BFGoodrich All Terrain T/A KO2
Discussion in 'Wheels & Tires' started by Discount Tire, Sep 15, 2014.
  1. Jan 9, 2017 at 7:18 PM
    #1561
    Buck18
    Buck18 Well-Known Member
    Buck
    Euharlee GA
    01 Tacoma DC 4wd Limited TRD
    881's on Billie 5100's, Dakar's and 5100's, grey wire mod, 265 75 ko2
    SUGABEAR are those 265/75/16 on 3" lift ? Nice truck. Like the stance
    SUGABEAR[QUOTED] likes this.
  2. Jan 10, 2017 at 7:41 PM
    #1562
    SUGABEAR
    SUGABEAR Well-Known Member
    MR.M
    SoCal
    Yes, not too sure now since my set up has settled. I'm on OME shocks with 881 coils and wheelers 5 leaf springs in the back.
  3. Jan 11, 2017 at 9:30 AM
    #1563
    SilverSurfer
    SilverSurfer Well-Known Member
    Mark
    Los Angeles
    2013 4X4 LT
    Did the job in the mud
    lpfe42, o0oSHADOWo0o and DavesTaco68 like this.
  4. Jan 12, 2017 at 7:46 PM
    #1564
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    We are at 36 days of snow and ice on the ground in the Columbia River Gorge. Zero issues getting around with the BFG KO2 tires. We don't use salt in Oregon so our streets are packed snow and ice.
    We all know Tacoma's have notoriously sensitive ABS in the ice. I have not experienced any premature ABS engagement on snow/ice with these tires. The Dungflops were a different story. I've hit ABS intentionally to see how it felt and simply releasing the brakes and reapplying to the threshold safely brought the truck to a stop.
    Watt maker and o0oSHADOWo0o like this.
  5. Jan 12, 2017 at 7:47 PM
    #1565
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I hit 20k on my 305/65r18 on my Tundra, still look great! No problems towing a lot in the Az heat either.
    Watt maker likes this.
  6. Jan 14, 2017 at 1:22 PM
    #1566
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
    Does anyone have the load inflation table for KO2s? My google-fu is failing me right now. I'll be coming from the stock Kevlars (SL i believe) on 3rd gens and want to know what PSI to run in the KO2s to match the load rating I had before. I'm assuming around 40psi without looking at the tables.
  7. Jan 14, 2017 at 3:56 PM
    #1567
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Need to know the size you are running. And the tables are not brand or model specific.
  8. Jan 14, 2017 at 4:22 PM
    #1568
    c4lvinnn
    Oops thought i put that. Stock is 265/70/16 and will be going with 275/75/16 KO2
  9. Jan 14, 2017 at 5:39 PM
    #1569
    DVexile
    Ken
    Hmmm... I don't think there is a LT275/75R16. There is a LT265/75R16 and a LT275/70R16. Did you mean one of those?
    Some relevant inflation tables below. Note that P and LT tables for the same size are different. Note that Toyota puts the TRD Pro LT door sticker a bit higher than interpolation from the stock P tires would imply. The load tables for LT265/75 and LT275/70 are very close as you can see. I don't have a load table for LT275/75 but as mentioned I don't think KO2 comes in that size.
    Tables are identical regardless of load rating (C/D/E all use the same table for a given size). Also standard across all brands. All that matters is the size and if it is LT or P.
    Hope this helps!
    P265/70R16 (Stock)
    26 - 1914
    29 - 2015
    32 - 2115
    35 - 2185
    LT265/70R16 (Stock size, but LT rated - Stock on TRD Pro)
    35 - 1820
    40 - 2000
    45 - 2170
    50 - 2335
    LT265/75R16
    35 - 1910
    40 - 2100
    45 - 2280
    50 - 2470
    LT275/70R16
    35 - 1925
    40 - 2110
    45 - 2295
    50 - 2470
    P265/70R16 Stock door sticker - 29F/32R
    LT265/70R16 TRD Pro door sticker - 46F/46R
    LT265/70R16 interpolated inflation based on stock P - 40F/43R
    LT265/75R16 interpolated inflation based on stock P - 38F/40R
    LT265/75R16 interpolated inflation based on TRD Pro LT - 43F/43R
    LT275/70R16 interpolated inflation based on stock P - 37F/40R
    LT275/70R16 interpolated inflation based on TRD Pro LT - 43F/43R
    o0oSHADOWo0o and c4lvinnn like this.
