BFGoodrich All Terrain T/A KO2
Discussion in 'Wheels & Tires' started by Discount Tire, Sep 15, 2014.
  1. Nov 10, 2014 at 8:45 PM
    #141
    surfermatt
    surfermatt Well-Known Member
    CA
    04 prerunner, ext cab
    Front long travel custom: king 10" CO, solid lowers, fabbed spindle, heimed everything ect. Rear still in progress, waiting to be put on: bilstein 9100s, T100 axle. Stock 3.4 engine, 4.30 gears.
    Shop around, I got quoted fifty less for 285s with lifetime balancing mounted also...
  2. Nov 10, 2014 at 11:32 PM
    #142
    ZenkaiTaco
    ZenkaiTaco Well-Known Member
    Utah
    11 DCSB TRD OR
    I absolutely love the way these tires transformed the look of my truck!
    I had firestone destination AT's in the stock size from when I bought the truck. For some reason it just didn't look right to me, something was off.
    These tires fixed that right up!
    Also the extra weight and stiffness of the E rated tire is nothing like I thought it would be. This is something I was really worried about. I can't really tell if these are any more noisy then the destination at's. And as for the sidewall stiffness, I actually like how it feels now better! Just feels more stable I guess.
    Silvertexastaco likes this.
  3. Nov 11, 2014 at 8:54 AM
    #143
    Discount Tire
    Discount Tire [OP] Tire & Wheel Specialists Vendor
    Arizona, USA
    LT tires typically ride a little stiffer when compared to standard load passenger tires. Like you noted, this is due to higher inflation requirements and heavy duty construction. 35PSI is the minimum cold inflation pressure we recommend you run your LT265/75R-16E KO2 tires at.
    As far as the $70.00 BFG Rebate goes, we are excluded from this particular promotion.
  4. Nov 11, 2014 at 5:48 PM
    #144
    surfermatt
    CA
    Got mine today, 1028 out the door minus rebate from tire pros for 285 75 16
    So far the sidewall stiffness feels great, mine also have a sticky sound haha.... Alignment time
  5. Nov 12, 2014 at 11:38 AM
    #145
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Colorado
    98 3.4L V6 TRD Ext. Cab 4x4 SR5
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    So far they seem to be performing loads better in the snow than the KOs. Though with the shocks being a little underpressured from our altitude climbing and descending now paired with the extra weight of snow on the truck...so much rubbing haha
  6. Nov 12, 2014 at 12:31 PM
    #146
    Discount Tire
    Arizona, USA
    Did you snap any snow pics?
  7. Nov 12, 2014 at 2:43 PM
    #147
    Ice Horse
    Lauren
    Colorado
    The snow isn't super deep currently (on the roads at least), just enough to make it icy, but noticed it seems to grip a lot better.
    I didn't get any pictures but if we go out again later I could possibly gets some poser shots in a parking lot haha
    Did get a pic of our crawler last night, though not quite KO2s haha
  8. Nov 13, 2014 at 8:25 AM
    #148
    OPC
    OPC New Member
    Phx, Arizona
    SR5 4WD
    Very interested in the KO2s for my stock DCSB 4x4, but concerned about the rubbing noted above. Would anyone with 265/75-16s (I'm on stock wheels) be willing to measure the diameter (horizontally) of the mounted tire to help me anticipate fender clearance issues? I know the calculated value is 31.7", but wonder if the KO2s are coming in larger.
    Thanks.
  9. Nov 13, 2014 at 1:07 PM
    #149
    Discount Tire
    Arizona, USA
    You're right, those are not quite KO2s :D Nice looking crawler!
  10. Nov 13, 2014 at 1:31 PM
    #150
    pwrstrk02
    pwrstrk02 Well-Known Member
    randy
    kansas city missouri
    2010 4x4,dc,off road, black pearl
    aired up to 40lbs, 31"vertical, and 31 3/8th horizontal. ive only drove it 3 miles so my words arent writen in stone just yet, but it took a 3" curb at 7mph at full lock to rub. flat ground they do not rub. im not worried about rubbing because i never would of ran over that 3" curb at 7mph at full lock anyway. all highway here.
  11. Nov 13, 2014 at 1:32 PM
    #151
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    I wouldn't put too much cred into the M+S rating. You can buy performance street tires that have that rating on the side. That being said the All Terrrain TA has been a great all terrain tire and the new one is just a little bit better. There's a reason they haven't changed it much over the years. I may get rid of my rugged terrains for these in the spring. I have winter and trail tires so these would fill in between nicely.
  12. Nov 13, 2014 at 1:34 PM
    #152
    OPC
    OPC New Member
    Phx, Arizona
    SR5 4WD
    Cool! Thanks! :thumbsup:
  13. Nov 13, 2014 at 2:51 PM
    #153
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I understand that they are not a snow tire, but it matters for those in California for one reason:
    In the winter, Caltrans sometimes places restrictions the higher elevations get snow and there may be restrictions on vehicles with regards to tire chains (or cables). I am guessing because so many dumb drivers going from sea level to Tahoe every weekend can't drive in any weather conditions. There are 3 levels of restrictions enforced by Caltrans:
    • R1: Chains or snow tread tires required. Snow tires must have a tread depth of 6/32" with a "M & S" imprint on the tire's sidewall.
    • R2: Chains required on all vehicles except four-wheel drives or all-wheel drives with snow tread tires on all four wheels.
