Vendor
    Arizona, USA
    I'm sorry to hear you are still having ride issues.
    According to the manufacturers spec sheet, the Fuel Trophy in the Tacoma 6-139.7 bolt pattern has a 108mm center bore diameter, making the wheels lug centric. See the spec sheet linked below for details.
    Do you know if hub centric rings were installed? If not, hub centric rings are available for this application which will make centering the wheels easier.
    http://www.fueloffroad.com/specs.cfm?id=3330&name=D551
  2. Aug 13, 2015 at 11:12 AM
    #742
    Tacoman2013
    Tacoman2013 Active Member
    2013 TRD off-road Tacoma
    Hub centric rings were not installed. The manager took the center cap off and showed me that there was no room for the rings and that the wheels were already hub centric. Everything I am coming across is confirming what you are saying and disproving what the manager is telling me. So from what you are telling me and what I have researched is that I need a hub ring for these lug centric wheels?
  3. Aug 13, 2015 at 11:32 AM
    #743
    Discount Tire
    Arizona, USA
    It's possible the spec sheet is wrong. I would call Ryan and ask him to order in a set of hub centric rings for you to at least test fit. The product code you need is 80504 (ring size 108-106.1).
    On a side note, you do not need to run hub centric rings but like noted earlier, they make centering the wheel on the hub easier. Check out this write-up we put together for more information.
    http://thesquealingtire.com/tech-write-ups/
  4. Aug 13, 2015 at 11:32 AM
    #744
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    This is exactly why I insisted on Hub centric wheels.
    My old Lug centric wheels were fine for the most part but if the installer was in a hurry, they always are.. and powered on my lugs with air tools then sometimes even if the wheel was balanced would sit funny.
  5. Aug 13, 2015 at 11:36 AM
    #745
    Tacoman2013
    Thank you! I just got off the phone with the store and they are calling the distributor and looking into some rings.
  6. Aug 13, 2015 at 11:38 AM
    #746
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Glad this is all working out for you, and you learned about lug and hub cetrics now. :)
  7. Aug 13, 2015 at 11:39 AM
    #747
    Tacoman2013
    I have. Hopefully they will get those on and this will be done with. Never considered any of this before, but then never had an issue either. Thanks again. I will let you know how it worked out
  8. Aug 13, 2015 at 11:44 AM
    #748
    Discount Tire
    Arizona, USA
    Thank you for keeping us posted, Tacoman. We appreciate your patience through all of this.
  9. Aug 13, 2015 at 11:51 AM
    #749
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    I had similar issues with my duratracs until I found a good tech who was able to rebalance them right at DT in Acworth - the tire needed to be moved on the rim, I asked them to do it before but they would not listen at another store, the last tech fixed the issue in 15min and the wheel in question balanced out just fine with a 3rd of the original weight
  10. Aug 14, 2015 at 8:12 PM
    #750
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    Ended up caving in.... www.4wd.com is running a sale and there was $50 off a set of 4 with free shipping... Just shy of $658 for a full set of 4 (265/75/16) shipped. Another $60 to get them mounted and balanced, can't say i'm disappointed at all at that price.... Really excited to see these on the truck despite my reservations with the heavy tires on an already under powered engine.
    http://www.4wd.com/eSearch.aspx?Ntk=primary&Ntt=BF+Goodridge+All-Terrain+T/A+KO2+Tires&utm_source=listrak&utm_medium=email&utm_campaign=20150813_4wd_tires_popular
    baldy77 likes this.
  11. Aug 14, 2015 at 8:17 PM
    #751
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    265/75-16r
    For sale socal only 50$
  12. Aug 18, 2015 at 3:58 PM
    #752
    snowmanwithahat
    For those of you with 265/75/16s what pressure are you running?
    I'm having mine installed tomorrow and was thinking of having them set then at 35 psi first and seeing how it goes.
  13. Aug 18, 2015 at 4:07 PM
    #753
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    35psi
  14. Aug 18, 2015 at 4:33 PM
    #754
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    35 for me as well.
  15. Aug 19, 2015 at 6:31 PM
    #755
    baldy77
    baldy77 Well-Known Member
    Albuquerque, NM
    05 TRD Offroad Doublecab Speedway Blue
    3" Toytec Adj Coilovers w/Bilstein 5100's front and rear, Toytec TSB AAL, LR UCA, Avid Weld-on Sliders, A.R.E. CX Topper.
    Thanks for the link. I ended up getting the price beat by a whole dollar at a local discount tire and paid $163 per tire. Great deal in my opinion and the truck rides so much smoother. The tires I had before were the bfg ko and they had 7 years on them. I probably could have squeezed out a few more miles out of them but the rubber was hard and I didn't feel confident driving on the highway on 7 year old rubber in the southern Arizona heat. Thanks again snowmanwithahat.
  16. Aug 19, 2015 at 7:04 PM
    #756
    snowmanwithahat
    So I got these mounted today, very impressed with the overall look and feel. I can't say I notice any real significant difference in power despite the 12lb per tire increase. We'll see if my MPG takes a hit after I get some time with these tires. Overall I was expecting more of a harsh feel but it didn't feel worse than normal, just different, slightly sturdier, but not harsh, if that makes sense.
    Overall a huge improvement visually compared to the previous set of tires, (OEM Rugged Trails).
  17. Aug 19, 2015 at 10:27 PM
    #757
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    :thumbsup:
    Mpg will take a hit. Mine did.
    But for the security i feel with the tire, it's worth it. Imop
  18. Aug 20, 2015 at 11:26 AM
    #758
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    Many people claim their mpg takes a hit. I have 275/70/17 and get an average 17 mpg. I run chevron or shell gasoline only though.
  19. Aug 21, 2015 at 7:30 PM
    #759
    Tacoman2013
    Well after spending pretty much all day at discount tire I returned the KO2's and have a set of Nitto Grappler G2 on order. I got the hub rings installed and still it did not go well. Way too much movement in the steering wheel. They suggested the G2's so I will be giving those a shot. Only down side is that they come in P or E ratings. I know I cannot touch the E load but I feel the P might be too light and weak. I don't think they have ordered them yet so I still have time. Would you guys suggest the P or the E? I wish the KO2's worked out but for some reason even after 4 balancing, whole new set of tires, hub rings, ET lugs they still shake like crazy. For now I have the stock tires on until my nitto's come in, at least no more shake
  20. Aug 21, 2015 at 7:42 PM
    #760
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    I have around 5k on my 265/75 BFG AT KO2 tires so far and I like them a lot. The handle fine on the road and they've passed the test during some pretty aggressive off-roading (crawling over rocks, creek beds, climbing creek banks, steep hills, etc). With the larger and heavier tire I lost about 2 MPGs on average with 80% highway driving during my work commute...oh-well.
    I'd definitely recommend the tires but if I could go back and buy again I'd probably go with 245/75 tires. A buddy of mine went with that size and they look great, with less impact on mileage and probably better in the snow.
