Big 3. Anyone?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KAGING, Oct 30, 2012.
  1. Oct 30, 2012 at 7:30 PM
    KAGING
    KAGING [OP] Well-Known Member
    just call me "KAGS"
    OC
    RED PreRunner SR5 Short Bed
    Flowmaster Exhaust 50 Series, BLHM, Toyota Tube Step & Bed Extender, Bike Rack Mount on Bed, Windows & Bug Deflector, Emblems & TRD Stickers Off, Grill Rims Caliper Drum Tube Step Painted.....
    Have anyone of u guys here done "Big 3 upgrade"? Any write up with pictures?
  2. Oct 30, 2012 at 8:27 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    WTF is a "Big 3 upgrade" ?
  3. Oct 30, 2012 at 8:28 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Huh? Never heard of such a thing, I thought this was a thread about the Big Three automakers.
  4. Oct 30, 2012 at 8:32 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  5. Oct 30, 2012 at 8:33 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    I have done the big three and it helps a ton. no write up or pictures sorry
  6. Oct 30, 2012 at 8:34 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Big 3: Increasing the wiring size of the integral wires on the vehicle for the 3 main electrical points.
    1) Battery to the alternator power wire
    2) Engine to chassis ground
    3) Negative battery to ground point
  7. Oct 30, 2012 at 8:35 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Never heard of this, found a pretty good article which details the mod
    http://knowledge.sonicelectronix.co...es-and-installation/how-to-big-3-upgrade.html
    "Performing what is known as the “Big 3” upgrade to your vehicle will improve the performance of your electrical system and increase its current handling capabilities. This should be the first upgrade done to your electrical system which will then allow you add more powerful audio system components. The “Big 3” upgrade is a swap or addition to these three cables:
    1) Alternator positive cable that runs to the positive terminal of the battery
    2) Negative battery cable that runs from the battery to the vehicles chassis
    3) Chassis grounding cable that runs to the engine block"
  8. Oct 30, 2012 at 8:38 PM
    LEGITacoma
    LEGITacoma Well-Known Member
    Louisiana
    99 Tacoma Prerunner
    Rockford Fosgate T0 in a Ported Box, Hifonics 1000.1, Pioneer AVIC Z-120BT Headunit w/ Rearview Camera
    I want to do it. What size wire did you use? Or plan on using??
  9. Oct 30, 2012 at 8:51 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Woah woah woah....let's tap the brakes here.
    Guy who said he did it and it made a huge difference....what difference did you observe and can you measure this?
    For everyone else, it's only useful if you're running an insane amount of current from large amplifiers or something else like a winch (which should have it's own dedicated ground anyway).
    The only reason you'd see any measurable/noticeable benefit is if the stock grounds are insufficient. I'd imagine in this instant you're running over 1000watts and using all of it on a regular basis. You were probably smart (ok no you weren't) and bought a larger alternator and a second battery too. So doing the "big 3" would likely be something you'd HAVE to do in that instance because the wires will need to go to new objects and or places.
    So long way to say that you likely don't need it and or wont see much (if any) benefit from doing it. But if you have some extra thick gauge wire and a couple free hours GO FOR IT.
  10. Oct 30, 2012 at 8:53 PM
    blake5995
    Blake
    Truckee, CA
    alright i will tell you how it helped. I am running 0 gauge as big three and a 2000 watts amp and .25 ohm Resistance and calculated to run close to 3000 watts out of it. So this is where i saw the huge difference in battery recharge rates and power handling of my vehicle
  11. Oct 30, 2012 at 9:05 PM
    ItalynStylion
    Steven
    DFW, Tx.
    You sir are in a situation that NEEDS it. In the event that you're actually USING all 3000 watts you're pulling 250A which is fucking unreal. That would certainly overwhelm the stock wiring. Sounds like it's an SPL vehicle?
    But as a said before; people in that type of power range are in the minority. Even you likely don't use close to that much power on a daily basis. If you do you either have a horribly efficient sub and partial hearing or you have a normal sub and can't hear shit. I'm guessing you upgraded the charging system too?
    PS What amp subs combo are you running? I assume you're running multiple subs since it would be hard to get to a quarter ohm on just one sub (or at least not anything common).
  12. Oct 30, 2012 at 9:05 PM
    Aw9d
    Aw9d That one guy
    I've always ran the Big 3, but I always run around 2000-3000 Watts of power. In my DC, I can't fit that much stereo behind the seats. So no need for it.
    However, I will be installing a second battery, so I will be doing the Big 3. Plus, I got about 40ft of 0g wire that needs to be used up :D
  13. Oct 30, 2012 at 9:18 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    In 95% placebo unless you are running some god awful stereo amp setup. For the average Joe it has No effect whatsoever.
  14. Nov 1, 2012 at 6:48 PM
    blake5995
    Blake
    Truckee, CA
    it aint SPL vehicle. I am running a dc audio xl (http://dcsoundlab.com/xl.html) and dc 2k amp. i havent upgraded charging system that is next on the list :)
