Big 2GR-FKS engine problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ToyFXR88, Dec 17, 2015.
  1. Dec 25, 2015 at 9:12 AM
    #141
    highwhey
    highwhey Well-Known Member
    Alan
    Phoenix
    2016 Tacoma OR m/t
    He said shortblock is upwards of 4800, complete assembly is 28000. I'm just baffled by the discrepancy in price when the only additional parts are the heads and engine accesories.
  2. Dec 25, 2015 at 1:03 PM
    #142
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    I assumed it came with everything under the hood.
    ToyFXR88[OP] likes this.
  3. Feb 3, 2016 at 4:14 PM
    #143
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    Subscribing this thread.
    Just took mine in for 5k service. Was short a bit of oil, light going on intermittently.
    I'll go talk to the techs and see what they did.
    I did do a bit of offroading before (mostly trail runs), but that shouldn't result in oil burn, right?
  4. Feb 3, 2016 at 4:26 PM
    #144
    highwhey
    Alan
    Phoenix
    2016 Tacoma OR m/t
    Did your light turn on at 5k miles or before? I'm at 4450 and my maintenance light has been on permanently for the last 80 miles. Also went off roading recently.
  5. Feb 3, 2016 at 4:28 PM
    #145
    .劉煒
    Maintenance light is a factory thing. You can just reset that, but hey, ToyotaCare is free. It comes on 500 miles before the service interval. Mine came on too.
    This was different.
    I didn't do anything too insane, just wanted a chance to put it in 4L/atrac (ha!) So I did a little bit of Tonga Pass until my tires hated me.
    Oil level display popped on, I checked the stick manually, and it was barely on the stick.
    Currently at 4800-ish.
  6. Feb 3, 2016 at 4:42 PM
    #146
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    I wonder if this is some kind of first model year thing.
  7. Feb 3, 2016 at 4:43 PM
    #147
    .劉煒
    I sure hope not.
    I'll keep y'all up to date, don't you worry.
    James_Bond likes this.
  8. Feb 3, 2016 at 4:46 PM
    #148
    addicus24
    I just believe Toyota will make this right with the owners of the trucks in question.
    .劉煒 likes this.
  9. Feb 3, 2016 at 4:48 PM
    #149
    usadaytrader
    usadaytrader Well-Known Member
    Anybody else chime in? Whats your oil level at 5,000 miles? This sucks. My 2nd gen 4 cylinder didn't burn any oil until it was well into the 200k miles
  10. Feb 3, 2016 at 4:50 PM
    #150
    .劉煒
    Update: dealer just called, they have commenced the oil consumption test. Update in a few weeks (or 6k miles)
  11. Feb 3, 2016 at 4:51 PM
    #151
    .劉煒
    Repairs under warrantee are promised.
  12. Feb 4, 2016 at 6:53 PM
    #152
    Gutt Pile
    Gutt Pile Well-Known Member
    2016 Blazing Blue TRD Offroad
    Could be worse I guess. At least the low oil indicator worked? I wouldn't even think to check the dipstick on a new toyota before the first 5K miles.
  13. Feb 4, 2016 at 9:26 PM
    #153
    bruce_d
    bruce_d Well-Known Member
    Davis, Ca
    2016 Tacoma DCSB SR5
    :rasta:
  14. Feb 5, 2016 at 12:41 AM
    #154
    DRosales901
    DRosales901 Well-Known Member
    Dante
    2016 Silver Tacoma TRD OR Double cab 4x4 auto
    We're screwed. :confused:
  15. Feb 5, 2016 at 6:28 AM
    #155
    ToyFXR88
    ToyFXR88 [OP] Well-Known Member
    WI
    2016 MGM DCSB TRD Sport 6MT
    Sadly, I don't have anything further to update on the case I originally posted about, but I have not encountered, nor have I heard of any other similar low oil situations.
  16. Feb 5, 2016 at 7:24 AM
    #156
    red1949
    red1949 Active Member
    Richard
    I would think that if a valve guide seal failed sufficiently enough to allow a significant amount of oil into the cylinder that the engine would be smoking noticeably. In any event this certainly appears to be a workmanship issue, and I hope it is an isolated incident.
  17. Feb 5, 2016 at 8:09 AM
    #157
    .劉煒
    I'll let you guys know what the result is in another 1000 miles for the oil consumption test.
  18. Feb 5, 2016 at 1:13 PM
    #158
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Mine has not used any that I have noticed and I check regularly. At 6000 miles and two oil changes.
  19. Feb 14, 2016 at 9:16 AM
    #159
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I hope my oil indicator light works. I cannot see the oil level on my dipstick. (734 miles)
  20. Feb 14, 2016 at 9:22 AM
    #160
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    Drill some small holes at the business end of the dip stick.
    CusterFan[QUOTED] likes this.
