BFGoodrich All Terrain T/A KO2
Discussion in 'Wheels & Tires' started by Discount Tire, Sep 15, 2014.
  1. Mar 2, 2016 at 10:30 AM
    #1241
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    Should be good to go, maybe take the mud flaps off if they rub
  2. Mar 2, 2016 at 10:37 AM
    #1242
    jbentham84
    jbentham84 Member
    Jeremy
    Lake Grove, NY
    2012 Tacoma DCSB TRD
    3" Toytec Boss lift, all pro expedition rear leafs, Icon hydro bump stops, SS brake lines, 285 BFG AT's, Pro Comp Alloy's.
    Those are coming off anyway :)
  3. Mar 2, 2016 at 7:44 PM
    #1243
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    Yeah I've been through some bigger rougher type terrain and still did well. I didn't air down even though I should have. Probably would have been a walk in the park where I was.
  4. Mar 3, 2016 at 5:21 AM
    #1244
    3milecreek
    3milecreek MtnGoat
    Stephen
    Barnwell SC
    Heavily Modified 94 Yota
    Never the same
    Nice! I like to hear this.
  5. Mar 4, 2016 at 12:17 PM
    #1245
    TheTacoma
    TheTacoma Well-Known Member
    Birmingham, AL
    2017 DCSB, TRD OR 4x4, Quicksand. SOS Bolt-on Sliders. 285x75r16. Kings
    Just filled up first time with the new tires so that I could check the mpgs. I do all city driving, I lost 3mpg. I went from 18mpg with 245x75x16 street tires (came on the truck) to 15mpg with the 265x75x16 KOs. Worth every bit of it though!
  6. Mar 4, 2016 at 7:03 PM
    #1246
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    When you calculated your MPGs, did you take into consideration the 4% odometer error introduced by the larger diameter tires. Multiply the miles the ODO shows you went by .04, that will add back at least a 1/2 mpg to the average.
    NeedmoreTaco likes this.
  7. Mar 4, 2016 at 7:08 PM
    #1247
    NeedmoreTaco
    NeedmoreTaco Garage full of white Toys...
    Eric
    Travelers Rest, SC
    2012 Super White DCSB Prerunner
    LEDs and stuff
    Shouldn't you multiply it by 1.04 before doing your mpg calculations, not .04?
    Digiratus[QUOTED] likes this.
  8. Mar 4, 2016 at 7:49 PM
    #1248
    Digiratus
    Roaming the PNW
    The RedHead
    Yes, .04 shows what the error is. 1.04 ads it to the total.
  9. Mar 4, 2016 at 10:07 PM
    #1249
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    How do you figure out the percentage of how much bigger the newer tire is?
  10. Mar 5, 2016 at 12:41 PM
    #1250
    TheTacoma
    Birmingham, AL
    It almost added 1 more mile. It would be like 15.8mpg. lol whatever.
  11. Mar 5, 2016 at 1:22 PM
    #1251
    NeedmoreTaco
    Eric
    Travelers Rest, SC
    LEDs and stuff
    1-(old tire size/new tire size)*100 =percent of increase in tire size (let's use P)
    To figure gas mileage with new tire size...I believe I may be a little off here but basically if it's a 2% increase use 1.02 for the first number.
    ((P*100)*trip mileage)/gallons=mpg
  12. Mar 5, 2016 at 1:40 PM
    #1252
    99TacoDriver
    South Louisiana
    I went from 265/70/17 which is 31.6 in according to tire size calculator
    Now I have 275/70/17 which is 32.2
    So it's about 1.7% difference.
    Just filled my tank today and had 14.34 gal. And 268 miles
    Soooo (268*1.017) / 14.34 = 19.0 mpg
    Is this correct or should I be going from the stock tire size that comes with the truck?
  13. Mar 5, 2016 at 1:54 PM
    #1253
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    I swapped out KO2s with some Michelin LTX ATs hoping the reduced resistance and few pound of weight difference would make a difference. It did not - at least not a noticeable difference. I ended up putting the KO2s back on my 4x4.
  14. Mar 5, 2016 at 2:35 PM
    #1254
    NeedmoreTaco
    Eric
    Travelers Rest, SC
    LEDs and stuff
    Calculation is correct but I would use stock tire size since that's what the odometer is calibrated for.
    99TacoDriver[QUOTED] likes this.
  15. Mar 5, 2016 at 7:09 PM
    #1255
    99TacoDriver
    South Louisiana
    Wow. So when i correct it it's a 5.4% difference and I actually get 19.6 mpg
    I really hope it's true lol that's awesome
    BTW after learning this my brother and I made an excel spreadsheet so now all we gotta do is put milage and how much it took to fill up and it spits out what the adjusted milage is.
    I'm happy I've learned this because now you can also calculate how many miles the truck actually has
  16. Mar 6, 2016 at 8:04 AM
    #1256
    99TacoDriver
    South Louisiana
    My question now is: how does the new tire width play into the equation?
    I was thinking that extra width would play into it but I'm not sure if it actually needs to be calculated in
  17. Mar 6, 2016 at 11:22 AM
    #1257
    tx_shooter
    The best way to check what you adjusted mileage is involves a GPS tracker app on your phone and a known distance of driving.
    99TacoDriver likes this.
  18. Mar 7, 2016 at 12:19 PM
    #1258
    Liquidmantis
    Liquidmantis Well-Known Member
    2016 MGM 4R TEP w/KDSS
    Your tire could be three feet wide and the calculation wouldn't change. I suspect your mileage wouldn't be eco friendly but you'd calculate based on the same system of circumference times number of revolutions.
    Brian007Taco likes this.
  19. Mar 7, 2016 at 3:25 PM
    #1259
    99TacoDriver
    South Louisiana
  20. Mar 8, 2016 at 8:17 PM
    #1260
    Kwik
    Kwik Well-Known Member
    Kyle
    Seattle
    2011 Tacoma 4x4 2.7L
    Are your 265 70 17's in Load range C? If so what PSI have you found they ride best with?