    • R3: Chains required - ALL VEHICLES- no exceptions
    Also, note "R-1 and R-2 are the most common chain controls. The highway will often be closed before an R-3 control is imposed.", so in reality, if the roads are open but have restrictions, the KO2's allow me (since I have 4x4) to not have to put on chains.
  14. Nov 13, 2014 at 3:32 PM
    #154
    Ice Horse
    Lauren
    Colorado
    Thanks! And here's some pics as promised.
  15. Nov 13, 2014 at 8:53 PM
    #155
    surfermatt
    CA
  16. Nov 14, 2014 at 7:48 AM
    #156
    Discount Tire
    Arizona, USA
    Looking good.
  17. Nov 14, 2014 at 9:49 PM
    #157
    JimBCa
    JimBCa Well-Known Member
    Jim
    Bay Area California
    2012 TRD Off Road
    Build Duratrac 265/75R16 Load rated E BAMF Rock Sliders, Pelfreybilt Front bumper and skid plates (3) Pro Runner front and rear shocks,Add-A-Leaf springs ATO (Armor Tech Offroad) hilift mounts, Famous Fabrication cb antenna/flag mount CoverKing Tactical seat covers, Flyzeye dash-light ARE Shell, backup light mod SumoSprings and Stops
    Nice pics, ordering my set tomorrow looking forward to getting them om. My Duratracs are down to about 35%, going to pull them off as leaving Thanksgiving week for off road from Nevada to Baker California. Plus I drive all winter long to Soda Springs, so like fresh tires. Will sell or hand off my old tires as I also have the original oem tires with only 5k on them. Spent lots of years living in Nevada, Lake Tahoe, and Oregon, so like the new rubber. I have been running 265/75 and will continue without problems.
    I would like to get new wheels to move the tires out about 1/2 - 1 " as there is only a finger width of inside clearance but not sure what to get. They have to be for off road, and carry weight of my boat and gear.
    Suggestions appreciated.
  18. Nov 14, 2014 at 11:19 PM
    #158
    Mr Ribby
    Mr Ribby Well-Known Member
    Andrew
    NW Indiana
    2013 "Baja"
    Pioneer DvD double din, pioneer 5way front door speakers, kicker 3 way rear door speaker
    I've been driving on the older style ones for around 30k miles, so Ill give my opinion on here, because it seems fitting. Like many posts before mine, I agree that the new ones are way to similar to the previous A/T. Where is the new technology? The KOs are an all around good tire for the average driver. It does have some serious downfalls though. The way the elements on the tire are designed, it tends to hold snow/mud/dirt extremely well consequently giving u less traction. I have a ton of experience driving with these tires in the snow, and they are ok. Not the best but ok. I live in NW Indiana and last year the roads were closed due to almost 2ft of snow in 2 days. I was one of the few that ignored the mandated closure of roads and romped around town. Like I mentioned before these tires get decent traction as long as you get out and unpack the snow/mud from them every once in awhile, it sounds stupid but I am serious. I made a couple trips to the only gas station that was open in town for emergency personal to fill up some extra gas, and ended up pulling a state cop in a suburban out of a drift. Struggled to get traction on a wet surface (their was no ice) I was pulling from. threw down some cat litter and was a lot better. Would I recommend these tires to someone to put on their Tacoma to be used in winter? probably not. If you live out west and see little to no snow or mud it would probably suit you better. They are extremely soft tires for an AT. In sand or anything that is hard packed they handle very well. When braking hard, abs kicking in, mine tended to "hop" like they were fighting for traction on a perfectly dry street surface. weather that was my driving or the tires I don't know, first time I have ever had that happen in a truck. Overall though I would limit this tire to dry hard packed conditions. A True more desert sand style tire. In my opinion these are one of the louder A/T when street driven. Hope this helps anyone whose on the line of buying towards the 4 seasons part of the US. I think I will give a different tire a try next go around. Please please please take this with a grain of salt, as every tire suits someone's needs completely differently. I'm sure their are reviews out their that love these tires but to me an A/T should be able to siphon/drain to a better extent and should not be fighting for traction as much as I am on a dusting of snow. Best of Luck
  19. Nov 15, 2014 at 7:35 AM
    #159
    Discount Tire
    Arizona, USA
    Looking forward to your thoughts, Jim. I know a lot of people are searching for side by side comparisons between the KO2 and DuraTrac.
    As far as wheels go, take a look at the new Level 8 Pro line. We have the 16x8.5 Tracker Pro and Bully Pro in stock :cool: Zinc plated lug hardware, hub centric rings, and a Level 8 deflator gauge are included with the purchase of four(4) Level 8 Pro wheels.
    Details: http://www.tacomaworld.com/forum/wheels-tires/323086-level-8-pro-wheels.html
    Thank you for sharing your experience with the original TA KO. Although the new TA KO2 doesn't look all that different from the outside, BFG has made some pretty major changes to the tire's carcass, belt packages and tread compound. Its really an entirely new tire that held on to some of the KO's classic look.
    Here's a side by side shot of the KO and KO2 in the LT285/70R-17 size. The KO2's side bitter lugs, serrated shoulder, and 3-D locking sipes improve mobility in winter conditions, soft soil and mud.
  20. Nov 15, 2014 at 10:35 AM
    #160
    Mr Ribby
    Andrew
    NW Indiana
    2013 "Baja"
    Its such a good looking tire!!!! I'm just undecided on if I want to give a tire with such a similar tread another go in the winter. Guess it will be a waiting game and see how other people feel about them after this winter. Thanks for posting that side x side of both. Very cool! Until then im stuck with the originals again for this winter, but hey that's half the fun!
