BHLM Ribbon Sealer??
Discussion in 'Lighting' started by dza1284, Apr 9, 2011.
  1. Apr 9, 2011 at 12:15 AM
    dza1284
    dza1284 [OP] Well-Known Member
    CA
    08 OR Short Bed Dbl Cab
    Bilstein 5100, 2" AAL, Grille, BHLM, Footwell LED, Dash LED, Aero exhaust
    Viet2100 BHLM thread says to use 3M Window-Weld Ribbon Sealer. Unfortunately a lot of local stores do not carry this. Autozone carries a similar prodcut but it is not called window weld. Will this stuff work the same? This is for re-adhereing the headlight lense to the bezel after the BHLM.
    This is the recommended ribbon sealer from 3m.
    http://solutions.3m.com/wps/portal/3M/en_US/Marine/Home/Products/Catalog/?PC_7_RJH9U5230GE3E02LECIE20S4K7_nid=GSJZ5GZYTKgsQH8HT14PGTgl34QXLJFH1Jbl
    This is the ribbon sealer that auto zone carries (isn't called window weld, not sure if that is just a brand name)
    http://www.autozone.com/autozone/accessories/Metro-3-8-in-x-15-ft-round-bead-ribbon-sealer?itemIdentifier=501842
