bhlm help!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kinkrider101, Mar 8, 2010.
  1. Mar 8, 2010 at 4:47 PM
    kinkrider101
    kinkrider101 [OP] Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    i cant get the headlights off the truck. i took off three bolts and when i pull on the headlight it doesnt seem to come out.
  2. Mar 8, 2010 at 4:51 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    oh boy? i cant remember how many bolts there were? I ended up taking the whole front bumper off of mine to get the headlights off! good luck
  3. Mar 8, 2010 at 4:52 PM
    kinkrider101
    santa barbara
    wheels and tires
    oh god i dont wanna have to do that
  4. Mar 8, 2010 at 4:54 PM
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    There is a 4th bolt.
    10 mm
    It's inside the fender. Feel up in there with your hand...you wont be able to see it but you can feel it. And you will feel two bolts...the one on top is the one you want to unbolt;)
  5. Mar 8, 2010 at 4:54 PM
    TacoSupreem
    Hayden
    Kentucky
    you shouldnt have too! there is one bolt that you will have to get on your back and reach up behind the front bumper cover to get. its a pain in the ass!
  6. Mar 8, 2010 at 4:55 PM
    TacoSupreem
    Hayden
    Kentucky
    WHOA! Super Werty blessed us with his presence! ...Star struck!
  7. Mar 8, 2010 at 6:05 PM
    kinkrider101
    santa barbara
    wheels and tires
    ok i got the headlights out. how do i remove the main light in the assembly?
  8. Mar 8, 2010 at 6:09 PM
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    the headlight bulb?
    There is this bent wire that you lift and kinda twist...the wire should stay attached to the plastic headlight and the bulb will come out..
    play with it, be gentle...dont break it
  9. Mar 8, 2010 at 6:13 PM
    kinkrider101
    santa barbara
    wheels and tires
    yes the one on the middle
  10. Mar 8, 2010 at 6:56 PM
    kinkrider101
    santa barbara
    wheels and tires
    now i need to go buy a torxe bit for the three bolts on the headlight... what number torxe bit is it?
  11. Mar 8, 2010 at 7:01 PM
    TacoSupreem
    Hayden
    Kentucky
    Just a sec and i'll tell you
  12. Mar 8, 2010 at 7:02 PM
    kinkrider101
    santa barbara
    wheels and tires
    ok cool thanks... im about to go to the hardware store
  13. Mar 8, 2010 at 7:06 PM
    TacoSupreem
    Hayden
    Kentucky
    says T15 on my craftsman set
  14. Mar 8, 2010 at 7:11 PM
    kinkrider101
    santa barbara
    wheels and tires
    is that the size
  15. Mar 8, 2010 at 7:15 PM
    TacoSupreem
    Hayden
    Kentucky
    Shit i dont really know? just says t15 m?
  16. Mar 8, 2010 at 7:17 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I didn't have a torque bit the first time i took them apart... used a flat bladed screw driver. Take one of the screws out and take that to the store to find the right size screw driver.
  17. Mar 8, 2010 at 7:39 PM
    kinkrider101
    santa barbara
    wheels and tires
    ok i got it it was a t 10 do i put the headlight in lens up or lense down?
  18. Mar 8, 2010 at 8:03 PM
    ImpulseRed008
    Susan
    SC
    lens up is what I did. Don't want to risk scuffing the lens. Make sure you put it on some cardboard
  19. Mar 8, 2010 at 8:07 PM
    kinkrider101
    santa barbara
    wheels and tires
    i tried it and i could not pull the lense off.
  20. Mar 8, 2010 at 8:27 PM
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    what baking instructions did you follow?
    heat up the oven to 300*F
    turn off the oven
    put the headlight in the oven for 10 min....make sure the oven is OFF
    after ten min pull the headlight out...wear gloves
    pull it apart....its still going to be really tuff to tear apart, but it will happen after you struggle with it
