Bi-xenon Morimoto Mini Stage III (D2S) (DEMON EYES) Headlights
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by ColoradoTaco, Nov 16, 2012.
  1. Nov 16, 2012 at 6:01 PM
    ColoradoTaco
    ColoradoTaco [OP] Well-Known Member
    Boulder
    2013 DCSB OFFROAD
    Headlights off old Tacoma
    All purchased from The retro fit source ecept the housing those are ebay
    #1 TREX EYELIDS painted at a paint shop with the same black paint code
    Two morimoto 35 watt ballast
    Appolo Shroud
    Phillips 85122 As close to noraml color with a slight blue tint
    the DTRL/TURN signal cover painted with krylon yellow stained glass
    The back of the projector is painted with a mettalic red hig temp ceramic paint. Truley Bad ass and one of a kind.
    PIC IS NOT ALTERED IN ANYWAY NO LED's natural reflection of light off inside of projector.
    Looking to recoup the cost of the parts labor is on me
    390 for the parts
    45.00 TREX EYELIDS....50 for the paint...90.00
    135.00 Ebay headlights
    Total in parts no labor
    ASKING 615.00 OBO
  2. Nov 16, 2012 at 6:51 PM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    God... those are GORGEOUS!!!
  3. Nov 16, 2012 at 7:21 PM
    ColoradoTaco
    Boulder
    2013 DCSB OFFROAD
  4. Nov 16, 2012 at 8:45 PM
    dlooney
    dlooney Well-Known Member
    Dennis
    Wilmington NC
    07 TRD Sport PreRunner
    Satoshi w/ hella 500s mounted behind, 20% tint, 6K HID retro headlights, 4300k HID fog lights, DTRLs, plastidipped front valence, cb mount
    Looks badass, if I had 600 bucks...damn
  5. Nov 16, 2012 at 9:17 PM
    Datsik
    Datsik Well-Known Member
    Anthony
    San Diego
    Not much.
    Your old truck was clean man. You going to start stormtroopin this one soon?
  6. Nov 18, 2012 at 7:06 PM
    ColoradoTaco
    Boulder
    2013 DCSB OFFROAD
    got it just in time for thanksgiving sales
  7. Nov 18, 2012 at 7:11 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Looks sick!
    Is there a red tint to the beam at night from the reflector, or does the HID burn through it?
  8. Nov 18, 2012 at 7:21 PM
    ColoradoTaco
    Boulder
    2013 DCSB OFFROAD
    the beam comes out clean but if you look directly into the projector while its on you can see a slight red tint but nothing to be worried about from the popo.
  9. Nov 18, 2012 at 8:56 PM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    What part of the projector is painted? The cut off shield or the actual projector? Also what paint is that? It looks freaking amazing and might have to copy you if I do another retrofit.
  10. Nov 19, 2012 at 10:45 AM
    nimrod712
    nimrod712 Well-Known Member
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    Dang, those look good. The more I look at them, the more I like them.
    Any leaking or anything? How old are they?
  11. Nov 19, 2012 at 11:33 AM
    ambiguous
    ambiguous Master Retrofitter @RECHELON/AESTHETICS Vendor
    Burt
    Portland, OR to SoCal
    2012 DCLB TRD
    Demon eyes look cool. I'm assuming it's the shield that's painted not the back of the projector itself...
  12. Nov 19, 2012 at 1:23 PM
    ColoradoTaco
    Boulder
    2013 DCSB OFFROAD
    if you have the projector in hand remove the glass paint everthing except the bowl that stays chorme to help reflect light. I painted the back of the cutoff, the edges around the bowl and the black box that houses the little spring. So everything but the bowl. The paint is VHT high temp mettalic red ceramic paint. I will get the exact name when i get home.
    As far as wear and tear they were on the truck about 3 months. i would not seel to to fellow TW members if there were any imperfections. No cracks no leaks nothing. As stated in original post this was my third set and they came out perfect. So much so that instead of destroying them to use the parts in my new 2013 I felt that would be a shame so im offering them to all yall.
  13. Nov 19, 2012 at 5:44 PM
    smood74
    smood74 Toyota Fanatic
    Coconut Tree, Hawaii
    Simple Toyota
    Simple Stuff
    pm sent :D
  14. Nov 20, 2012 at 12:24 PM
    ColoradoTaco
    Boulder
    2013 DCSB OFFROAD
    still for sale pm me with any questions.
  15. Nov 21, 2012 at 9:28 AM
    ColoradoTaco
    Boulder
    2013 DCSB OFFROAD
    SOLD. Thanks TW
  16. Nov 21, 2012 at 10:47 AM
    fgcutaco
    fgcutaco Fly rod in one hand, hockey stick in the other
    Nashville
    '09 SWB, Access Cab, 5 Lug
    Stock... For now...
    Dang! Those things are BADA%$ :drool:
    Edit: (stupid move, didn't see they were sold)
  17. Nov 24, 2012 at 10:55 PM
    MGoBlue
    MGoBlue Active Member
    Rex
    Ann Arbor, MI
    2013 Tacoma 4X4 TRD Sport
    Debadged, 5% Tint on Rear Windows Over Factory, 35% Tint on Fronts, 1.25" Hub-Centric Spacers with Factory 17" Sport Rims Painted Black, Valentine One Radar Detector Install (ODB Powered), Blacked Out Front Emblem
    Yo OP, could I ask you what type of rims those are in the photo of your black truck? That rim/tire combo is pretty sick. Actually, what are those tires too?
  18. Nov 25, 2012 at 4:57 PM
    ColoradoTaco
    Boulder
    2013 DCSB OFFROAD
    18" xd monster center caps removed with duratracs 295/56/18
  19. Nov 26, 2012 at 7:21 AM
    MGoBlue
    Rex
    Ann Arbor, MI
    Thanks for the reply! I like the way those look. Might have to swagger jack. My taco is a magnetic gray though.
    Those demon eyes are dope. If they would fit a 13 I would cop them quick.
