Big 2GR-FKS engine problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ToyFXR88, Dec 17, 2015.
  1. Dec 17, 2015 at 11:07 AM
    ToyFXR88
    ToyFXR88 [OP] Well-Known Member
    WI
    2016 MGM DCSB TRD Sport 6MT
    So an acquaintance of mine at another dealership has encountered an interesting situation with a 2016 Tacoma with the new v6. Customer stated oil light was on at around 5,000mi. Upon inspection, found truck was low on oil. Added 2.5qts. No oil leaks were found. Began an oil consumption test, and concluded the truck loses approximately 5qts of oil every 10,000mi, because at 10,000mi, another 2.5qts was added. When looking in cylinder 4 with a bore scope, we found scoring on cylinder wall #4 and lots of oil. Spark plug #4 was smothered in oil too. Toyota approved an engine tear down. Cylinder #4 indeed scored, heavy carbon deposits on piston #4 along with valve parts from the same cylinder. Oil found in intake. Currently trying to find source of oil. Will share pics soon.
    Toyko Joe likes this.
  2. Dec 17, 2015 at 11:08 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    queue all the haters of the 3rd gen in 3...2....1....
    But I am curious as to what's going on and if it's a single issue or has others reports this as well? That person must have been driving quite a bit to hit 10k miles already.
  3. Dec 17, 2015 at 11:09 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Damn.:eek::popcorn:
  4. Dec 17, 2015 at 11:12 AM
    ToyFXR88
    WI
    Lots of oil in the intake side of both heads. Tons of carbon in cyl 4. All 3 cyl walls on bank 2 are scored. Rings and seals looked ok
    Key-Rei, Toyko Joe and Pella like this.
  5. Dec 17, 2015 at 11:17 AM
    busticator
    busticator Well-Known Member
    FL
    2016 Tacoma SR5 DCSB
    CPS rev2
    yea that sucks. guess I better check my oil now.
    kennebec likes this.
  6. Dec 17, 2015 at 11:19 AM
    bearsman34
    bearsman34 Well-Known Member
    RVA
    2016 Inferno DCSB TRD OR 4x4
    well that certainly looks like a problem. Hopefully it is very short list of people with this problem....like 1
    wirenut likes this.
  7. Dec 17, 2015 at 11:22 AM
    OffsetPlayer2
    yeah I'm hoping this is isolated as well and doesn't spread to everyone. That could be bad.
  8. Dec 17, 2015 at 11:24 AM
    ToyFXR88
    WI
    yeah I'm hoping it was a Friday @ 4:30 engine or something like that. Perhaps check your oil levels just to be safe... If it's low, DO NOT add oil. Take it to your dealership and get the documentation started.
    Junkhead likes this.
  9. Dec 17, 2015 at 11:27 AM
    Suxdsmdmr
    Suxdsmdmr Well-Known Member
    Iowa
    2016 Tacoma Limited DCSB 4x4 Super White
    Do you have a VIN number on it to know which plant or when this one was built?
  10. Dec 17, 2015 at 11:31 AM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    All the engines are built at the same factory in Alabama.
    Plain Jane Taco likes this.
  11. Dec 17, 2015 at 11:31 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Looks like self cleaning cycle working as designed.
  12. Dec 17, 2015 at 11:35 AM
    ToyFXR88
    WI
    It wasn't designed to handle oil like this. We suspect the excessive oil lead to the carbonizing of everything. Despite how the valves looked, it still had perfect compression. It's quite the head scratcher.
  13. Dec 17, 2015 at 11:36 AM
    Large
    Large Red
    :pccoffee: I need a good read
  14. Dec 17, 2015 at 11:39 AM
    ToyFXR88
    WI
    this didn't do it for ya?
  15. Dec 17, 2015 at 11:41 AM
    Large
    Large Red
    That's why I'm here. :cheers:
  16. Dec 17, 2015 at 11:43 AM
    BlueT
    NorthEast
    I dont think its head scracher. Somebody at factory scored cylinder, so oil in larger quantity than normal was getting pass piston inside cylinder #4, since this engine has that Atkinson cycle. That means when oil was going pass piston, inside the cylinder, and Atkinson cycle kicked in, intakes valve stayed open and fuel and oil got pushed into intake.
    Really the only head scratch-er is who is the a hole who scored cylinder. I dont think there are many engines like that, unless the retard in factory who was putting that engine together was drunk through out the shift.
    So that maybe only truck, but Iwould check every truck that has engine from that particular dude.
    shthawk likes this.
  17. Dec 17, 2015 at 11:44 AM
    highwhey
    highwhey Well-Known Member
    Alan
    Phoenix
    2016 Tacoma OR m/t
    Does the customer get a new engine? Are you a tech?
  18. Dec 17, 2015 at 11:46 AM
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    Just throwing this out there. If the valve stem seal failed catastrophically enough to allow a certain amount of oil into the cylinder, and the engine continued running for several thousand miles, could the resulting carbon build up break away enough material to score the cylinder?
  19. Dec 17, 2015 at 11:53 AM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Likely "just" a manufacturing defect. I've been checking mine routinely and don't notice any change in oil level. I'm at about 3500 miles. The design and testing of engines from a company like Toyota is so refined that having a gross design error just isn't going to happen.
  20. Dec 17, 2015 at 11:54 AM
    Thomas Jefferson
    Sacramento,CA
    '13 SR5 DCSB 4x4
    I would definitely try to get a new crate motor. Seems like this is applicable under the lemon law.
