BFGoodrich All Terrain T/A KO2
Discussion in 'Wheels & Tires' started by Discount Tire, Sep 15, 2014.
  1. Aug 19, 2016 at 3:56 PM
    #1441
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    MCObray likes this.
  2. Aug 19, 2016 at 4:06 PM
    #1442
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    Looks pretty good IMO.
  3. Aug 20, 2016 at 3:59 PM
    #1443
    Jgchfd
    Jgchfd Well-Known Member
    James
    Kentucky
    2016 Tacoma SR5 DCSB
    Can you give us specific info on how?
  4. Aug 21, 2016 at 4:27 AM
    #1444
    tx_shooter
    How low was the psi?
  5. Aug 21, 2016 at 12:08 PM
    #1445
    tx_shooter
    Yeah; pretty weird.
  6. Aug 21, 2016 at 1:11 PM
    #1446
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    That looks like a tailings pile... They hide all kinds of sharpbshit in those.
  7. Aug 27, 2016 at 1:35 PM
    #1447
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    I'll be having 265/70r17 KO2's put on Monday. I'm expecting a 10% drop in fuel economy from what I've read here, which is fine. The stock Dungflops are getting pretty ragged around the edges and the sidewalls pretty beat.
    MCObray and MARK97XP like this.
  8. Aug 29, 2016 at 5:06 PM
    #1448
    randomguy
    The Dalles, OR
    17 T4R 4x4 MGM
    Just picked my truck up. Love the new look it has. Installer set the pressure at 45, I promptly dropped it down to 35. Being as these are E rated I may end up going down even lower. It's too soon to really tell any major difference. Truck is about a half inch taller now. I ended up with the E rated tire.
    I have to say I am rethinking my plans for lifting and may just go with Eibach 1.6" in the front and bags in the rear for loads. I'm an that pleased with how the truck looks and handles other than the desire to be level.
  9. Aug 30, 2016 at 10:49 AM
    #1449
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    Looks perfect. I would just get the front up a 1" and call it good.
    randomguy likes this.
  10. Aug 31, 2016 at 8:16 PM
    #1450
    PFD FIRE
    PFD FIRE Well-Known Member
    David
    San Diego
    2011 Toyota Tacoma TRD Sport
    265/75/16 Goodyear Duratrac Tires, Total Chaos UCA, Bilstein 6112 Coilovers (front) Bilstein 5100 (rear), TRD CAI, TRD Cat Back Exhaust, Rough Country/Lamphus LED lights, rear ARB locker, Baja Rack
    Im thinking about going with the BFG Ko2 275/70/17's. As far as lift is concerned, is a 2.5 inch lift be more then enough for this size tire? I currently ride with Bilstien 6112 adjustable shocks in the front that can adjust up to 2.5 inches. Don't want the rubbing.
  11. Sep 1, 2016 at 3:39 AM
    #1451
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Check your uca clearance. They may be pretty close now if you're running 265's. You may rub the frame at full lock at that size also.
  12. Sep 1, 2016 at 7:08 AM
    #1452
    randomguy
    The Dalles, OR
    17 T4R 4x4 MGM
    First 200 mile trip under my belt. I was lazy and didn't fuel up to check economy loss, though I'm not optimistic with this tank. I drove a little faster than usual into a head wind, which usually got me 18 mpg max with the stock tires, and traveled 100 miles of winding forest service roads.
    On the plus side the KO2s with 35lbs of air in them did awesome. Maybe my stock Grandtreks just sucked so bad but the ride and handling were both great. Traveling over washboards wasn't as bad either. I failed to slow down for a couple 20mph corners and not even a sign of squeal with these where the Dungflops would be singing.
    I'm going to be replacing my stock mud flaps with Husky's sooner than later. The trimming I did on the front was great for the Dungflops but these BFG's really pick up the debris and throw it and I need a little more length.
  13. Sep 1, 2016 at 9:15 AM
    #1453
    hungrycoyotes
    hungrycoyotes Active Member
    Tyler
    Vancouver, WA
    2010 Taco 4x4 Dblcb
    Flowmaster 40 muffler, LED Bed Lights, AFE Drop In Filter, BFG KO2 265/70/17
    Truck looks nice. I finally bit the bullet and bought KO2 in 265/70/17 with C load rating. Currently running them at 35 psi.
    Those Dunglops were downright unsafe in any sort of weather. Will report back once I get some miles under these tires.
    old55guy, randomguy and MCObray like this.
  14. Sep 4, 2016 at 10:09 AM
    #1454
    ChrisSandstorm
    ChrisSandstorm Well-Known Member
    '01 Land Cruiser, '16 TRD OR DCSB
    I just purchased 4 285/75/16 via 4Wheel parts!
    They are running that special no tax, no shipping, 50.00 off and then BFG has the 50.00 rebate.
    So pretty good deal, 857.00 out the door and then the 50.00 rebate.
    I am debating of putting on stock OEM 16s or buying TRD Trail teams in Black..
    I think I would prefer not to mark up my Daily Driving wheels and save the OEms for daily driving.
    Sounds like I might have some minor heat gun modding to remove rubbing.
    Will also have 2-2.5" lift and install my SPC UCAs soon
  15. Sep 4, 2016 at 7:23 PM
    #1455
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    Just purchased 265/75/16 god I hope I like them and they don't hurt ride and mpg too badly...
  16. Sep 4, 2016 at 9:27 PM
    #1456
    ChrisSandstorm
    uh, you will like them and they will be bueno!
    I saw them on another Taco today and I was like, hey those are the tires I am getting.
  17. Sep 4, 2016 at 9:28 PM
    #1457
    ChrisSandstorm
  18. Sep 5, 2016 at 9:52 PM
    #1458
    randomguy
    The Dalles, OR
    17 T4R 4x4 MGM
    I have 265/70r17's in a load range E. Ride is great, better then the Dungflop Grandtrek AT20's the truck came with.
  19. Sep 6, 2016 at 9:24 PM
    #1459
    MARK97XP
    MARK97XP Well-Known Member
    Mark
    Spokane
    03 SC DC 4WD TRD OR
    Hopefully someone can chime in on this. 03 DC 4WD taco with 70K. I got BFG KO1'S 265/70 16 on right now with 58K on them. Even with the stock size they rubbed up front on frame at full lock both sides but not bad. Im wanting to get 265/75 KO2's cause there like $40 cheaper a tire. Will they rub worse, not as much or not at all?
  20. Sep 6, 2016 at 9:48 PM
    #1460
    MARK97XP
    Mark
    Spokane
    03 SC DC 4WD TRD OR
    I know there an inch taller but not as wide.
