BHLM tomorrow.. kinda nervous!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma909, Aug 14, 2011.
  1. Aug 14, 2011 at 1:08 AM
    Tacoma909
    Tacoma909 [OP] Well-Known Member
    Going to attempt to do the BHLM tomorrow. Hope everything goes smooth. I've done my homework, so I will put it to the test.
  2. Aug 14, 2011 at 1:14 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    good luck
  3. Aug 14, 2011 at 1:18 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    as per the usual
    :worthless:
    Good luck!
  4. Aug 14, 2011 at 2:04 AM
    2TRunner
    2TRunner Well-Known Member
    GL.
    I say keep/reuse as much of the OE sealant as possible.
    Re-used OE sealant then a decent bead of Silicone all around, 0 issues with leaks, condensation, etc...
  5. Aug 14, 2011 at 5:37 AM
    roboots21
    roboots21 Taco Supreme!
    Brian
    Pittsfield, MA
    2007 TRD Sport DC LB
    Bilstein 5100's, Grillecraft, Flowmaster, Nitto's, NFab's, BHLM, BFLM, 20% tint, more to come.
    This mod was the one that made me the most nervous but it was one of the simplest ones. The only scary part is when you are peeling the headlights apart it will make noises like the lens is cracking .. it is just the sealant letting go. After that as long as you take your time and since you did your homework, you will be fine! Are you using Plasti-dip or regular paint for the mod? Good luck!
  6. Aug 14, 2011 at 7:56 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    did mine a few days ago, turned out great.
  7. Aug 14, 2011 at 8:39 AM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Yes. Use the old sealant. I didn't and ended up buying some eBay lights
  8. Aug 14, 2011 at 10:29 AM
    Tacoma909
    Do you guys know if the headlights stink the house by putting them in the oven?
  9. Aug 14, 2011 at 10:30 AM
    Tacoma909
    I was thinking of using a flat black plastic paint.
  10. Aug 14, 2011 at 10:39 AM
    Davidson
    Davidson Well-Known Member
    Cody
    Elmendorf AFB Alaska
    11 trd sport
    5100's in the front @ 2.5", 1.25" allpro wheel spacers (Removed), painted front valance, BHLM, eyelids, Grillecraft grille, magnaflow catback ehxaust, k&n CAI, window tint, 2 10" kicker subs, painted badges, 5000k 55w HIDs (headlights & fogs), (2) 7" kragen HID lights behind grille, rear tsb (finally), AAL
    i did the exact same and i have zero issues. but i used quite a bit of silicone window sealant. the entire tube on both actually haha i just wanted to be sure.
    my one problem (which was totally my fault) is that on one of the headlights i forgot to turn the oven off and it started smoking. unfortunately it bubbbled the lens a tiny bit.
  11. Aug 14, 2011 at 10:40 AM
    07TaCo07
    07TaCo07 Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    Make sure u give enough time to dry. I was in a hurry and got a few little scratches when putting the 2 halves together. Im the only one who will probably notice
  12. Aug 14, 2011 at 11:44 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    Well, more than one way to skin a cat. I've pulled mine apart 2x now, using 3m window weld each time, and I have never had any leaks or condensation either.
    Either way, I'm sure you'll be fine w/ the mod. Its an easy job
  13. Aug 14, 2011 at 3:08 PM
    Tacoma909
    Success!!! Everything went great as planned.
  14. Aug 14, 2011 at 3:55 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Nicely done. And a celebration beer too
  15. Aug 14, 2011 at 3:59 PM
    Fred1524
    Fred1524 Love me some tacos!!!!
    Fred
    Temecula
    08 Silver 4X4 Rugged Trail
    Blacked Out badges,blacked out tail lights, 7% Tint(all around) Wet okole seat covers, A/W TRD floor mats, 10K HID Headlights, 6K HID Foglights, DTRL MOD, LED cluster swap...
    That looks good....this is on my list to do early next month. Did you use window weld?
  16. Aug 14, 2011 at 4:03 PM
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    Damn i gotta do this finally. Looks great, congrats. As for the oven smell, how did that go? Not sure how the guy I'm renting from will feel about this one.. haha
  17. Aug 14, 2011 at 4:05 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    there's no smell - at least I didn't have any. The oven should be off and it's not that hot.
  18. Aug 14, 2011 at 4:17 PM
    Tacoma909
    No used clear RTV silicone. I think it works great.
  19. Aug 14, 2011 at 4:17 PM
    Tacoma909
    X2
  20. Aug 14, 2011 at 6:41 PM
    Mitch
    Mitch
    Spokane, WA
    So from start (pulled lights off and into oven) to finish (lights back on truck) how long did it take?