  10. Jan 14, 2017 at 5:40 PM
    #1570
    c4lvinnn
    Wow typo'd again. 265/75/16 is what I was trying to say...
    And thats exactly what I was looking for, thanks!
    Pretty much spot on to my estimation at 40psi
    DVexile likes this.
  11. Jan 18, 2017 at 9:21 AM
    #1571
    Gooney
    Gooney Well-Known Member
    Southern California
    What's he best price people have seen on the 265/70/17 Load C? Looking to purchase a set once I get my new 2017 TRD Sport
  12. Jan 18, 2017 at 7:07 PM
    #1572
    10tac
    10tac Active Member
    so i see there are 82 pages and i dont feel like reading but whos had these in the mud and how do they do for a at tire
  13. Jan 21, 2017 at 9:14 AM
    #1573
    MCObray
    MCObray Well-Known Member
    Oregon
    2002 Toyota Tacoma DC TRD
    Mine performed awesome in the snow and ice we got last week. 235/85/16.
    [​IMG]Untitled by Mason Obray, on Flickr
    o0oSHADOWo0o, Watt maker and DVexile like this.
  14. Jan 23, 2017 at 9:17 PM
    #1574
    Inferno_OR
    Inferno_OR Well-Known Member
    Nate
    '16 TRD OR - Inferno DoubleCab
    stock....for now
    had a minor issue when first getting mine installed, just was a balancing problem. turned the tire a little, added some more tire lube and it was fine.
  15. Feb 2, 2017 at 3:32 PM
    #1575
    Buck18
    Buck
    Euharlee GA
    I'm having a hard time deciding between 255/85/16 Cooper ST Maxx and 33/10.50/15 BFG Ko2. Running them on a 1st gen DC 4wd. I have 1 set of stock TRD 16's and some 96 stock 15's. Anyone have a mounted measurement on a Tacoma? Don't really wanna do a lot of trimming, but if I order either of these I've got $1000 in tires and I'm wanting to be happy with my purchase!!
  16. Feb 2, 2017 at 6:42 PM
    #1576
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    I don't have any experience with the ST Maxx, but I do with the KO2. I like them enough that I'm getting a second set on my new wheels. Anyways, that size KO2 is a load range C at roughly 51 lbs per tire. It's going to be a bit lighter than the 255/85/16 ST Maxx load range E which I believe are 58-60 lbs. Just something to think about if you are comparing those two. I can't help you out with how much trimming may be required.
  17. Feb 2, 2017 at 6:59 PM
    #1577
    Buck18
    Buck
    Euharlee GA
    Thanks @yeos. All you said above is true. Trimming is no big deal, my concern is I'll spend $1000 on a set of 5 and not like em. I only put around 8,000 miles a year on my Tacoma so they should last for more than 5 yrs. That's a long time to have a disappointing tire. I'd like to go 255 so I can get 16" TRD gray simulated beadlock wheels !! But like the 33 10.50 ko2 for the weight difference
  18. Feb 3, 2017 at 3:30 PM
    #1578
    kyuss88
    kyuss88 Well-Known Member
    Jimmy
    New Jersey
    2012 MGM DCLB TRD Sport 4x4 V6
    No skids, no lockers, no winch.
    I just bought Pro Comp 69's(17x9) and BFG KO2 275/65R17 Load range E. Is load Range E to heavy of a tire for my 2012 TRD crew cab long bed. Has anybody had problems with Load Range E KO2's? Also, what do I do about the tire sensors? I don't want the low tire light on all the time.
  19. Feb 3, 2017 at 4:56 PM
    #1579
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Same here. I've got 275 load E KO2s on my FJ and they ride just fine. Sure I notice a difference going back and forth from the wife's 5th gen T4R with P rated coopers, but set the tire pressure correctly and they'll be fine.
    IIRC when I had them mounted they got set at like 48 psi which was wayy too much. Just do a chalk test and they'll feel much nicer.
    kyuss88 likes this.
  20. Feb 3, 2017 at 9:06 PM
    #1580
    kyuss88
    Jimmy
    New Jersey
    Mine say 80 psi max. Should I run them that low? I'm still not sure what to do about the tire pressure sensors.
