BHLM frustration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gupster88, Sep 30, 2009.
  1. Sep 30, 2009 at 8:31 PM
    gupster88
    gupster88 [OP] Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    well apparently i didnt seal my driver side headlight properly when i did the bhlm. its been getting foggy. ive been lazy, so i just took the headlight out and applied (a very thick layer) of the silicone adhesive around the seal on the outside of it. im lazy in the sense that i didnt wanna re-bake it, pull it apart, then put it back together. well after doing this twice, it still fogs. guess im gonna have to get some energy and do it the right way...damnit:frusty:
  2. Sep 30, 2009 at 8:32 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Sucks to hear. Make sure all the condensation is out before you reseal it.
  3. Sep 30, 2009 at 8:34 PM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    yeah, first two times i did this i borrowed a hair dryer and held it to the center hold and just let er dry it out lol
  4. Sep 30, 2009 at 8:34 PM
    MotoTacoma
    MotoTacoma Adrenaline Addict
    Pencilveineeya
    14 Tundra TRD OR, 05 GX470
    tacoma sold 11/13/13 GX470 has 2” Dobinsons IMS w/JBA UCA, Baja Designs S1 ditch lights, more to come!
    the silicone should work, i know it's obvious but double check that all your bulbs are fully inserted and twisted all the way..
    good luck
  5. Sep 30, 2009 at 8:35 PM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    didnt think about that. but it seems like the fog is starting in the bottom two corners and all the way up the right side. would that mean thats where the leak is or just so happens to be where the fog starts?
  6. Sep 30, 2009 at 8:36 PM
    Rollinn
    Rollinn Well-Known Member
    Vegas
    06 Prerunner sport
    Icon 2.5 c/o,TC uca, bhlm mod, nav, etc etc
    the things we do to keep up w/ the TW jones' :D
  7. Sep 30, 2009 at 8:36 PM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    Yea, mine did it the first time and I left it out in the sun all day and resealed. Now my other one is foggy occasionally. I guess I'll have to reseal that one. :(
  8. Sep 30, 2009 at 8:37 PM
    jammdogg
    jammdogg Well-Known Member
    James
    Hillsboro, OR
    13 Spruce Mica DCLB
    6" ProComp lift on 35 MT's. ARB Bumper.
    Post pics when done. I absolutely LOVE your tacoma. One of the best I have seen.
  9. Sep 30, 2009 at 8:39 PM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    how'd you reseal your first one, just did it the same way you did the first time? i read that some guy put electrical tape around his to seal it up, messaged him and asked if it worked but ill prob just re do it...im so lazy
    thanks man. hopefully, if i do it right, the before and after pics will look the same lmao.
  10. Sep 30, 2009 at 8:45 PM
    MotoTacoma
    Pencilveineeya
    i wish i knew..
    i'm sure you'll get it squared away in no time tho..
  11. Sep 30, 2009 at 8:48 PM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    Put a ton of silicone on and made sure it was completely covered.
  12. Sep 30, 2009 at 8:50 PM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    you put it in the groove and over top of the line where the two parts go together or just in the groove?
  13. Sep 30, 2009 at 8:52 PM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    When I used to do 4th Gen Camaro's I would drill small drain holes on the under side of the housing to allow for some air circulation & moisture drainage. It worked well. Just an idea.....
  14. Sep 30, 2009 at 8:53 PM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    did it fog up any?
  15. Sep 30, 2009 at 9:00 PM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    This is why I haven't done mine. The thought of a putting a ton of silicone on my headlights makes me cringe.
  16. Sep 30, 2009 at 9:01 PM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    a non-bhlm silver streak dont look too bad. but a non-bhlm bsp looks iffy so i gotta do it lol
  17. Sep 30, 2009 at 9:02 PM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    You can't see it from the outside but it doesn't look to good from the inside.
  18. Sep 30, 2009 at 9:03 PM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    x2. i got mine loaded up with silicone but you cant see it at all
