Big 3 upgrade in Arizona?
Discussion in 'Arizona' started by chrslefty, Jul 30, 2018.
  1. May 14, 2019 at 6:34 AM
    #61
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    How much slack was there with the 3 foot length? Was it pretty tight once everything was hooked up or a decent amount of extra in case you were running a different battery with an alternate post placement?
  2. May 14, 2019 at 6:55 AM
    #62
    Man of Steel TRD
    Man of Steel TRD Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    There was enough in this kit for me to do it twice.
  3. May 17, 2019 at 4:54 PM
    #63
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    Late but...
    chrslefty[OP] likes this.
  4. Oct 30, 2019 at 10:18 AM
    #64
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    That should work good, I recently upgraded the main cables on my 2001 diesel and they recommended crimps due to the much higher current draw of the CTD diesel starter and air heater, it can create enough draw to loosen the solder some during cold weather starts. The Tacoma draws are substantially lower, so I bet you’re good to go. Not like it ever gets cold in Phoenix area:tumbleweed:
  5. Mar 8, 2022 at 5:38 PM
    #65
    atlantaalex
    atlantaalex New Member
    Alex
    2018 SR5 V6
    Where is the engine ground wire located on a 3rd gen. I know we’re the alternator wire and ground from the battery wire are located but no the engine ground.
