BHLM help please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sfoxwoody, Feb 9, 2012.
  1. Feb 9, 2012 at 8:53 AM
    sfoxwoody
    sfoxwoody [OP] Well-Known Member
    Calhoun, Ga
    05 TRD Sport, 4x4, BSP, LB
    none yet
    While doing mine I decided to tint the blinker lens and the orange reflector with Rust-oleum spray tint, FYI dont use that stuff! They look bad and I dont want to try wet sanding them unless I have to, do any of you have some or know where I can get them? I mainly need the blinker lenses
  2. Feb 9, 2012 at 8:54 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Will something like gasoline on a rag take the tint off? Or brake cleaner maybe?
  3. Feb 9, 2012 at 9:05 AM
    sfoxwoody
    Calhoun, Ga
    none yet
    I'm afraid if I use chemicals it will haze the lens, if I cant get some I'm going to try something
  4. Feb 9, 2012 at 9:08 AM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    just use paint thinner and rub quickly dont let it just sit and soak into the plastic.
  5. Feb 9, 2012 at 9:23 AM
    sfoxwoody
    Calhoun, Ga
    none yet
    I'll try it, cant hurt! If nothing else I can polish it out like headlights
  6. Feb 9, 2012 at 9:26 AM
    sir1123
    Charleston
    let us know how it goes or i think mineral spirits is less intense..not sure though
  7. Feb 11, 2012 at 1:08 PM
    sfoxwoody
    Calhoun, Ga
    none yet
    Nobody has a pr they screwed up, I'd still like to find some. I tried mineral spirits and I finally got the tint off using 1000 grit wet sanding it but its hazy now, I'm going to buy a headlight polishing kit and see if that helps
  8. Feb 11, 2012 at 1:12 PM
    tbturner47
    tbturner47 Well-Known Member
    '16 Barcelona Red TRD Off Road
    just leave them out
  9. Feb 13, 2012 at 11:07 AM
    sfoxwoody
    Calhoun, Ga
    none yet
    Things are all good now, I wet sanded with 1000 grit and mineral spirits, then bought a 3M headlight restore kit and it looks great now! Now I've just got to put them back together
