Bicycle alarm install w/pics
Discussion in 'Audio & Video' started by Raylo, Jul 26, 2009.
  1. Jul 26, 2009 at 2:14 PM
    Raylo
    Raylo [OP] Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    When I installed my security/rs system a couple months ago I ran the second negative trigger wire, typically used for trunks, into the drivers door sill for future use for my bicycle alarm. I finally got around to completing this. It uses a tilt switch connected to a cable that runs into the bed via the center drainage hole. Then I can run a bungee cord or thin cord or wire from a bike, from the bike locking cable, or from anything else I want to protect to this new alarm cable where it comes out of the drainage hole. Any tugging on this sets off the alarm. The tilt switch also functions as a full veicle tilt switch for towing, jacking, etc. Not perfect security for leaving a bike for long periods in sketchy isolated areas since the lock cable goes to d-dings held on with bolts, but it expands the situations where I feel comfortable leaving my bike unattended.
    Here are some pics.
    First, the blue second trigger wire. I extended this wire and ran it through a rubber body plug under the seat. IMG_0432_d33f617791b79423491989b2e6ad67b3fd745e53.jpg
    DEI tilt switch.
    Fabbing brackets.
    How it moves.
    Completed device. Rubber band is for helping gravity return the switch home after it is tripped. I ended up not using the single black wire to connect to the actuating cable. I just attached the actuating cable directly to the tilt switch... shown in a later picture.
    Cable ending in bed.
    Cable from underneath.
    Final install on body crossmember.
  2. Jul 26, 2009 at 2:17 PM
    AFButters
    AFButters Rigger, Please!!
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    thats pretty cool
