BHLM again...It doesn't fog up anymore...?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 45longcolt, Jun 19, 2008.
  1. Jun 19, 2008 at 5:57 PM
    45longcolt
    45longcolt [OP] Well-Known Member
    DFW Area
    2020 Off Road
    Has anyone ever had a fresh BHLM go foggy on them and then later on down the road it stops fogging up? After about a month now the rain and car washes don't seem to make it fog up anymore. Could it perhaps seal it self up some over time and in our 100+ Texas heat? Maybe the lamp seals weren't good to begin with but got better? It doesn't fog up anymore at all on me. Me happy about that for sure!:)
  2. Jun 19, 2008 at 6:23 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    The heat could have baked out any moisture and until it rains and gets moisture again you might be good to go...
    I guess it is possible to have it bake in a seal...
    just glad is working for you...
  3. Jun 19, 2008 at 6:42 PM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I guess you are just lucky. I think I am going to glue one of those silicon packs to the back of one of the reflectors when I do mine. That way it will absorb any residual moisture.
    I did something similar on my old Subaru. It turned out pretty good, but without the silicon pack it got moisture buildup in a week or so.
    Any other ideas to be sure there is no moisture?
  4. Jun 19, 2008 at 7:15 PM
    45longcolt
    DFW Area
    2020 Off Road
    I thought about using dissicant bags too behind the reflector and then I thought if those bags shook enough to break loose or the stuff spills out and dust gets everywhere. Maybe I was just lucky.
  5. Jun 19, 2008 at 7:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The last time I worked on healights, I drilled a 1/32" hole at the bottom of the light near the back. Yeah, it lets moisture in, but it lets it back out too. :)
  6. Jan 3, 2010 at 1:11 AM
    808Raider
    808Raider Well-Known Member
    hawai'i
    Where did you guys get the silicon packs from and exactly where did you put them? Just did the BHLM a couple weeks ago and one of my lights is fogging after the first car washand wondering what to do
  7. Jan 3, 2010 at 1:25 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Yep, my drivers headlight did that .So I tried to resilicone it, that didnt work. So then I stripped what was left of the factory glue and put more silicone in it, that didnt work either. So I bought a oem headlight and will be switching out the baezels soon so I dont have to repaint. :D
