BFGoodrich All Terrain T/A KO2
Discussion in 'Wheels & Tires' started by Discount Tire, Sep 15, 2014.
  1. Sep 7, 2016 at 5:25 AM
    #1461
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    They're just as wide too. "265" in 265/75/16 is a measure of the width in millimeters.
  2. Sep 7, 2016 at 6:17 AM
    #1462
    MARK97XP
    MARK97XP Well-Known Member
    Mark
    Spokane
    03 SC DC 4WD TRD OR
    From the specs sheet it says the 265/75 is slightly thinner at the tread width. 8.5" compared to 8.7" for the 265/70. Prolly not gonna help me though im guessing. :annoyed:
  3. Sep 7, 2016 at 6:19 AM
    #1463
    snowmanwithahat
    That may be a difference in how it's manufactured, but "all" 265s are supposed to be the same width. That's probably just due to tolerance differences in the moldings and the fact that they will be a slightly different shape when inflated.
  4. Sep 7, 2016 at 6:22 AM
    #1464
    snowmanwithahat
    http://www.tirerack.com/tires/tiret...ained&ef_id=V7TVXgAABBwhTYII:20160907131946:s
    Section Width
    Following the letter(s) that identify the type of vehicle and/or type of service for which the tire was designed, the three-digit numeric portion identifies the tire's "Section Width" (cross section) in millimeters.
    P225/50R16 91S
    The 225 indicates this tire is 225 millimeters across from the widest point of its outer sidewall to the widest point of its inner sidewall when mounted and measured on a specified width wheel. This measurement is also referred to as the tire's section width. Because many people think of measurements in inches, the 225mm can be converted to inches by dividing the section width in millimeters by 25.4 (the number of millimeters per inch).
    225mm / 25.4 = 8.86"
  5. Sep 7, 2016 at 9:53 AM
    #1465
    MARK97XP
    Mark
    Spokane
    03 SC DC 4WD TRD OR
    Would running spacers up front solve this and how much?
  6. Sep 7, 2016 at 10:34 AM
    #1466
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    KO2's getting it done!
    Broken Arrow in Sedona Arizona.
    Turkey Creek going from Bumble Bee Road to Crown King Road near Crown King and Cleator, Arizona.
    Note: Not my pic, but it is my truck.
  7. Sep 7, 2016 at 5:27 PM
    #1467
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    First tank on the E rated KO2's at 17.3 mpg with 150 miles of forest roads with intermittent 4wd use and 175ish miles of winding mountain highway. I am pleased as my stock tires got about the same under similar conditions. For the record I am not correcting for the 3.5% difference in size. I'm currently running 35 psi all around.
    Brian007Taco and hungrycoyotes like this.
  8. Sep 7, 2016 at 5:31 PM
    #1468
    MARK97XP
    Mark
    Spokane
    03 SC DC 4WD TRD OR
    Running the original TRD off road star wheels, I believe there 4.5 BS
  9. Sep 7, 2016 at 8:55 PM
    #1469
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Those Pro Comps are 4.5" of BS
    Close.
    +15 mm offset on a 7" wide wheel. It ends up being 4 9/16" of BS
    m3bassman[QUOTED] likes this.
  10. Sep 10, 2016 at 4:35 PM
    #1470
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    tire specs 265 is width in millimeters, 75 is the percentage of the width (265) will be 1 sidewall height, and of course 16 is the rim size....if you do not have a tire calculator handy can do the math on a phone, its easy.
    265
    x 75
    x2 (2 times the side wall height is what this part of the equation is figuring out )
    = 39,750 take this number and divide by 2540 (its converting the number to inches 25.4 millimeters in an inch)
    = 15.64 inches, then take this and add rim size in this case 16
    265/75/16 = 31.65 inches
    265/70/16 = 30.60 inches
  11. Sep 11, 2016 at 3:02 PM
    #1471
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    Should I go with the 265/70/16 or the 265/75/16?
    There is about $160 difference (the smaller set is more expensive).
    tirerack is the cheapest I can find right now, but adding in shipping and install its going to be about $230-240 a tire. Which is what Mr Tire said they would charge with install included.
  12. Sep 11, 2016 at 3:10 PM
    #1472
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    I got mine at BJs wholesale for 1081 for 5 mounted and balanced.. 265/75R16
  13. Sep 11, 2016 at 3:25 PM
    #1473
    infernotacoluis
    infernotacoluis Well-Known Member
    luis
    soflo
    2016 tacoma trd off road
    wheels,tire,steep bar,interior light,trd shift knob,led headlight
    i bought 4 tires 265/70/r17 last week for 786 otd at fierceoffroad.com idk if this coupon still works with them ''fiercefast5''
    tacoflavoredkisses1 likes this.
  14. Sep 11, 2016 at 5:06 PM
    #1474
    tacoflavoredkisses1
    Woah! I can get these (265/75/16) for $683 OTD!
    Is this site legit? How are they with returns or issues?
  15. Sep 11, 2016 at 6:49 PM
    #1475
    SpodieOdie
    SpodieOdie Well-Known Member
    2004 Tacoma OR
    None
    265/70/17 BFG KO2 T/A (C Rating) on stock rims. The tires have been great so far, but I've only had them for about a month. Nothing but good things to say so far. Super quite on the Hwy too.
  16. Sep 11, 2016 at 9:30 PM
    #1476
    Svizzusi
    Svizzusi Lifted 2009 4x4 DCSB
    San Luis Obispo, CA
    Bilstein 5100/ OME 887/ 285/70/17 BFG KO2/ 17" ProComp 7032/ OME Dakar/ LR UCA/ Superbumps/ AllPro Flip Kit
    285/70/17 BFG KO2
  17. Sep 13, 2016 at 10:40 AM
    #1477
    wake100
    Syracuse, NY
    oh yeah. so I was worried about gas mileage and the stiff ride of E rated tires... So I picked these up in 265/75R16 and replaced Cooper A/T3 C rated of the same size. Mileage believe it or not is the same as the coopers, I got ~18 mpg all highway (70-75 mph) on a road trip. yesterday. They actually ride way better than I expected. if anything they are cushier than the coopers. The only thing I dont like and will just get used to is how heavy they are. yeah... things need to be a little more thought out in terms of merging and what not.
  18. Sep 14, 2016 at 9:36 AM
    #1478
    MARK97XP
    Mark
    Spokane
    03 SC DC 4WD TRD OR
    Got mine 265/75R16 at 4wheel parts $749! No tax with $50 rebate. Now to get them installed...stopped by discount and they wanted $110, Les Schwab $133 lol I cant believe im saying this but the Dealer only wants $69.95.
  19. Sep 14, 2016 at 11:57 PM
    #1479
    Aaronlammm
    Aaronlammm Well-Known Member
    Aaron
    Denver, CO
    2016 Quicksand Toyota Tacoma Trd Off-road
    What psi are you guys running on 285/70/17?
  20. Sep 15, 2016 at 12:22 AM
    #1480
    Croth51
    Croth51 Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    Welp picking up my second set soon.... At 9000 miles
