Big 2GR-FKS engine problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ToyFXR88, Dec 17, 2015.
  1. Feb 14, 2016 at 9:24 AM
    #161
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I was thinking about putting a quart of Royal Purple 0W-20 in it.
    TacoBella[QUOTED] likes this.
  2. Feb 14, 2016 at 10:08 AM
    #162
    angry john
    angry john Well-Known Member
    john
    2016 DC OR V-6
    You think maybe your over reacting??? One case and were all going down in flames. Go have a smoke drink a cup of coffee and relax!
  3. Feb 14, 2016 at 12:50 PM
    #163
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Press it against a paper towel or napkin and look for the wet spot
  4. Feb 14, 2016 at 5:50 PM
    #164
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    That's what she said...!!
    Duchateau and Wittyusername like this.
  5. Feb 14, 2016 at 7:32 PM
    #165
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    Gentlemen, gentlemen! A bit of decorum, please!
    Wittyusername likes this.
  6. Feb 15, 2016 at 8:55 PM
    #166
    sndtubes
    sndtubes Active Member
    2016 TRD Off Road 6sp Manual
    So do you all recommend 5000 mile oil changes even though we are using full synthetic? So far, I really like my 2016 Taco Off Road MT. I'm hoping it will be running strong like the 2.7L in my 2003 Honda Element 5sp. Uses no oil and runs just like it did when new. Original clutch even. I am expecting that kind of service from my.Tacoma....
  7. Feb 15, 2016 at 9:53 PM
    #167
    highwhey
    highwhey Well-Known Member
    Alan
    Phoenix
    2016 Tacoma OR m/t
    I'd say look at your oil and you decide? I'm going with the 10k miles but i just hit the first 5k so I'm going to do it within the next couple of days because i am paranoid about what is floating in my engine with it being new and all.
    As for clutch wear, that's really on the driver. I've had previous cars with manual and i drove them fine but after a long period of driving auto, it took me a while to readjust to manual on this tacoma. I've actually stalled a couple dozen times pulling out of parking lots -_-
  8. Feb 18, 2016 at 10:35 AM
    #168
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    1k mile test over, after they filled it up it didn't budge.
    I'm just going to chalk this one up to low fluid levels and dry sumps from the factory, and a bit of trail driving splashing the oil everywhere and coating everything leaving less in the oilpan.
    But I'm going to keep an eye on it.
  9. Feb 22, 2016 at 4:37 PM
    #169
    Tacomatrd2010
    Tacomatrd2010 Well-Known Member
    Jimmy
    Colorado
    2016 Street Queen
    [​IMG][​IMG]this seem like a lot? changed at 1200 miles. showed a friend thats a mechanic and he thinks so.. these pics were taken after i had already rinsed the thing twice with fresh oil..
  10. Feb 22, 2016 at 7:53 PM
    #170
    Js16taco
    Js16taco Well-Known Member
    2016 Tacoma trd sport
    Use brake clean to clean it out, mine looked the same at 1500, now at 2300 and running great
  11. Feb 23, 2016 at 7:25 AM
    #171
    manofsteele2003
    manofsteele2003 Well-Known Member
    2016 Blazing Blue TRD Sport Double Cab
    17" TRD wheels w/265/70/17 BFG KO2s, Weathertech mud flaps, Gecko LED bed lights, more to come.
    It's normal for the first oil change or two. My 4Runner and everybody else's had the same.
    Tacomatrd2010[QUOTED] likes this.
  12. Feb 23, 2016 at 9:15 AM
    #172
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  13. Feb 23, 2016 at 1:30 PM
    #173
    highwhey
    Alan
    Phoenix
    2016 Tacoma OR m/t
    Just an fyi, i convinced the toyota tech to do an earier oil change. Obviously i used up one of the changes but i used the "i idle a lot" excuse to get him to change the oil at 5k miles.
    I went to sit in the lobby and i heard the advisor get a phone call from the tech "yes, I'm aware it's at 10k intervals, just go ahead and do the oil change. No, it will not be charged to you, the advisor will take care of it"
    Lmao
    TRDSport10 and Tacomatrd2010 like this.
  14. Feb 23, 2016 at 4:08 PM
    #174
    Tacomatrd2010
    Jimmy
    Colorado
    2016 Street Queen
    Oh I C. thanks guys
  15. Feb 23, 2016 at 7:42 PM
    #175
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If that light comes on and stays on, it is very likely to late and damaged has occured. It comes on at a very low oil pressure.
  16. Feb 23, 2016 at 7:49 PM
    #176
    CusterFan
    I had a 91 Ford Ranger that had leaking valve gaskets. I had the light come on one day while cutting wood. Not one drop on the dipstick. I put 3 quarts in it and it was running fine 3 years later when I sold it.
    The oil in my Tacoma is starting to darken up a little now. I cannot see a distinct oil level line but spots about 1/2" in 3 places up to the 2nd dot on the dipstick.
  17. Jun 9, 2016 at 2:37 PM
    #177
    .劉煒
    Update ... Oil light came on again at 8k miles and 13k miles. Running consumption test #2 right now. Mine seems to consistently burn about 1qt/3k miles, which seems a bit excessive to me.
  18. Jun 9, 2016 at 4:06 PM
    #178
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    It almost sounds like a VW/Audi engine.
    CoB_88 and Torspd like this.
  19. Jun 9, 2016 at 7:35 PM
    #179
    .劉煒
    Lol, my TDI went 20k between changes, so not really.
  20. Jun 9, 2016 at 7:50 PM
    #180
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    2.0T, 4.2 ate oil like a fat kid on a cheeseburger. 1qt per 1k miles.
    Torspd likes this.
